My Aircooled Vanagon: Hated by All, Loved by Buggeee
Buggeee
Buggeee is offline
PostPosted: Wed Nov 14, 2018 1:20 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
?Waldo? wrote:
If you ran the heater buddy that night, then the ice was frozen condensation from the water it put into your van. Hopefully you don't still have any fiberglass insulation, or even more of the water condensed in the insulation and is rusting out your seams, especially behind the kitchen.
Agreed. Ventless sucks.
And... have you seen my seams? lol.
It's in the works, this was a shake out run so I brought my work-on-the-bus-in-the-winter space heater to survive the experience. Rest assured, its was temporary solution.
1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote:
Every setback is an opportunity to learn stuff and to buy new tools.
Buggeee
Buggeee is offline
PostPosted: Wed Nov 14, 2018 1:35 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
So now, at least, I know what the intermittent problem was. It was probably a bad connection on the TempII sensor, which was new, and I can fix that. Cylinder 3 just happened to be the first to foul out the plug on the overly rich mixture, providing a graciously placed thought-path that finally led to the real issue. This is better than bad injector or AFM or whatever might be possible.
With the engine hot and the TempII lead grounded, all 4 cylinders came on line and it ran like a champ.
So I went to just clean up the connection by splicing in some fresh wire and a connector to replace the corroded, split-covered mess that was there and found that the BRAND NEW TempII sensor was really part of the issue, the lead was just barely together in there, literally falling apart in my hand.
So even with a good connection this was going to be a problem. I emailed this picture to Bus Depot and less than 24 hours later they responded saying the manufacturer was drop shipping a replacement to me. Thank you Bus Depot!
Also, I found that the tin on the cylinder head was slightly interfering with the seating of the TempII sensor. Check this out, you can see the shiny spot where the sensor was stopping on the tin rather than the head:
So I took a clown sized flat screw driver and a Thor hammer and tapped down the edge of the tin so the new sensor will ground properly when it arrives.
My working hypothesis at this point is that the "intermittent" problem was actually a constant problem with "intermittent" symptoms. I think that the difficulties in signaling accurate engine temperature from the TempII sensor resulted in an overly rich mixture that was causing the the plugs to foul as they gasped for combustible mixture under the given circumstances.
So... all together... the TempII connection in the FI wiring harness was corroded, the tin was in the way of the proper seating of it in the head, and the sensor itself was also defective.
I finally hit the Trifecta!!!
That's not a Trifecta? Well, its the closest I'll ever come so I am taking it!
[Epilogue: I had performed the ohms resistance test as per Bentley back when installing everything and... at rest when cold I was getting the correct reading, believe it or not, even with all these issues. They came to a head (no pun intended) on this shake out run.]
levi
levi is offline
PostPosted: Wed Nov 14, 2018 7:36 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
I'm jealous of your capability to diagnose issues.
My standard approach is to guess at possibilities, and simply "replace and try" one thing at a time. Confused With believed-to-be good parts.
In fact for the last several days I've been employing just this method on my 1.8t, culminating in success a couple hours ago.
Timing belt looks good, everything lined up? Check
Switch out the coolant temp sensor, nope, put the other back in.
Switch out the AFM, nope, put the other back in.
Switch out the crankshaft position sensor, nope, put the other back in.
Switch out the camshaft position sensor, VROOOOM! Looking at the other one I see yellowish buildup on the contact, clean it off, put it back in, good to go.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
Buggeee
Buggeee is offline
PostPosted: Wed Nov 14, 2018 8:02 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Hey Levi. I'm no stranger to throwing parts at an engine. And this fuel injection is a fascinating trip down the rabbit hole for me. I've stared at the order page for a pair of Solex carburators more than once already (not looking to start a debate here Sambanistas jus' sayin). But at this point I'd really like to get it down and really understand the way it works. It is amazing to me that differences in electrical resistance is a language for the ECU. Seems so very frail to me somehow. Yet, when its working, its spot on. Immediate start. Crisp rev. Very satisfying. I think I'm going to have a collection of spare FI parts in the van though.
Congrats on your success! That must have felt great when you finally hit it.
daroota
daroota is offline
PostPosted: Mon Dec 03, 2018 9:16 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Very nice, looks like I'm a few weeks behind.
FYI on your EMPI muffler, Expect about 1-3 years life out of it, they rust so quickly. (depending on your usage)
Always use a bit of locktight blue on the temp2 sensor (just enough that it doesn't back out while driving) and also on the lower engine tin... I've come close to loosing tin.
Let me know if you need help locating parts, I run the aircooledvanagon group on fb, and we share stuff/knowledge/where to shop.
1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Air Cooled Vanagon's FaceBook Group:
www.facebook.com/groups/AirCooledVanagon/
Buggeee
Buggeee is offline
PostPosted: Sat Dec 15, 2018 8:27 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Well I've been enjoying some progress on the Westy, and put a new battery in the laptop today so time to catch up the ol' build thread a bit.
Bust Depot was good on its word and a new replacement Temp2 sensor arrived in short order.
Here it is snuggled into its new home with a copper washer.
That did help the ECU manage the richness as the engine warmed up and all 4 cylinders kept firing. I took it for a spin for a while and after it cooled down I pulled the plugs. They looked good.
However, it was still hesitating occasionally,jerking a bit once in a while and stumbling at idle. Its misbehavior seemed worse when it warmed up so I decided to just plod through the remaining snippets of the Bentley diagnostic process I had skipped and clean up all the loose ends I could find.
I checked the cold start start valve to see if it was leaking. Here is a picture of me pointing at it, demonstrating my ability to name a new part, which makes me feel a little less ape-like (an illusion).
As I understand it, it works like an injector and sprays extra fuel into the intake chamber for a bit when the engine first starts. I know it sprayed fuel as I had found a bunch in there at some point when I was changing the gasket in the throttle body. What I was curious about here was whether it stopped when it was supposed to. So I unplugged the wires to it (so it wouldn't open), unbolted it from the air chamber, and activated the fuel pump by opening the air vane in the AFM.
With the pump running and the system under pressure, the cold start valve did not leak.
The second part was to see if the signal to it from the wires turned off when it was supposed to. I bolted it back into the air chamber and left the wire unconnected. I plugged a noid light into the wire connector and started the engine. The light stayed on for about 10 seconds or so and then turned off, letting me know that the little thermal switch was functioning. Nothing to see here... move along.
The next think I tested, also successfully, was the Auxiliary Air regulator. This allows extra air into the chamber when cold, to match the extra fuel from the cold start valve I suppose. When warm, it closes. Here I'll quote myself from another thread on that:
Buggeee wrote:
I checked mine today because I'm chasing demons. It seems to be fine and I figured I'd post the pictures here.
I cleaned it with carburetor cleaner, stuck it in the freezer and here's how it looks when it's cold / open.
Then I warmed it with a heat gun for a while and here's how it looks when it's warm / closed.
The good news is it was not the problem.
The bad news is it was not the problem LOL
As long as it was out, I installed a fresh rubber thingy to avoid vacuum leaks in the future:
A few last tidbits of old vacuum hose were also retired. Here is one from the distributor line:
A proper metal gasket for the exhaust had arrived by now so the blown out paper gasket was replaced and all was quiet.
Buggeee
Buggeee is offline
PostPosted: Sat Dec 15, 2018 8:30 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Thank you Daroota. I'm not on facebook but my better half is, so I'll have her show me your site. Smile
I didn't think to use locktight on the temp2 sensor so I'll have to check in with it once in a while to see that it is staying put. I appreciate the tip.
Buggeee
Buggeee is offline
PostPosted: Sat Dec 15, 2018 8:37 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Here is one place, among many, that I have found pleasure in my metric o-ring set from Harbor Freight.
The o-ring on the case breather was a rock and it really did not provide any seal at all, the breather just stayed in there by gravity. Now its snug.
Details, details. It's the little things that replenish the motivation batteries when the demons are staying one step ahead of me.
Buggeee
Buggeee is offline
PostPosted: Sat Dec 15, 2018 8:47 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Well, that is a picture of how, eventually, I had been starting the Vanagon. I was starting it a lot as you can imagine from my adventure here.
Earlier in the relationship I thought I had a parasitic battery drain somewhere because occasionally the starter would not engage. I'd roll it down the street and bump start it and everything would be fine. Eventually I figured out it was not the charging that was making it right, it was the shock of the bump-starting. So when it would act up I'd crawl under there with the Thor Hammer and give it a wake up. (Meaning I'd knock it off the grabby grabby of the worn bearing, letting it spin again).
So check this new (rebuilt) starter out! Seems it had been coaxed along as well before getting sent in for its core duty. Laughing
This is a picture of my use of Gorilla Tape to hold the bolt in place for me
And, the relaxing view of a fresh starter ready for duty
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sat Dec 15, 2018 8:54 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
I'm enjoying this reclamation story.
You probably know this, and I'm sure a battery would do a better job but IIRC, using a heat gun to heat up the aux air valve body should cause the internal mechanism to react. i.e. it should show to some degree (no pun intended) if it's working or not.
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
Buggeee
Buggeee is offline
PostPosted: Sat Dec 15, 2018 8:55 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Another satisfying event was getting some heat into the cabin. I'm still working on getting the defrost functioning, and need to replace the cables to the heater boxes too. But for now I have installed the tube that connects the heater boxes to the cabin and have zip-tied the flaps open for the winter.
The part was hard to find. I was going to try a Bay Window tube but that didn't really work out. Luckily, some fine Sambanista gave me the proper part number and I googled one out of France! Ordering a part from a web-page in the French language was fun, as I don't speak it LOL. Here is the rundown as I explained it in another thread:
Buggeee wrote:
Using the correct part number provided by MarkWard above, I Googled and found the Vanagon driver's side heater tube in stock in one place - FRANCE.
Here is the link:
https://www.mecatechnic.com/en-GB/_C060757.htm
I ordered it and it arrived at my door in less than a week for a total of $135 and it is a brand new OG VW part.
I also ordered the $20 Bay Bus tube from CIP1, with the link WBailey provided above.
Here they are together. Bay repop on top. VW Vanagon OG on bottom:
They appear to be the same inside diameter. The Bay is substantially longer. The Vanagon is fatter on the outside. The Vanagon has an angled end on the heat exchanger side, necessary to the agle between the pieces it connnects to in the van. Neither one is flexible really.
The VW is constructed with a soft red rubber insert on each end that may help seal and may also insulate the plastic from heat.
Looking inside, the VW maintains the full inside diameter with a sturdy perforated screen holding out some kind of insulating layer. Nothing is loose. No fibers can be discerned. Really clean, sturdy, quality look and feel to it.
In contrast, the $20 Bay repop is stuffed with loose batt insulation that looks to me like fiberglass, and held out, somewhat, by what looks to be a large coil spring.
It is a no-brainer to me. Here is a picture of the proper part in its new home. (The zip tie is only there to hold my flaps open until I can replace my cables)
Here is a close up of the part number sticker on the VW unit.
Thank you Bill! Thank you Mark!
Keep on Buggin'
Now, for you kind Peeps, I will share the result of the effort. Even after cleaning out a grocery bag full of mouse-house and blowing a million mile an hour leaf blower through all the pipes earlier in the project.... hooking up the air from the heat exchangers showered me in this!!!
Ahhhh, the lovely feeling of mouse feces and acorns sandblasting your ankles.
Uniquely... Volkswagen.
Buggeee
Buggeee is offline
PostPosted: Sat Dec 15, 2018 9:02 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Neil.
Pun Taken! Thanks Neil Yellow Vanagon
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Sat Dec 15, 2018 10:51 pm    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
I love how you called it an o2 sensor at first. Laughing someone else referred to a ts2 as a o2 earlier today to me. Funny!
On the breather hoses, if your gonna keep this, you should drop the coin on these:
https://www.thesamba.com/vw/classifieds/detail.php?id=1988499
Lifetime warranty and EXACT fit on a bay engine (not positive on a van) but as you discovered with the accordion tubes, these will rival the original parts in fitment and quality like no other. The elbow you just replaced? Those repop rubbers fail in a year or two. Faster then the empi exhaust. Shocked the long hose with a 90* in the pic replaces that perfectly.
He has the S boot as well, but only for a bay, not a vanagon.
Stuart Zickefoose
206-841-7324
[email protected]
Abscate
Abscate is offline
PostPosted: Sun Dec 16, 2018 2:46 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
I doubt that the interference of the tin hadanythimg to do with the TSII problem. If I recall its tapered thread and if it firmed up going in the ground would be good. That electrical connection was toast though.
On edit...could have messed up heat transfer parameters, agreed.
I don't think anyone has source code info on the ECU here, but there are many ways to make a resistance measurement robustly communicate to logic circuits, especially on a small number of state systems, N<10
VW Engineers smarter Dan usses monkeys.
.ssS!
djkeev
djkeev is offline
PostPosted: Sun Dec 16, 2018 5:52 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
If my hot air delivery system were full of mouse debris like that, I'd NOT want to be breathing the hot air that comes out!
I would so be flushing the pipes with a cleaner and a sanitizer to remove not only the putrid smell but any chance of virus germs found therein.
I did exactly this in my WBX Vanagon, removed the entire mouse soiled heat system and scrubbed it.
I also flushed out the front crash distribution beam vent while I had the interior out.
Dave
Ghia
Vanagon
Beetle
Buggeee
Buggeee is offline
PostPosted: Sun Dec 16, 2018 6:37 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Stuartzickefoose wrote:
I love how you called it an o2 sensor at first. Laughing someone else referred to a ts2 as a o2 earlier today to me. Funny!...
Fixed that typo, it was late. Thank you Stuart.
The elbow you just replaced? Those repop rubbers fail in a year or two. Faster then the empi exhaust. Shocked the long hose with a 90* in the pic replaces that perfectly...
Whaaaat? I had a new long hose with a 90 elbow in there because that's the vapor parts hack I could piece together from the local Napa auto parts counter. And then I found this part I was so proud of myself for finding that "correct" rubber elbow and undoing my "hack." Oh, well... I'll keep an eye on it and hack it back if it starts to fail. It looks good though. Rolling Eyes
Buggeee
Buggeee is offline
PostPosted: Sun Dec 16, 2018 6:54 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Dave
I'm maintaining my immune system Dave. Wink (As a child I slowly but regularly increased my exposure to OG Volkswagen Rodent garnish to develop a resistance worthy of study by the World Health Organization).
Actually I'm surprised it hasn't all killed me yet between the air-cooleds and old campers that have fertilized my lawn and driveway. I do appreciate your point. I've got a gallon of a Simple Green product that includes a disinfectant for flu and virus, etc. that has done a great job on the campers for me and will lay some waste to the waste in this thing after winter.
In the meantime, I'm not done yet. There is still something interfering with the levers pushing the selection between floor and defrost, and it has a soft but insistent resistance that lets me know I'm gonna be pulling out another shredded t-shirt with a coat hanger before its over.
P.S. I have also flooded the heat exchangers with foaming engine degreaser and a thorough rinsing more than once, but its still is working out the burn-off of old oil here and there so having the windows open and a hat on the head is how this is goes for now. There is no substitute for using a vehicle to keep it maintained, and this one sat for a very long time.
jlrftype7
jlrftype7 is offline
PostPosted: Sun Dec 16, 2018 7:12 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
Dave
Hopefully that ‘soft but resistive ‘ thing isn’t the decaying body of a mouse jammed in your cables somewhere... Shocked
‘84 Tin Top - Hilga....Auto
Buggeee
Buggeee is offline
PostPosted: Sun Dec 16, 2018 7:21 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
LMAO for real. Thank you for that one I almost spit out my coffee! Very Happy
If it is I'm posting a picture for sure!
Buggeee
Buggeee is offline
PostPosted: Sun Dec 16, 2018 7:45 am    Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee Reply with quote
I have read, many times, and agree, without reservation that it is better to be able to stop before being able to go.
So while I had inspected the brakes a bit before rolling this dog around the roads, the parking brake had not been addressed.
Tiring of carrying a brick around in the cabin to use as a parking brake, and as impressive as that is to the onlookers when I apply the brick-brake and release the brick-brake in the parking lot of the grocery store, etc., I decided to address the parking brake.
What I found was actually very interesting and very weird, even for an aircooled world that is full of weirdness. I had never come across anything like this before but another thread turned me on to the underlying issue... which was not the braking system at all. Here I am reporting in on that:
Buggeee wrote:
Thank you for this thread about bad ground straps sending electricity through odd places like brake lines.
It helped me make sense of this:
That's a melted rear parking brake cable, which I was replacing because it was locked up. The plastic liner had fused with the cable, etc. Check out that melted covering.
So because of this thread, while I was under there I pulled the ground strap, cleaned it with some phosphoric acid, threw on some marine shrink wrap and reinstalled it with dialectic grease.
I learn something new every single day on the Samba. Smile
So, having learned something new, I proceeded to exercise a skill that was old, replacing the e-brake cable. I will spare you pictures of that tediousness.
However! I will subject you to a picture of my new rear wheel cylinder. Very Happy I now have two. They were dry when inspected before my trip but like everything rubber on this van, failing soon with any real use and already seeping at the time of this inspection.
Sitting it out for a decade is the cruelest thing to do to a car. I think the brakes had been done in the ordinary course before this one got parked, there is plenty of pad and not any real scoring on the front discs. But they are in line for a replacement next summer as the pitting gives a less than engineered surface to grab and a dry sound that is not all that impressive. Also they are solid rotors. Who does that?
As long as I had opened the lines for the rear cylinders and had to bleed the air out, I popped up to Harbor Freight for a brake bleeder kit that plugs into an air compressor so I could flush out all the old brake fluid. I did not have a helper handy to sit in the front seat for me and... well... any excuse is a good one for a new tool. Cool
Check out the dark mess that came out!!! Fluids. Replace em. Am I right?
I have new rubber brake hoses front and rear that will go on in the spring as preventative maintenance.
Page 5 of 9
