Vanagon Nut Samba Member
Posted: Wed Dec 19, 2018 12:29 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
And it even has the fuel pump switch. Nice work!
I guess the price of those AFM's will go up soon.
Neil.
Buggeee wrote: |
... It is brand new.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Wed Dec 19, 2018 3:06 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Abscate wrote: |
...with the TSII problem... That electrical connection was toast though. |
... And that was not the only Toasted connection I had!
In addition to the expected corrosion of connectors and cracked rubber, I had lit a bit of a fire in there early on if you all remember.
So I decided to just dive in and eliminate any issues with the wiring harness, inspired by some other threads here on the Samba.
I had a spare harness in the garage and I pulled this crispy one out of the van, laying them both on my basement floor.
Deep breath.
Ok, lets just get in there and start pulling off the covering. I threw a zip tie on each off-ramp as I relieved it from its covering so I could maintain the original dimensions as I went along. This is more tedious than I expected so I took a break half way through to document the progress, and grab a coffee:
After I got them both laid out, I inspected and chose the one I wanted to use as my foundation. Here is a menu of the various shortcomings (pun intended) found throughout them both:
Corroded connections:
Crispy coatings:
Wear/heat markings?:
Scary tape jobs:
Scarier groupings of cracked coatings under scary tape jobs:
Cracked and loose FI connectors:
Honestly, its a marvel that either of these harnesses could communicate the sensitivities of a FI system at all. But, the engine had been running.
Fun Fact: Once you remove the covering, every one of the white inner wires is tattooed with a number!!! Squint if you must, I did and its like looking at a little diorama or something, full of delightful surprises:
_________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Posted: Wed Dec 19, 2018 3:25 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
And, having found the floor of the valley, here is a menu of the methods used to climb my way back out....
First, all new fuel injection connectors for the injectors and the cold-start valves, etc. They are all the same. They come, now, in an available "spring clip" variety that makes it really easy to press and release when pulling them off the injector. Here is a picture:
I used one of these for each of the injectors as I have room enough by the intakes to have that spring arched above it and get my fingers on it to release it.
Compared to the original type that has a little wire spring, but does not have the arch for press and release convenience (sorry for the blurry but my eyes were crossing at all these little things so you can share the experience :
I used one of these on each of the three connections by the cold-start valve stuff near the air chamber/intake box. There is not enough room under there for me to use the arched spring, or to get my fingers over it anyway.
As it turns out, each of my local auto parts stores carries exactly ONE of each type of these connectors. ONE springy, for about $12 and ONE not-springy, for about $5.
I drove around town emptying the inventory of every store until I had enough. Now their order points will get all jacked up for about a year and they will have ample stock (tee, hee, hee).
For the corroded connectors, I set up a dish of phosphoric acid and a spray bottle of water. I'd soak the connector until it was bright and coppery and then I'd rinse it with the spray bottle and hit it with the heat gun briefly to dry it out thoroughly.
Here some are soaking:
Here are a couple examples of how they turn out.
This acid does more than just clear the surface of the connector, it gets in there and dissolves the green corrosion that is inside the strands of wire where they are crimped inside the connection.
Here, let me demonstrate a bit.
The fuel injection connections came with pigtails like 6 inches long or so. Also, some sections of wire just needed to be replaced. Stripping the old end of the original harness that would remain, I would find, predictably, that the copper inside was a bit oxidized - like so:
Before applying the ol' "lineman's splice" (Google it) to mate the new and old wires, I'd dip the old wire in the acid, just briefly:
Then I'd rinse it and dry it right away. It is like magic, and here is the result:
Clean and ready for mating.
Let's rest our eyes for a moment with a far away shot to relieve the muscle stress (I am aging as I breath it seems).
Posted: Wed Dec 19, 2018 3:37 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
I was scratching my head for a bit on how I wanted to handle the wear/heat marks I found inside where groups of wires had spent many decades working together in the close confines of the factory protective wrap.
Then I stumbled on this... liquid electric tape! How cool is that? It's cool.
So I just painted a few layers of this liquid rubber all over and into the groups of wires that had shown weakening of the white jackets. This shot is after a coat or two while it dries waiting for the next one.
The liquid electric tape (I happened to get this at Home Depot) comes in different colors too. The spring type fuel injector connectors did not have a shape that would have held the rubber boot, and seemed be sealed on their own. I decided to give them each a coating of appropriately colored green rubber.
After all the goo had dried, I laid out the harness as it would be installed in the van.
Then I installed varying sizes of wire covering to protect the whole thing. Here it is just before the final entombment in miles of electricians tape:
I think that shot really captures the "nervous system" plate for me. At this time of night (it was really late by now), the living nature of the organism had started to preoccupy my imagination. Time for bed!!!
In the morning, I killed many rolls of black electric tape and here is how it looked just before plugging it into the van:
Zeitgeist 13 Samba Member
Posted: Wed Dec 19, 2018 4:16 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
I recently rebuilt a problematic Vanagon engine harness similarly.
I also harvested a Fuego AFM years ago, and quite possibly used it on my '80 AC van...in fact, I'm positive I did. I think I assumed for a long time that all Bosch AFMs were the same after that. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Dec 19, 2018 10:34 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
This rabbit hole just gets better the farther I run down in it!
Outstanding find with the AFM! Total score!
Check this out: About a year ago I was fantasizing about a ‘test rack’ set up for my 1978 Baywindow. Like modeled after one of those giant Bear computers that you would see for the mechanic where he’d hook up all the test leads to the engine and start running his tests.
In that quest, I found an AMC/Renault/Chrysler test module that had the same exact Bosch multi pin connector... female on one side, male on the other. But I think there was something missing with it. It didn’t matter, because what I wanted was the female connector, and what I was going to do was feed all those leads into a couple of meters with a rotary switch. The leads would connect to all the test points, and the thing would set on a little wheeled cart. So I could select channels with the rotary switch and get dynamic information at different engine speeds without having to dick around moving test leads around. The envisioned console would also have a vacuum gauge and a fuel pressure gauge. Next to that would sit the LM-2 analyzer.
But I digress!
Anyway... I had a minor thought at the time to learn more about the relationships of Bosch/AMC et. al., and I was pleased to learn there was shared technology among the product lines. But I never pursued anything more, and the little module is still on the shelf.
I’ll have to get a pic of it to you. |
Posted: Sun Jan 06, 2019 10:24 am Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
An opportunity for personal growth has been bestowed upon me!
I have been bombing all over town in my Vanagon this season. Smiles, waves, impromptu conversations with people at drive through windows, gas stations, grocery parking lots. You know the drill, you drive a classic VW.
Then, while my Precious was left unguarded, parked helplessly out on the curb of a side-street with the great unwashed masses of daily drivers in a quiet suburban neighborhood.
We ate, exchanged gifts, warmed in the revelries of family, food and holiday festivities at the in-laws.
Blissfully, and selfishly, enjoying the holidays, fully unaware of my poor Precious nervously shaking in cold street outside, suffering the brutality of the wold around us and waiting for me to return to find...
Some Fool had caved in the side of my Westy and did't even bother to leave a note!
Thankfully, she gave just inside each of the seams. The seams are straight. By luck of poor weather I had not yet installed the replacement panel for the kitchen seam, so the Gorilla Tape gave readily, saving the line of the bottom of the rocker.
I can handle this. I will have my hands full, but I can do it. In the spring. When the heat in my head passes and the heat of the sun returns.
So...
I am going to be meditating on my Super Beetle for a bit until the resentment passes. Got some growing to do before I can fully indulge this repair in a healthy mind.
Man I hate opportunities for personal growth. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
jimf909 Samba Member
Posted: Sun Jan 06, 2019 10:32 am Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Dang. That's not a nice Christmas gift. You do seem to have an unusually good perspective though.
Here's to growth opportunities! _________________ - Jim
Abscate wrote: |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun Jan 06, 2019 10:47 am Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Buggeee wrote: |
That one is mine now, you will have to find your own!!! It works great. |
Hehe...I got the next one for a mere $105 for Notchboy
Bummer about the hit buggee! I’d be just a slight bit peeved as well.
Personal growth personal growth personal growth.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Muftobration Samba Member
Posted: Thu Mar 21, 2019 9:07 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
I just finished reading through the whole thread. Thank you for posting so many details and pictures! It makes me realize I should be doing the same with my van, which I've been restoring for a few months now. I love your writing style.
I actually just found out that my van ('84) was running rich due to a badly calibrated AFM. A previous owner, probably in an effort to fix the van's poor running condition due to a collapsed lifter and a failed fuel pressure regulator, had opened up the AFM, messed with all the calibration settings so it was reporting very high airflow (thus causing the van to run rich), and scribbled all over the contact patches with pencil! There are lots of crazies out there, and some of them owned our vans before we did. |
Scottn59c Samba Member
Joined: December 22, 2016 Posts: 308 Location: Northern CA
Posted: Sun Mar 24, 2019 9:06 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Been reading this thread on and off throughout the day as I get ready to take possession of an '81 AC Westy this week.
Man, I didn't see that hit and run coming - that sucks!
My van is going to need some body work, and I've done a little before, but if Buggeee is as descriptive as he was in all the other posts as he goes through the process, we can all learn from it.
I've been gone awhile and I'm looking forward to being part of this community again! _________________ Farfignewton! |
Posted: Fri Apr 05, 2019 6:53 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Fellow Star Trek Shuttle Fans.
I am shamelessly bumping my own thread today because I need some help and I have posted a thread in the engine section looking for insight. If you know what a rod knock sounds like, or if you know what a bad hydraulic lifter sounds like, would you hop over to that thread and share your thoughts? I don't want to destroy my engine so I'm trying to decide whether to crack into it before camping season. Here is the link:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716830
As for me, and thank you for asking, I am doing well. I have been in regular (almost daily) therapy sessions with my Super Duper Super Beetle and have a very good handle on my resentment over the @#$%#$@ who slammed into my Precious at Christmas. Sorry, little slip there. I'm close to being released to the side yard, however, to start in on the Vanagon repairs and am noticing the birds chirping again, etc.
Thank you for any help over there on the engine knock thread!!!!
P.S. -----
Muftobration wrote: |
... A previous owner ...had opened up the AFM...and scribbled all over the contact patches with pencil! ..... |
WTF??? Why didn't I think of that! lmao _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Fri Apr 05, 2019 10:41 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Posted _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu May 30, 2019 12:25 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
Buggeee wrote: |
Still here? Good....
P.S. For those staying after the credits to enjoy the music, the Gremlin has yet to be nabbed. Still an intermittent cut and stumble at mid throttle acceleration after its really warmed up. Stay tuned. |
O.K. I'll be realistic. Judging by the length of my beard and the strange clothes you all are wearing, I have been asleep a very long time and nobody remembers my quest for the Gremlin that haunted me at mid throttle acceleration. The year was 2018...
After replacing every piece of rubber in the fuel system, and I do mean every piece of rubber from line to vacuum to gasket, and the injectors, and the wiring loom, on and on... Oh, AND the Bitchin' Renault AFM Score! Still that annoying cut-out and stumble at mid-throttle acceleration.
So I was timing the girl, again, for the one hundredth time, and held it at 3,000 or so to see where the advance was actually settling in at up there. The light was scattering all over the place.
BINGO. It was this turd.
I yanked an equally ugly one off the spare engine in my garage, dropped it in and timed it up for a drive.
She purred like a kitten, roared like a mountain lion and cried More More More! Now this is the air-cooled fuel injection life isn't it!
Because I loooved the sounds she made for me I ordered her up one of Bill's beautifully restored distributors and I cannot wait to show you all the point-spinning porn of that thing when I get it in the girl. Wow Bill's work looks good in the box. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Thu May 30, 2019 12:43 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
I'm going to be road-tripping her this summer, so I decided it was time to change the gear oil in the transaxle of my 1983 Air-cooled Vanagon.
For the life of me I could not figure out how to get an allen key into the fill hole. It is blocked by the shifter mechanism. For the life of me I could not figure out how to remove the shifter mechanism from the transaxle. I really didn't want to either, by the way.
Then I saw in some non-Samba thread somewhere that someone used a rod-nut from Home Depot to substitute as an allen key. I got one, and I cut it down to short, and I stuffed it in the hole with just enough sticking out to use an open-end wrench on it. Here's a picture of the gear I used. The picture will betray my use of the Thor Hammer to break it loose:
Then, knowing I could fill it, I drained out the old gear oil. To my surprise, it was light brown, not black, and it did not smell of oil-well fires. Fascinating.
I looked at the magnet on the drain plug to read the tea leaves like the true mechanics here on the Samba.
I felt a little sick at first, but then I touched all the sharp spiky things. Whew! (Why don't we have a "relief" Emoji?) They were not sharp spiky things after all. Only the long hair sticking out the top had any form to it. The rest was absolute dust that just smeared into cream when I touched it. The long one had no substance really, breaking into small bits, a minor shaving.
Well it does make a rumbling racket sometimes when engine braking, but its working for now and does not slip out of any gear. With fresh gear oil, I have done my good deed for the day. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Thu May 30, 2019 1:06 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
With the help of you Sambanistas over in the engine forum, I have found the need to be playing with my hydraulic lifters to chase down an on-again off-again ticking sound.
First, I pulled out the lifters on the driver's side and did my best to keep them organized so everything could go back in the same place it came from.
A little visual inspection quickly revealed a less than satisfactory push-rod end. Ouch!
The ol' straight edge across the face of the lifters told me these lifters were not new when the PO did his "rebuild" in the basement "about 4k mi." before tying her up out by the garage for a decade. Concavity rather than convexity. [Are those words? Didn't trigger spell-check so good]
Worse, one of them had clearly been dropped on the cement floor at some point in its out-of-body experience. Check the rough edge.
There were no burrs to catch the case but still, WTF PO?! No need to check the passenger side, these are going to go in the trash all the way around.
In the meantime, I had to move the van back into the side yard, so back in they go. I laid them out for bleeding:
...and filled them up for duty according to this thread here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=331065
Then I pulled out the communicator we call a phone nowadays and promptly ordered some new ones.
This was Sunday before Memorial Day Weekend. No time to goof around.
Ebay Score with Fast-n-Free shipping - a set of Eight would delivered to my door for Sixty Bucks. Yes, you heard that right, the whole enchilada, Sixty USD. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Thu May 30, 2019 1:25 pm Post subject: Re: My Aircooled Vanagon: Hated by All, Loved by Buggeee |
They arrived at 11:30 Friday morning. We leave at 4:00 pm. Don't worry Honey, that gives us plenty of time.
Thankfully, in the midst of my bluff, I found the new lifters came pre-bled. Firm and full of some kind of oil. Here is a picture intending to capture a drop of oil dripping down the side after I pushed on it a bit.
I pulled the rockers, pushrods, tubes and lifters. For those of us Beetle owners out there, this is a really nice improvement. Pulling the pushrod tubes right out of the head is a great idea on the Type 4! I had a telescoping magnet ready to pull the lifters out of their holes and a full set of push-rod seals ready to stop the bleeding when the operation was over.
Along the way I found more smashed push-rod ends and a broken push-rod tube retaining spring that was just riding on the top of the push-rods. Really PO, Really? (I learned to say that from my ever-respectful teen brood)
I know mix-and-match is not a great thing for a fresh build, but this is not a fresh build and I have to be on the road before my best-friend makes me sell this girl, so I grabbed a handful of good looking push-rods out of the spare engine and got back in the rhythm of the adventure.
Here is a picture of how the situation presents after wiggling (with channel lock pliers) the push-rod tube and pulling it out. You can see down in there where the magnet will grab the lifter to pull it right out.
And, going back together, here is a picture with the push-rod tubes partially in place (on the right side) and wiggled/snapped down into position (on the left side). Or, maybe the ones on the right are snapped in fully and the left not so much. Well, anyway its a crappy picture so you can't tell the difference anyway. Just wiggle them until they fully slide down into the depth of the relief in the head. This was all new to me as a Type 1 dude so I found this to be fascinating:
Contrary to the PO's opinion, the spring retainer for the push-rod tubes does not ride loose on top of the moving push-rods. Instead, it snaps down into the bottom of the relief cut into the head for the push-rod tubes - holding them in place.
The rest I will leave to Bentley. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
