390nellie Samba Member
Joined: May 28, 2017 Posts: 138 Location: Westfield Massachusetts
Posted: Thu Oct 25, 2018 3:50 am Post subject: Stainless Pushrod Tubes |
Which are the better quality stainless steel factory style pushrod tubes; the EMPI's available at JBugs or the polished ones of unknown brand from CIP1? |
Deebs Samba Member
Joined: June 23, 2018 Posts: 248 Location: Chattanooga, TN
glutamodo The Android
Joined: July 13, 2004 Posts: 26298 Location: Douglas, WY
Posted: Thu Oct 25, 2018 4:00 am Post subject: Re: Stainless Pushrod Tubes |
Me I don't care if they are stainless or not. Now, the "windage" style tubes that extend further into the block to prevent oil sloshing down them when driving into curves, I think those have value, regardless of whatever metal they are made out of. That is, if you ever drive aggressively. Me, I put that style into my Baja Bug. _________________ Andy T.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Thu Oct 25, 2018 4:06 am Post subject: Re: Stainless Pushrod Tubes |
I got mine from Gene Berg and installed them in 1990 on my 1904.. Here's a picture of 2016 on my 2180.
Yes, i reused them and just cleaned the outside with some steelwool.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Oct 25, 2018 6:20 am Post subject: Re: Stainless Pushrod Tubes |
Thanks guys. I just don't want them to leak or rust. |
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Thu Oct 25, 2018 6:26 am Post subject: Re: Stainless Pushrod Tubes |
390nellie wrote: |
Remember to install with the seams UP. |
mark tucker Samba Member
Posted: Thu Oct 25, 2018 6:52 am Post subject: Re: Stainless Pushrod Tubes |
I only use the big aluminum spring loaded tubes, no leek, no dents, no dings, no effing with them.no leeks.J Cee, empi, scat. |
vwoldbug Samba Member
Posted: Thu Oct 25, 2018 5:03 pm Post subject: Re: Stainless Pushrod Tubes |
You might look at CB performance tubes . Also the empi stainless & windage tubes are ok . |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2379 Location: Seekonk,Massachusetts USA
goober Samba Member
Posted: Fri Oct 26, 2018 7:12 am Post subject: Re: Stainless Pushrod Tubes |
I like the stainless but it depends on what you plan to do with your Bug.
Stainless is more pricy but then they don't rust. My properly stretched steel OEM type tubes would weaken due to rust around the wrinkle and would lose some tension when reinstalling the heads.
And if you drive the winter in the North you might also want to consider stainless....anything that doesn't corrode due to road salt spray under the car is desirable.
Historically, the aftermarket stainless tubes I've gotten seem to have been made better than the plain steel. But I'm not sure of the quality they're making and selling today. |
