chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Thu Oct 25, 2018 7:13 am Post subject: Tar board? Drains in the floor pans?Heater channel bottom plate? |
This is on a super beetle.
Tar board?
Best way to remove in 45 degree weather?
Should I even try and save them?
When I buy new ones do I install with a heat gun?
Drains in the floor pans? Any advise on good ones that don't clog? Or make my own with regular grommets and rubber tubing? I'd like them to be flush not raised up so I don't have an 1/8 inch of water sitting.
It seams like the I should install some drain grommets that will let water out, but not in from the road.
Obvious places are the low spots, but since the low spot differs from how the car is parked I will place them under the rear seat, the low spot under the front seat and as far up front as I can get them.
Now the Heater channel bottom plate? (this is on a 71 super beetle if that matters) Do I even need this? It is mostly Swiss cheese and looks like it acts like a rain gutter soaking my heater channel. Could I remove it and just treat the exposed areas? |
Posted: Thu Oct 25, 2018 6:32 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Alright... Whats the deal with this tar stuff? |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Oct 25, 2018 6:35 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
If you can get heat from a Heat Gun on the mating side you might be able to reuse them. As I remember , they are like tar covered foam. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Fri Oct 26, 2018 6:45 am Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
theKbStockpiler wrote: |
If you can get heat from a Heat Gun on the mating side you might be able to reuse them. As I remember , they are like tar covered foam. |
You mean heat the underneath of the car?
Also, I'm gonna rust bullet the pan and want to get all the residue off. . How tricky is it to remove the residue? |
Posted: Fri Oct 26, 2018 7:15 am Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Quote: |
You mean heat the underneath of the car? |
Yes:
What is the particular 'residue' in question? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
beetlenut Samba Member
Posted: Fri Oct 26, 2018 8:29 am Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
chrisarnt wrote: |
Tar board?
So you basically have two choices with the tarboards, heat or cold. Cold works better and is less messy. One guy used dry ice and chipped the tarboard stuff off. I unfortunately did it in the Summer, and it was a gooey mess. I used a putty knife and hammer and just chiseled the stuff off. Then I used paint and tar remover with lots of rags to get off the leftover tar and residue. Just a shitty job all around!
I'm not a fan of purposely putting holes in my pan. I'd rather fix the source of the water. Stock VW's didn't come with drain holes in their pans as far as I know, and neither do the replacement pans.
The heater channel bottom plate has the captive nuts that the pans bolts up to and attaches the body to the pan with, pretty sure you want those. I've replaced those bottom plates. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Fri Oct 26, 2018 2:44 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
You can heat up the edge of a scraper and use that method but it fatigues the metal of the tool so you have to use a high quality one or at least keep a back up or two. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Tue Oct 30, 2018 4:01 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Yes you need the heater channel bottom plates. It's what holds up the floorpans.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
jimmy smallren Samba Member
Posted: Tue Oct 30, 2018 10:12 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
I found that xylene melts away tar board quite well, and would suggest giving it a try......... |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Wed Oct 31, 2018 8:21 am Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Different sizes of metal putty knives, a hammer, a wire wheel, steel brush, alcohol or acetone, and celebrate the big pieces. I never used supplemented heat or ice, and never had it turn messy, just frustrating.
Your 45deg weather should be fine. _________________ Plate of shrimp |
Posted: Mon Nov 05, 2018 5:50 am Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Actually the rust worked in my favor here because the large one under the seat just came up in one piece. The rest just left a little residue. I got it up with mineral spirits and endless running. |
Posted: Mon Nov 05, 2018 10:10 am Post subject: Pulling all the tar board up. Should I replace with stock board? |
I gotta pull it all up before I install the carpet.
The two pieces I pulled up revealed a pretty rusted, but salvageable floor pan.
Which I de-rusted and treated with rust bullet and glass.
I'm pretty sure I'll get more water in there because I know my pan seal is not sealing properly.
I think installing the rear fender seals would go a long way to stop the water, but I'm swapping out the rear fenders over the winter and will install then.
But back to the tar board...
Should I replace with stock?
On the one hand they are nice and thick. BUT! It looks like the stock allows any water to flow under it along the grooves in the pan.
then again Stock would keep my carpet dry if I installed drains holes.
But... I could install the peel and seal from Lowes and I think that would sound proof more.. I installed in the luggage area and under the rear seat. It's relatively easy to work with and goes down pretty evenly with a heat gun. But then again they would be really hard to get up if I needed to treat my pan again in 5 years.
I don't know.
What are you guys using? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Nov 05, 2018 1:08 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
I have cotton padding under the carpets in my squareback, so moisture can evaporate. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Nov 05, 2018 3:08 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Wouldn't that just make it soggy mess? |
Posted: Mon Nov 05, 2018 5:04 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
So, you need someone to explain 'evaporate' for you? _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Nov 05, 2018 5:07 pm Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
Mike Fisher wrote: |
So, you need someone to explain 'evaporate' for you? |
Ha ha HA! |
Posted: Tue Nov 06, 2018 9:18 am Post subject: Re: Tar board? Drains in the floor pans?Heater channel bottom plate? |
I doubt your pan seal is the water leak?
Usually front cooling air vents & windows for Type 3 water leaks.
We are using dry ice first & then heat/thinner. _________________ https://imgur.com/user/FisherSquareback/posts
