1950split Samba Member
Posted: Fri Oct 26, 2018 1:18 am Post subject: 48 DRLA Aux vent drip - tight valves |
Hi,
I am in the final stage of having my 1958 bug driveable again after a long break of 3 years.
The engine is a 2276, CB 2289 cam, 10.5 CR, Dual 48 DRLA's.
I was trying to tune the ignition and carbs last night but idle was crap. I then noted that down barrel 1+2, there was a massive drip down the center of the aux.vent.
I tried to reduce idle speed in order to cover progressions holes and increased timing. Nothing changed.
I had the engine running from time to time on a bench during my VW break and never had this drip.
Before removing and dismantling the carb, I'd like to clarify if a too tight valve play (meaning the valves are not closing completely) could generate a drip at the aux vent level. My valves are set a 0.15mm with manton dual tapered aluminium pushrods.
What is your take on this ?
Thanks,
Philipp |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Oct 26, 2018 4:30 am Post subject: Re: 48 DRLA Aux vent drip - tight valves |
Check your fuel pressure. If it's too high. You will get the drip from the aux vents.
I primed a set of 45's last week and over pressured the float needle valve. Fuel was running out of the aux vents.
What's the pressure?
A tight valve train will not cause the condition you are describing.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Fri Oct 26, 2018 8:38 am Post subject: Re: 48 DRLA Aux vent drip - tight valves |
Look for a sticky needle and seat or debris in there preventing it from closing. It could also just be out of adjustment, also causing the float to over run and spill out... the aux vent is the first spot it can spill out. They work just like a toilet fill valve.
If the inside bore of the seat is rough causing the needle to not move easily use a q-tip on a drill with some metal polish to clean it up. Also the circlip on one leg of the float needs to be there to keep the float centered.
As previously mentioned, check your fuel pressure as well, target 4 lbs.
I do not believe that a slightly loose or tight intake or exhaust valve can cause this behavior. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on."
74 Thing Samba Member
Posted: Fri Oct 26, 2018 8:41 am Post subject: Re: 48 DRLA Aux vent drip - tight valves |
Yep, fuel pressure, float heights or bad float, and needle seats. |
Posted: Tue Oct 30, 2018 6:35 am Post subject: Re: 48 DRLA Aux vent drip - tight valves |
Thanks for your input !
It turned out to be loose main jet holders and a needle that was a bit hard to move. |
