sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Oct 28, 2018 5:39 pm Post subject: Re: Seat stop. 64, 60/40 |
Not just to avoid measuring my own bus... But I'd just install the seat frame and see where it's paint-rubbed part of the black frame tube lands. Mark that spot, take a look underneath and drill through your weld. _________________
EverettB wrote: |
FU#5 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Oct 29, 2018 10:26 am Post subject: Re: Seat stop. 64, 60/40 |
MidDEC62 single cab measures at:
82.5mm from the right edge of that panel.
261mm from the rear of that panel.
Those are both to center of the hole.
Quote: |
Not just to avoid measuring my own bus... But I'd just install the seat frame and see where it's paint-rubbed part of the black frame tube lands. Mark that spot, take a look underneath and drill through your weld. |
At least on our SC, the OG upholstery covers the tube there. _________________ In Stereo, Where Available!
hitest Samba Member
Posted: Mon Oct 29, 2018 3:51 pm Post subject: Re: Seat stop. 64, 60/40 |
Eric&Barb wrote: |
At least on our SC, the OG upholstery covers the tube there. |
Great measurements- It's close to what I found on my double cab just now but got a flat 80mm (on center) to the side edge. I also came up with 7mm for the hole diameter if that sounds typical. My DC has it's original dogleg if it matters.
My camper bus' upholstery was worn through along the area of my stop (easy to see frame rub area)- but a lot of my stuff is way worn through _________________
EverettB wrote: |
FU#5 |
Posted: Mon Oct 29, 2018 4:14 pm Post subject: Re: Seat stop. 64, 60/40 |
Just updated the previous post that those measurements are to the center of the hole.. _________________ In Stereo, Where Available! |
