Rear view mirror install
DIMMA03
DIMMA03 is offline
PostPosted: Sat Oct 27, 2018 5:17 pm    Post subject: Rear view mirror install Reply with quote
Hi - Any trick to install a rear view mirror on a 74 Thing? The mirror is separated from the bracket. There is a metal bulb at the end. Pushed really hard but was concerned it would bust the plastic socket on the mirror.
Thanks
Al Capulco Premium Member
Al Capulco is offline
PostPosted: Sat Oct 27, 2018 10:36 pm    Post subject: Re: Rear view mirror install Reply with quote
It is a hard push, but it will go on. Put the plastic socket out in the sun for awhile. I would put a little Joy dish soap on the metal ball and try it. Use only your hands. You have to move the ball back and forth.
74 Thing
74 Thing is offline
PostPosted: Sat Oct 27, 2018 11:56 pm    Post subject: Re: Rear view mirror install Reply with quote
I found it easiest with the windshield folded down and pulling it on from leaning over the front hood.
wbailey2112
wbailey2112 is offline
PostPosted: Mon Oct 29, 2018 10:04 am    Post subject: Re: Rear view mirror install Reply with quote
I've also been through this particular process. As Al advised it will go on there eventually but it takes some muscle and some patience. I did not use dish washing soap to help with the process but I can definitely see how that would help make it a bit easier.
BTW, I would not attempt this operation with the mirror "arm" still attached to the windshield frame.
'74 Thing
'83 Westfalia
PostPosted: Mon Oct 29, 2018 1:07 pm    Post subject: Re: Rear view mirror install Reply with quote
X2. You really need to have both parts in you hands.
hitest
hitest is offline
PostPosted: Sun Nov 04, 2018 8:27 pm    Post subject: Re: Rear view mirror install Reply with quote
And wear heavy gloves just in case something shatters. And don't do it with the beloved pet nearby.
Yes, those two points are related but my family is not comfortable talking about it yet.
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '71 L12 113, '74 L65K Love Bug SE, '74 ORG 181
FU#5
