dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Sun Oct 28, 2018 7:20 am Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
Check the tdiclub. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12114 Location: Port Manteau
Posted: Sun Oct 28, 2018 7:28 am Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
...or vwdiesel.net _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sun Oct 28, 2018 7:42 am Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
If you don't need CAN-BUS functionality the $99 for a VCDS Lite registration and a $10 KKL cable from eBay/Amazon might be a good investment, especially if this is for a vehicle/engine you're keeping long term or taking on the road. Just a thought -- I was hesitant at first but it's been an invaluable tool with my 1.8T. |
HBB Samba Member
Posted: Mon Oct 29, 2018 9:45 am Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
tristessa wrote: |
VCDS Lite won't work--it doesn't have the "basic settings" mode that allows for checking injection timing, which is the main reason you need the software.
OP--there should be a sticky thread on TDI club, lots of folks share tools/VCDS cables on that site, and there are a ton of members in your general area.
Also, if you haven't done the job before, it's much simpler on a Vanagon than the stock vehicles that had the ALH. I can do it in about an hour on my Vanagon, where it takes 2 days on my Golf.
Edited to add:
Tool rental: https://www.metalmanparts.com/product.sc;jsessioni...tegoryId=9
VCDS locator: http://forums.tdiclub.com/showthread.php?t=296841 |
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Mon Oct 29, 2018 2:39 pm Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
Let me know if that rental doesn't work out, I have all the tools too. My brother should be done with my spare cable by then. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Mon Oct 29, 2018 2:43 pm Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
Dave,
I have the following:
MN3036 Universal Sprocket Buster
MN3034 A3/B4 TDI Crank Lock
MN3418 Universal TDI Cam Plate
Pin for locking IP
PM me if you can use em. |
Posted: Wed Oct 31, 2018 6:33 am Post subject: Re: Looking for diesel ALH timing belt tools and VAGCOM |
HBB wrote: |
VCDS Lite won't work--it doesn't have the "basic settings" mode that allows for checking injection timing, which is the main reason you need the software. |
Good to know. I've never needed that functionality, so I never looked to see if it was there. |
