i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Tue Oct 30, 2018 7:00 pm Post subject: Pop pop pop...pop...pop that's the sound I hear |
Stock 2000cc type 4 engine, 1.8 heads, dual webers...in a bus
I rebuilt the webers and put them back on, I got the engine started and tried.balancing the carbs...
I use a flow meter. When I got the flow/idle set then adjusted the mixture if I wrap.the throttle real quick then engine responds as it should but when the idle should come back to normal it drops down low and struggles to stay idling...or it comes back to idle but has a low deep popping noise, like fuel igniting in the exhaust.
Anyone have any troubleshooting steps or theories on what it might be[/b] |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Wed Oct 31, 2018 3:12 am Post subject: Re: Pop pop pop...pop...pop that's the sound I hear |
Idle mixture screws. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Wed Oct 31, 2018 6:22 am Post subject: Re: Pop pop pop...pop...pop that's the sound I hear |
Float level
Dirt in the fuel metering valves. _________________ Ancient vehicles and vessels
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Wed Oct 31, 2018 6:32 am Post subject: Re: Pop pop pop...pop...pop that's the sound I hear |
idle too lean on whichever cylinder is popping |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Oct 31, 2018 1:30 pm Post subject: Re: Pop pop pop...pop...pop that's the sound I hear |
Check fuel pressure. No more than 3.5 max _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
