NOS window rubber seals
Srecko
Srecko is offline
PostPosted: Fri Nov 02, 2018 1:10 am    Post subject: NOS window rubber seals Reply with quote
Does anyone know where I can find a set of NOS window rubber seals? I am finding the new seals from WW and WCM are too large in profile and don't sit well.
If anyone has a set of NOS seals please let me know. Thank you
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Fri Nov 02, 2018 6:16 am    Post subject: Re: NOS window rubber seals Reply with quote
Try with vewib ... nos rubbers often are old rubbers
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
Erik G
Erik G is offline
PostPosted: Fri Nov 02, 2018 9:43 am    Post subject: Re: NOS window rubber seals Reply with quote
in my opinion, thats actually one thing you don't want NOS. That and brake parts with rubber. It breaks down over time
laneven28
laneven28 is offline
PostPosted: Fri Nov 02, 2018 5:40 pm    Post subject: Re: NOS window rubber seals Reply with quote
Agreed - you don't want NOS. After having the same problems as you with WW seals, I found these and they worked great:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C24-113-845-121-A
No kit, you have to buy each seal individually. The difference between WW and these was night and day.
1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop
Srecko
Srecko is offline
PostPosted: Fri Nov 02, 2018 6:40 pm    Post subject: Re: NOS window rubber seals Reply with quote
Thank you yeah I've ordered a set from CIP1, i'll see how they fare.
lzamora
lzamora is offline
PostPosted: Thu Nov 15, 2018 10:44 pm    Post subject: Re: NOS window rubber seals Reply with quote
Just received a front and rear set of seals from CIP1. Question, when installing the seals on the glass does the seam where the rubbers are glued together go at the center bottom or center top of both front windshiel and Oval rear glass?
Thanks Louie
aa390392
aa390392 is offline
PostPosted: Fri Nov 16, 2018 9:05 am    Post subject: Re: NOS window rubber seals Reply with quote
Srecko, Izamora good luck to both of you.let us know how it goes
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
