TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Jan 19, 2019 1:51 pm Post subject: Re: iMohr on a Early Bay |
tristessa wrote: |
TomWesty wrote: |
Will either of them work for stock ride height without losing ground clearance? |
While the original question is a good one, the part I added in bold is also relevant I think, Depending on what you're doing, stock ride height may not be much good if the lowest point of the suspension is 2-3" off the pavement... |
Excellent point. Or in my case an inch off the rocks and sagebrush. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
BlueWeasel Samba Member
Joined: February 07, 2018 Posts: 29 Location: Bellaire, TX
Posted: Mon Jan 21, 2019 1:44 pm Post subject: Re: iMohr on a Early Bay |
I don't see why standard height couldn't be maintained. It's a bolt in replacement. You simply pick the bolt holes you wish to use. |
Posted: Mon Jan 21, 2019 6:24 pm Post subject: Re: iMohr on a Early Bay |
Since I have a ‘71 and would want to retain my current brakes and spindles, I would go with Imohr. But I’m staying stock for now. Incidentally, within seconds of looking at the Imhor I was able to determine I could maintain stock ride height. Not so with Red9 Design. Also, R9D business is for sale and that would make me nervous regarding future support. _________________ If you haven't bled on them, you haven't worked on them.
metahacker Samba Member
Posted: Wed Jan 23, 2019 2:30 am Post subject: Re: iMohr on a Early Bay |
I've seen some iMohr pics from actual installs that were scary (unsafe, poor quality, life-threateningly terrifying)
poor man's Mendeola or Red9 it would seem
good I'm theory but I'm not sure it's quite up to TUV standards, so to speak |
Posted: Wed Jan 23, 2019 2:42 am Post subject: Re: iMohr on a Early Bay |
and i mean crimped(!!!!) parts, bad welds, metal on metal moving parts, crooked misaligned geometry, high school hack job quality stuff... the CAD models look nice though
Posted: Wed Jan 23, 2019 6:12 am Post subject: Re: iMohr on a Early Bay |
metahacker wrote: |
and i mean crimped(!!!!) parts, bad welds, metal on metal moving parts, crooked misaligned geometry, high school back job quality stuff... the CAD models look nice though |
Yikes!, got pictures? _________________ If you haven't bled on them, you haven't worked on them.
Posted: Fri Jan 25, 2019 8:22 pm Post subject: Re: iMohr on a Early Bay |
After discovering unisteer.com a few nights ago I've realized that for ~$500 more than what Red9 charges for just the beam upgrade I can get a narrowed, adjustable beam, front and rear disc brakes, drop spindles and rack and pinion steering... |
Posted: Mon Jan 28, 2019 11:00 pm Post subject: Re: iMohr on a Early Bay |
TomWesty wrote: |
metahacker wrote: |
and i mean crimped(!!!!) parts, bad welds, metal on metal moving parts, crooked misaligned geometry, high school hack job quality stuff... the CAD models look nice though |
Yikes!, got pictures? |
from their website
that part just looks foolish
a lot of the stuff looks kinda great in pics but i dunno if i trust them |
Posted: Mon Jan 28, 2019 11:02 pm Post subject: Re: iMohr on a Early Bay |
BlueWeasel wrote: |
what does unisteer have for VW? |
Posted: Tue Jan 29, 2019 6:00 am Post subject: Re: iMohr on a Early Bay |
Nothing by default I suspect. I've not really had a chance to look at all of the distance, angles, and options in depth.
Like the iMohr product, I assume that a steering / bevel box will need to be used. Then my assumption is that it's just a matter of getting the correct length inner tie rods to connect everything (Once getting it mounted in the correct location).
This is one of many things that I've got months to think about and can come back to some other time...and/or find a better solution along the way. |
