Replica Kubelwagen. New project
Page: Previous  1, 2
sinclair
sinclair is offline
PostPosted: Wed May 26, 2021 12:42 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
I'll be following this one as its local Very Happy
Randers
Randers is offline
PostPosted: Tue Aug 03, 2021 4:00 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Blimey what a rigmarole putting up photos.
Been a while since last post, things have got underway nicely. Lots made and lots done. Here is result so far. More photos to show how it got this far coming later. Engine is 1200 ex Wehrmacht industrial.
Randers
Randers is offline
PostPosted: Tue Aug 03, 2021 4:01 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Randers
Randers is offline
PostPosted: Tue Aug 03, 2021 4:08 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Randers
Randers is offline
PostPosted: Tue Aug 03, 2021 4:12 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Raised spindles my way, loads of work... handy being a machinist.
nshaddox
nshaddox is offline
PostPosted: Tue Aug 03, 2021 4:38 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Super cool spindles. Thanks for sharing.
Neil
Randers
Randers is offline
PostPosted: Tue Aug 03, 2021 11:52 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Thank you. Whilst I did some considerable planning to make them, most of what was done is a result of overcoming and finding solutions to the next snag that arose. Good lessons.
Randers
Randers is offline
PostPosted: Wed Aug 04, 2021 12:00 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
More pictures of the raised spindles. Basically using itself to machine itself.
ralphd
ralphd is offline
PostPosted: Wed Aug 04, 2021 8:36 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
VERY cool work! Thanks for sharing. I'm needing to do this. Tried beam adjusters this summer and it didn't get close. I have a '59 bus gear reduction ready to install. Thanks so much for the pics!
Porsche 356 Super 90
Porsche 356 Normal
Replica Kubelwagen mit MG34
73 Type 181 Thing
Oval, 36hp und nichts anderes
Randers
Randers is offline
PostPosted: Wed Aug 04, 2021 8:59 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
I have a 1960 bus transmission. In a previous post here I mentioned it needed narrowing. However, it does not.
Any other photos you need for reference or inspiration please let me know. Currently working on crossmember, it's mounts and engine tray. Getting back into sheetmetalwork. 🤯
D-train
D-train is offline
PostPosted: Fri Aug 06, 2021 9:41 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
This is rad! Those spindles and RGB work is epic!
I have Tyre envy too now, so they come in a 600-15?
shiny paint doesnt make it worth any more
Randers
Randers is offline
PostPosted: Sun Aug 08, 2021 3:20 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Tyres are 16". Made the wheels from centres of some repro 15" smoothies and Rover 16" x 4" spacesaver outside rims.
Bit of a pain job and extremely noisy on lathe. Turned out well and ultimately worth the grief.
petrol punk
petrol punk is offline
PostPosted: Mon Aug 16, 2021 5:41 pm    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Wow those spindles are interesting. It looks like you cut the spud off a ball joint spindle and welded on a link pin spud, then bolted/welded the hybrid spindle to a cut up link pin spindle. Is that the case? Very creative, I made some BJ lift spindles by cutting and welding up multiple BJ spindles but never thought of doing something similar to create a pseudo-barndoor spindle for a link pin beam.
36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma
Randers
Randers is offline
PostPosted: Tue Aug 17, 2021 2:05 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Petrol Punk, made from 4 link pin spindles in the end. I did cut down a ball joint spindle down for its spud but I encountered a problem that I cannot remember. Might be its length or not enough remaining material to on it work with. The extra bit on bottom that houses a bush and a short king pin was to beef it up a bit as I thought it looked a bit weak. The result nice as it looks a bit more like it should.
The whole thing was a bit of learn while doing, making the best of what you are given or have got.
vintagemx0
vintagemx0 is offline
PostPosted: Thu Aug 19, 2021 10:13 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Very nice work. Did you fabricate the front beam, or is it original? I also see it appears that lever shocks will be used on the rear end. Amazing attention to detail.
Where ever you go, there you are.
Randers
Randers is offline
PostPosted: Thu Aug 19, 2021 10:56 am    Post subject: Re: Replica Kubelwagen. New project Reply with quote
Vintagemx0, before I reply, I would like to thank you for your sharing of photos during your replica build. Very useful and very much an inspiration to do my own. Really good work.
Front beam is a 1960 bug, I cut the shocker towers off and just fabricated new ones. Adapted arm for short shocker too. Not sure what to do there yet but told a Bombardier snowmobil shocker can suffice. Yes, lever arm shockers going on, went for readily available (here in UK) off an MG B. Just had to extend arms.
Page: Previous  1, 2
Page 2 of 2
