Dead 1 Samba Member
Joined: October 31, 2005 Posts: 1374 Location: Burning shores of Lake Michigan
Posted: Mon Nov 05, 2018 11:23 am Post subject: 71 ignition switch electrical question |
Pardon me if I missed the answer out there in samba land. Im trying to remove the little round switch from the lock cylinder. Is it as simple as yanking it out? I removed a small little screw in the ignition cylinder and tried to pull out the old switch with no luck. Any ideas? _________________ "I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Mon Nov 05, 2018 1:07 pm Post subject: Re: 71 ignition switch electrical question |
There are four 6mm phillips head screws holding the steering column, remove those. The column will shift aft and now you can look up and see the lock assembly. There's a small, straight slot set screw to remove with a jewelers screwdriver. At this point the electrical side of the switch can be pulled towards the drivers side. It's tough, but can be done. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Dead 1 Samba Member
Posted: Mon Nov 05, 2018 3:05 pm Post subject: Re: 71 ignition switch electrical question |
Thank you. I’ll giver another try _________________ "I reject your reality and replace it with my own"
71, 1776 cc. |
SGKent Samba Member
Dead 1 Samba Member
Posted: Mon Nov 05, 2018 4:23 pm Post subject: Re: 71 ignition switch electrical question |
Perfect. Thank you very much. _________________ "I reject your reality and replace it with my own"
71, 1776 cc. |
