Reef_slacker Samba Member
Posted: Mon Nov 05, 2018 9:56 pm Post subject: Pictures of Inside a BN4 Fuel Pump |
I did somthing bad to my BN4 fuel pump.
Turns out the fuel pump is crimped shut and not serviceable (I had read this on the BN4 sticky but you can't believe what you read on the internet). So when I tried to unscrew it I broke the leads and got my self an open circuit. I found a lack of pictures of this part 221261467 disassembled. I hope someone sees this and just soaks it in WD40 overnight instead of wrenching on it.
Body of Thing Heater fuel pump disassembled.
Piston of BN4 fuel pump.
O-ring size to have on hand for when I open it up again in 50 years because I try and "fix" it again.
I think the top of the piston is non-conductive.
The dumb wires I broke.
Is this reading healthy?
I took more measurments, comment if your interested in more on this post or more posts like it. Also comment if you are not interested. |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Thu Nov 08, 2018 8:06 pm Post subject: Re: Pictures of Inside a BN4 Fuel Pump |
Hopefully you got it working again. I bought a new one for a modern heater as an experiment in case my old one quits, hopefully I'll never have to try it. |
Posted: Thu Nov 08, 2018 10:31 pm Post subject: Re: Pictures of Inside a BN4 Fuel Pump |
Yes sir, got it fired up today after work. I had to clean the points on the fan motor to get the pump to run correctly. I did have one small scare with a backfire during testing from turning it off and on. |
KAmes Samba Member
Posted: Fri Nov 09, 2018 5:38 am Post subject: Re: Pictures of Inside a BN4 Fuel Pump |
Cool! The backfires are always a surprise, never seems to hurt anything though. |
