jsirhc22 Samba Member
Joined: February 23, 2018 Posts: 46 Location: san diego
Posted: Wed Nov 07, 2018 4:59 pm Post subject: taking off rusted exhaust |
Basically the title speaks for itself here. have some icing right under the carb and wanted to clean out the heat risers as best as i can (via wire and drill method) without taking it out of the car. the only problem is the exhaust. thing is rusted to shit and i’m afraid that if i try and unbolt it from the heat risers something is going to snap or it’s just not going to come off. am i going to need a new exhaust or just some new hardware to reinstall it? i would try and buy a nicer og exhaust to replace it with but currently going back to school so money is tight. thanks in advance!
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Wed Nov 07, 2018 6:52 pm Post subject: Re: taking off rusted exhaust |
Breaking off those rusty bolts and studs is a distinct possibility with a VW exhaust system. Replacing the bolts is not a big deal, but replacing a stud certainly is. Regardless of what you do, you'll have to take it off at some stage to replace the exhaust.
While you are contemplating doing something, I would just hit each of those bolts with penetrating oil and repeat if for a couple of weeks, then try and work one bolt or stud at a time to see if they come loose.
The phenomenon of icing is over-dramatisised by many. Unless the car is really playing up and you live in a real cold climate (which SD I think is not?) you can buy some time before you rip into it and start shearing off studs and bolts. |
Posted: Wed Nov 07, 2018 7:12 pm Post subject: Re: taking off rusted exhaust |
viiking wrote: |
yeah it’s pretty warm here but the intake is like ice cold and the car stumbles/ almost dies on me out of first gear but the other gears are fine. unless you have any other suggestions on what the issue could be? |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Wed Nov 07, 2018 7:30 pm Post subject: Re: taking off rusted exhaust |
that muffler doesnt look like its coming off intact....the 12mm rabbit exhaust lock nuts arent going to make it any easier...i'd sooner pull the generator and stand and remove the intake manifold itself...cause if you cant get it unclogged its coming off anyway...does it have a stock air cleaner with functional preheat tube....cause that may help warm the air up enough for you to get by for now |
Posted: Wed Nov 07, 2018 7:47 pm Post subject: Re: taking off rusted exhaust |
volksworld wrote: |
yeah it’s got the stock air cleaner. i’m not sure how to takeoff the generator and the stand or the fan shroud if that has to come out too. is it an easy job to do or does it get pretty complicated? |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4416 Location: Stuck in Ohio
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Wed Nov 07, 2018 11:26 pm Post subject: Re: taking off rusted exhaust |
That severely rusted exhaust may not survive the operation.
Liberally apply PB to dissolve the rust on threads, then torch heat 'em (but don't even think about re-use). Some intense prayer might help on behalf of the muffler. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Thu Nov 08, 2018 6:12 am Post subject: Re: taking off rusted exhaust |
jsirhc22 wrote: |
volksworld wrote: |
I've found that you have to loosen the fan shroud, but not remove it. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Thu Nov 08, 2018 6:57 am Post subject: Re: taking off rusted exhaust |
When I remove an exhaust I don't fool around with trying to 'save' the nuts. I go straight to the air chisel and split them along the sides. Since taking this approach I have never broken a stud.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
gt1953 Samba Member
Posted: Thu Nov 08, 2018 7:21 am Post subject: Re: taking off rusted exhaust |
Soak them and soak them again. As mentioned for weeks. Then heat the bageebers out of them, glowing red hot. Engine removal if possible will most definitely make the job way easier then in the car. The big fear is the nuts on the cylinder head. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Nov 08, 2018 8:04 am Post subject: Re: taking off rusted exhaust |
Yeah that job is gonna suck.
In the future when putting it back together with new hardware, use copper anti-seize on all the threads.
The muffler clamps and hardware are available as "muffler installation kits" so replace those; doubtful the old ones are coming off in one piece. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
hotsam Samba Member
Joined: December 02, 2015 Posts: 366 Location: Ashburn, VA
Posted: Thu Nov 08, 2018 8:46 am Post subject: Re: taking off rusted exhaust |
runamoc wrote: |
I agree on this approach - though I might chisel them off by hand.
Basically you want to chisel them so they split enough that the nut releases itself from the threads. _________________ 1968 Beetle |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Thu Nov 08, 2018 9:38 am Post subject: Re: taking off rusted exhaust |
GM sells a penetrating oil that is vastly superior to others.
This stuff is the best - hands down. Has never failed me.
Genuine GM Fluid 88862628 Rust Penetrant and Inhibitor - 11 oz. https://www.amazon.com/dp/B00BK7MLKE/ref=cm_sw_r_cp_api_i_8xg5Bb2NSYZHN _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
bluebus86 Banned
Posted: Thu Nov 08, 2018 9:41 am Post subject: Re: taking off rusted exhaust |
Heat from a torch can do wonders on jobs like this. Id be inclined to replace the studs, one pictured is pretty rusty. If the head threads get messed up, an oversized step stud can be utilized.
Bug On my rusty muffler friend! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Thu Nov 08, 2018 10:48 am Post subject: Re: taking off rusted exhaust |
The VW machine shop repaired my cylinder studs correctly 1.5 years ago.
About mid-1990s Mrs. Cusser had backed into a parking block and tore off the exhaust in my 1971; all four rear cylinder studs broke off when I tried to remove the nuts (yes, even in Arizona), never broke a stud on any, even when I was wrenching on these for a job in 1974-1975. So I lowered the engine a few inches, drilled them out as straight as I could, and re-tapped to 8.0mm x 1.25mm, and those held. Machine shop made them perfect again.
Now I use brass nuts there on both my engines. However I did look up air chisels, they are not expensive; but my air compressor is only 3 gallon, so might be marginal, but might work for occasional air chisel use. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Thu Nov 08, 2018 12:11 pm Post subject: Re: taking off rusted exhaust |
I like to take a wire tooth brush/wire wheel, and remove as much rust as I can. Then start applying penetrating oil daily for about a week, usualy works... _________________ foam cowboy hats aren't good helmets. |
Posted: Thu Nov 08, 2018 1:05 pm Post subject: Re: taking off rusted exhaust |
Quote: |
Basically you want to chisel them so they split enough that the nut releases itself from the threads. |
Yes. That will do the trick. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1379 Location: Wichita, KS
Posted: Thu Nov 08, 2018 2:18 pm Post subject: Re: taking off rusted exhaust |
Really rusty stuff like exhaust fasteners and hardware, I like using the combination of heat, penetrating oil, and patience/persistence.
Wire brush loose whatever rust you can off the outside areas first. Then use a torch to heat up the fastener and/or joint area (to a dark/dull red level or so, for steel stuff), and afterwards let completely cool. Repeat that cycle a couple-few times -- the heating expansion & cooling contraction movement helps to crack and "crunch-up" the brittle solid rust areas. Then soak area with a good penetrating oil (e.g. "Kroil" or similar) for suitable length of time -- i.e. few minutes to overnight -- before trying to wrench on the parts / fasteners. If still frozen solid together, repeat the heating and oiling cycle, and try again...
If you have the time and patience for this process, have found that it nearly always works in the end. Splitting the nuts (as others mention above) may be faster though, especially if you're in a hurry or don't have lots of time to spare. Good luck to you! _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Fri Nov 09, 2018 9:18 am Post subject: Re: taking off rusted exhaust |
runamoc wrote: |
i feel like this is the best option for me. why take the chance if i’m using new hardware anyways. i don’t have an air compressor sadly so do you think a little rotary tool and then a hand chisel would do the job? |
Posted: Fri Nov 09, 2018 10:43 am Post subject: Re: taking off rusted exhaust |
Yes, score the side of the nut some, then put the chisel in the scoreline and give it some whacks. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
