I'm a bonehead
i_luv_my_bus76
i_luv_my_bus76 is offline
PostPosted: Thu Nov 08, 2018 4:30 pm    Post subject: I'm a bonehead Reply with quote
While building my engine I ruined my straight cut timing gear that goes on the crankshaft. I was wondering if I could just buy that one or do I need to buy the set?
ach60 Premium Member
ach60 is offline
PostPosted: Thu Nov 08, 2018 4:56 pm    Post subject: Re: I'm a bonehead Reply with quote
Call your vendor that you purchased the gear set from.
These gear sets are not matched, so it's just a matter of your vendor taking pity on you.
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
i_luv_my_bus76
PostPosted: Thu Nov 08, 2018 7:01 pm    Post subject: Re: I'm a bonehead Reply with quote
I bought it online about 5 months ago...
They allowed me to do a warranty claim
nsracing
nsracing is offline
PostPosted: Sat Nov 10, 2018 4:19 am    Post subject: Re: I'm a bonehead Reply with quote
So how did you manage to mangle the gear in the first place?
How big was the sledgehammer you used? Very Happy
The American dream is alive for those unversed in the ideology of victimhood. - Thomas Sowell
This summer I am offering machining/balancing work. Engine builds - PM me.
madmike
madmike is offline
PostPosted: Sat Nov 10, 2018 4:41 am    Post subject: Re: I'm a bonehead Reply with quote
I bet he cracked it ,,,,like i did once,,, Embarassed Rolling Eyes Laughing
65 Baja
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag bug 1915 or 2276 'Turbo'
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's
i_luv_my_bus76
PostPosted: Sat Nov 10, 2018 8:35 am    Post subject: Re: I'm a bonehead Reply with quote
Didn't get to the sledge...
I have built engines in the past, and always said I'll never make this mistake...
i forgot to install the bearing that goes on before the gear. When I went to pull it off with my puller it came off cock eyed and marred up the inner portion of the gear badly, but surprisingly no damage to the crank (which is awesome, it's a new 76mm counterweight $$$$$)... when I get off work I'll send some pics. I was able to swap it out just have to wait until the new one comes to finish the crank
i_luv_my_bus76
PostPosted: Sat Nov 10, 2018 8:37 am    Post subject: Re: I'm a bonehead Reply with quote
No cracks...but thought I had
i_luv_my_bus76
PostPosted: Sat Nov 10, 2018 9:47 pm    Post subject: Re: I'm a bonehead Reply with quote
nsracing
nsracing is offline
PostPosted: Mon Nov 12, 2018 7:11 am    Post subject: Re: I'm a bonehead Reply with quote
You get that type of damage from putting it in crooked, not removal. If it went on clean, you will not end up w/ a burr like that.
An easier way to put on a gear is to heat the item. I just use a torch - hold the item with a pair of pliers and just flame the outside few minutes. Just warm it up. NOT BLUE! Then just flop the gear on the nose. It drops down on its own weight. If not, just tap with a drift and it goes on.
For pulling, I use a hydraulic puller. I damaged an old Berg puller so I just use the plate w/ the hydraulic puller. It is clean, strong and pulls it nicely.
mark tucker
mark tucker is offline
PostPosted: Mon Nov 12, 2018 7:37 am    Post subject: Re: I'm a bonehead Reply with quote
many people justuse a 60-100watt lightbulb, put the gear on it for 5-10 min then it slips on. or a old hot plate.or use the coffie maker to heat it. do beat it on ,dont use a press. it's eazy to effup the spindly crankeshaftem thingy too.
nsracing
nsracing is offline
PostPosted: Mon Nov 12, 2018 10:14 am    Post subject: Re: I'm a bonehead Reply with quote
Won't a torch be way cheaper and quicker? And you don't even have to risk being electrocuted. Laughing
Tucker is fancy for sure.
[email protected]
john@aircooled.net is offline
PostPosted: Mon Nov 12, 2018 12:09 pm    Post subject: Re: I'm a bonehead Reply with quote
Welcome to the club. As you get older this sort of situation is called "experience". I have a lot of "experience".
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
i_luv_my_bus76
PostPosted: Mon Nov 12, 2018 12:15 pm    Post subject: Re: I'm a bonehead Reply with quote
I appreciate that...
I beat myself up pretty bad about what I did. Thank you for the encouragement
mark tucker
PostPosted: Mon Nov 12, 2018 12:19 pm    Post subject: Re: I'm a bonehead Reply with quote
I could see somebody with a torch getting the gear red hot....and then a effed up engine.I have also used heat gun.( witch is my way of doing it.I aint in no hurry like nick. and I may just need my hair dried too. beware when heating the gear or any thing at all it may be hot.
nsracing
nsracing is offline
PostPosted: Wed Nov 14, 2018 2:46 pm    Post subject: Re: I'm a bonehead Reply with quote
It is not gonna get hurt if you over-cook it. It is not a hardened part at all.
A minute/s or so with a torch is plenty. A torch is very nice to warm things up in winter. I use it to warm the pistons when I assembling the pin into it in winter builds. Very Happy
I also torch parts a little to dry them up quickly in winter after a wash, if I don't have time to wait around waiting all day to dry up. Works really good...on rocker/valvetrain parts and things.
try it man. Just don't burn down your house.
kwarloc
kwarloc is offline
PostPosted: Wed Nov 14, 2018 11:13 pm    Post subject: Re: I'm a bonehead Reply with quote
i just wrapped my crank in a towel and let it chill in the fridge w/ the soda's & beer for about 30. then i warmed the gears (w/ dinner) in the oven for about 15... dropped right in w/ ease
Max Welton
Max Welton is offline
PostPosted: Thu Nov 15, 2018 6:46 pm    Post subject: Re: I'm a bonehead Reply with quote
I use a cheap little toaster oven to warm up the gear and some leather gloves. Doesn't take all that much heat and it will drop on easy.
Never thought to use it for pistons. Huh.
Max
nsracing
nsracing is offline
PostPosted: Thu Nov 15, 2018 6:54 pm    Post subject: Re: I'm a bonehead Reply with quote
Torch is awesome on pistons in winter. Just get them warm above 70 deg and the pins slide in easy.
modok
modok is offline
PostPosted: Thu Nov 15, 2018 7:10 pm    Post subject: Re: I'm a bonehead Reply with quote
Toaster ovens are 20$ at wallmart.
you have no excuse for now getting one. it's cheaper than a torch. A good torch and MAP gas bottle your looking at 50$ min
nsracing
nsracing is offline
PostPosted: Thu Nov 15, 2018 7:35 pm    Post subject: Re: I'm a bonehead Reply with quote
Can a toaster oven do copper pipes? Very Happy
Or, or thaw out something in the middle of a field?
It is hard to beat a propane torch - one of the best all around tools.
