Zundfolge1432 Samba Member
Posted: Mon Nov 12, 2018 9:16 am Post subject: Re: Troubles removing engine, no clearance for tools? |
Glenn wrote: |
Abscate wrote: |
Snap on or MACK pricey but works of art |
S/K are professional level and much cheaper than Snap-On.
Only if you buy them at full retail. Unknown to most but Snappy and Mac offer discounts up to 55% off to students and then there are the other outlets. I’ve purchased much of my tooling used for pennies on the dollar, reference “What did you see” in off topic.
Who in their right mind pays full retail for anything ? Wife and I shop around for everything and use coupons, any advantage available I’ll use it. Yesterday many retailers here honored veterans so I got a free haircut, Starbucks, dinner at Olive Garden. If someone was handing out 20 dollar bills would you accept one?
Looks like mine is bigger hmmmmmm
Last edited by Zundfolge1432 on Mon Nov 12, 2018 9:36 am; edited 1 time in total |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Nov 12, 2018 9:19 am Post subject: Re: Troubles removing engine, no clearance for tools? |
I bought most of my tools online and they were drop shipped from a warehouse. One place that I purchased a lot from I spoke to the salesman and he told me it's a house in the suburbs of Vegas and there are 4 that work out of it. They have no inventory and everything is shipped from multiple locations.
Pawn shops are also a good source. All of my air tools came from a pawn shop and are K/D, Mac or Snap On. _________________ Glenn
Member #1009
#BlueSquare |
Buzzerbug74 Samba Member
Posted: Mon Nov 12, 2018 9:20 am Post subject: Re: Troubles removing engine, no clearance for tools? |
Mine was out easy as pie! Just got underneath, used the 17mm wrench and they broke loose easy. It also helped that I cut my rear apron for a quicker removal (it was rusted and bondo heaven, I have a replacement)
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Nov 12, 2018 4:32 pm Post subject: Re: Troubles removing engine, no clearance for tools? |
I have a set of wobble extensions from Harbor Freight - handy !!!
My 1970 has a 1971 engine case/doghouse, and I now use a metric allen head bolt (from Ace Hardware) on that upper left location which takes an 8mm hex bit; someone here suggested that.
10mm x 1.5mm x 70mm _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
lookphoto Samba Member
Posted: Wed Nov 14, 2018 2:20 pm Post subject: Re: Troubles removing engine, no clearance for tools? |
https://www.harborfreight.com/8-piece-metric-offset-box-wrench-set-32042.html
Not really brand specific, but these provide a great angle to get those two bottom bolts. I actually put them back in tonight, and was able to tighten down both from the driver's side without getting completely under the vehicle. Just reached in and got plenty of torque without rounding.
17mm ratcheting wrench for the starter D-Bolt nut. 17mm deep socket for the top left bolt.[/quote]
Ding ding ding! For anyone that stumbles across this thread and is having issues or needs motivation, this answer was spot on. Highly recommend this set to anyone removing their engine. Far far easier than using a standard offset wrench. |
Cusser Samba Member
Posted: Wed Nov 14, 2018 4:15 pm Post subject: Re: Troubles removing engine, no clearance for tools? |
lookphoto wrote: |
So we assume that you now have the engine out of the VW ??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
