njstein Samba Member
Posted: Sun Nov 11, 2018 8:10 pm Post subject: Wrong light socket for back-up lights? |
My stock ('69) back-up lights were so dim that I couldn't see anything behind me, so I figured I would swap out for some brighter LEDs. A quick check in the manual confirmed I needed 1073's, so I bought a pair of 1156's. Taking off the lens, I see that there are dual filament bulbs in there and only one filament is lit (explains the dim lights) -- the socket is double contact, which doesn't jive with the lights described in the manual. Were there any years with double contact reverse lights? Can I use an 1142 (dual contact monofilament) in there instead of changing bases? |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
Posted: Mon Nov 12, 2018 2:52 am Post subject: Re: Wrong light socket for back-up lights? |
Welcome to the Samba...
What you described seems odd, so I’m wondering if your 69 is actually an early MY 1970? with the reversing lights in the tail light housing....like this...
or does have the elliptical shape tail lights it like 60’s Ghia usually have? Then your reversing lights are on the bumpers like so..
I know the reversing lights on the bumpers are only single pole. I’d also expect the same with the integral lights the 70. Possibly yours have been modified. Perhaps they are dim because the two filaments have been connected in series somehow.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Mon Nov 12, 2018 8:57 am Post subject: Re: Wrong light socket for back-up lights? |
Get a pair of 1157 or 2057 bulbs (2057 are brighter 1157's) and connect your one wire in the backup light socket that 'works' to the 'brake' light side of the bulb. Brighter already without a lot of changing and buying new stuff. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Mon Nov 12, 2018 5:04 pm Post subject: Re: Wrong light socket for back-up lights? |
sputnick60 wrote: |
or does have the elliptical shape tail lights it like 60’s Ghia usually have? Then your reversing lights are on the bumpers like so |
It's definitely a 69 (has a 149 vin number) with the oval all-red tail lights and the separate chrome back-up lights mounted to the bumper, like the black ghia in your second picture.
Here is a pic of the reverse light housing. You can see the dual contact socket in the back.
runamoc - jumpering the two terminals sounds like a solid idea. I'll give that a shot. |
Posted: Mon Nov 12, 2018 5:52 pm Post subject: Re: Wrong light socket for back-up lights? |
njstein wrote: |
sputnick60 wrote: |
the method from runamoc is a good workaround.
I can see in your photo how it's been modified with some other socket in there. It you want to go back to original its possible to these find reflectors on their own in the classifieds. I think the bus and 356 ones are slightly different across the back and might not fit in the housing.
https://www.thesamba.com/vw/classifieds/search.php...ton=Search
