Westaru Samba Member
Posted: Mon Nov 12, 2018 8:13 pm Post subject: Bike rack that works with rear spare tire carrier/trays |
I currently have a tray style bike rack (Kuat) that I've used for several years across a wide range of vehicles. I realized this weekend that it would not work well with my Vanagon due to interference with the Rocky Mountain Westy tire carrier and cargo tray. I can carry only one bike in the farthest slot from the bumper.
Is anyone aware of a good bike rack, tray or otherwise that would allow me to carry at least 2 bikes?
Thanks in advance, _________________ 1984 'Westaru' Vanagon Westfalia EJ22
@UtahWestfalia on IG |
redrocksteady Samba Member
Joined: May 22, 2017 Posts: 31 Location: Sedona, Arizona
Posted: Mon Nov 12, 2018 8:30 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
I wonder if a hitch swing arm would not only push your kuat rack out far enough to accommodate, but also give you the ability to swing out your rack for easy hatch access? _________________ 1989 2WD Vanagon Westfaila Wolfram Grey |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Mon Nov 12, 2018 10:25 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
redrocksteady wrote: |
I wonder if a hitch swing arm would not only push your kuat rack out far enough to accommodate, but also give you the ability to swing out your rack for easy hatch access? |
^^^ https://rakattach.com
Also, OP, have you considered carrying your bikes in a more vertical position like this GW set up: https://www.gowesty.com/product/bike-racks/23892/yakima-front-loader-upright-bike-rack?v=
I imagine you could fit these to your RMW setup. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
jimf909 Samba Member
Posted: Mon Nov 12, 2018 10:42 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
I noodled this one for months, maybe a year. I've got a Kuat rack that I wanted to use. Rack-Attach swing out, Kuat swing-out (made by Rack Attach), various extensions, etc, etc. None allowed easy access to the hatch or didn't block the taillights.
I landed on 1Up bike racks mounted to an RMW swing out with the RMW Switch back attachment. It's a darn good solution for my needs. 1Up bike racks are very well designed and executed (relatively simple and no plastics).
FWIW, YMMV. _________________ - Jim
Abscate wrote: |
Posted: Mon Nov 12, 2018 11:27 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
^^^ Slick! Are those 1Up "Roof Racks" (flush mount) or ??? _________________ 1990 Multivan - "Ohana"
Posted: Tue Nov 13, 2018 2:39 am Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
Yes, those are two 1Up flush mount roof racks. I was concerned about using them in a vertical orientation and used two back-ups to ensure that I wouldn't lose the bikes in front of other vehicles while driving down the road. After a summer I became confident enough in the rack design that I only use one back-up (a cable lock connecting the bike to the RMW swing-out, if the 1UP fails which seems unlikely, the bikes are still locked to the van).
https://www.1up-usa.com/product/roof-rack/
There a few videos that help explain how they work...
https://www.google.com/search?client=safari&hl...M3_SQ0LO_M _________________ - Jim
Abscate wrote: |
Timwhy Samba Member
Posted: Tue Nov 13, 2018 3:50 am Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
the Utahn wrote: |
Thanks in advance, |
I use this Yakima rack that is made for four bikes and they can position outward from the back.
You could try a hitch extender?
https://www.harborfreight.com/12-in-hitch-extender-69882.html _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
kourt Samba Member
Joined: August 13, 2013 Posts: 1941 Location: Austin, TX
Posted: Tue Nov 13, 2018 5:24 am Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
Just buy a hitch extender. Dozens of companies make them. I have RMW trays and use my old hitch mount Thule bike rack with them just fine. This is an easy problem to overcome.
kourt |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3795 Location: VA/TN
Posted: Tue Nov 13, 2018 6:33 am Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
jimf909 wrote: |
FWIW, YMMV. |
^^ Siiick! I think you sold me on this RMW setup. For the LONGEST time - I thought most of the swing aways were built into the bumper (I'm thinking GoWesty setup).
I regret buying my GoWesty 2" hitch so much right now.
Edit: Wow. This looks like a winter project for sure.
_________________ Brandon
Instagram @joannthevan |
benandmj Samba Member
Joined: October 29, 2012 Posts: 550 Location: Atlanta
Posted: Tue Nov 13, 2018 9:52 am Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
I'm a big fan of 1up as well. I have no problem clearing my gowesty spare with my big ass 29er.
I had a similar swing away setup that held up well and allowed for access to the back of the van.
I ended up not staggering the bikes and used a longer yakima bar. _________________ 85 Westfalia Weekender
91 Syncro Westy |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Nov 13, 2018 2:12 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
kourt wrote: |
kourt |
Was going to say this. I saw one on the side of the road one time and picked it up. I don't think I have ever used it, except to bolt my toilet seat to.
You can buy hitch tighteners that kind of pull the hitch up a little to keep it from banging around. Using one of those would keep it from sagging as much. Here is one example:
https://www.amazon.com/SAUNICE-Tightener-Anti-Ratt...&psc=1
Can't really see the hitch extender very well in this pic, but it's humorous.
_________________ Dave Cook
1973 Wild Westerner
My Thing |
izzydog Samba Member
Posted: Tue Nov 13, 2018 10:55 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
+1 on the hitch extender. Harbor Fright has them super cheap. |
Posted: Wed Nov 14, 2018 5:56 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
Thank you all for the input... I feel a bit silly not thinking about a hitch extender, and it appears that Kuat even makes one now:
http://www.kuatracks.com/products/accessories/
Between that and the hitch tightener I should be good.
I will say that if I had to do it again, I might look at the 1up rack as I really like the way it slopes upwards to maintain ground clearance. For those of you with a 1up, does it accomodate road bikes as well? Is it adjustable for kids / smaller bikes?
The RWM switchback attachment is pretty awesome with the 1up racks. _________________ 1984 'Westaru' Vanagon Westfalia EJ22
Posted: Wed Nov 14, 2018 6:53 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
I have a 1 Up. Best rack I've ever owned and that includes Yakima and Thule. There's no plastic to break or breakdown in the sun and yes...it fits road bikes really well.
Kid's bikes? I don't see any photos of kid's bikes on the 1 Up site. Maybe give them a ring. |
kourt Samba Member
Posted: Wed Nov 14, 2018 7:08 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
Here's the old Thule rack with an extender, and the RMW tray deployed. This was just this past weekend on the Texas coast.
kourt |
Posted: Wed Nov 14, 2018 9:30 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
izzydog wrote: |
Agreed. Give them a call, they’re friendly folks from small town Wisconsin. _________________ - Jim
Abscate wrote: |
Posted: Wed Nov 14, 2018 9:43 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
shagginwagon83 wrote: |
I regret buying my GoWesty 2" hitch so much right now. |
Don’t regret it too much. I bought one, used it a year and then realized it wouldn’t work with the Bostig. I put the hitch on CL and the dude who came to buy it not only paid my asking price but he also bought my 2.1 wbx. Best CL buyer ever!
That pic brings back memories. I installed the RMW swing outs and switch back racks during the final weeks of recovery from a knee replacement. It was a fun project to do in a gimpy, pain-med addled mindset during beautiful spring days away from work.
RMW sells a great product and sends it out remarkably well-packaged with great instructions. The install was entirely straightforward. _________________ - Jim
Abscate wrote: |
scavengers Samba Member
Joined: June 24, 2018 Posts: 21 Location: Portland, OR
Posted: Sun Feb 09, 2020 12:40 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
benandmj wrote: |
I ended up not staggering the bikes and used a longer yakima bar. |
@benandmj what is the rack system you were using here? _________________ 1990 Vanagon GL Westfalia AT 2.3 |
Timwhy Samba Member
Posted: Sun Feb 09, 2020 1:08 pm Post subject: Re: Bike rack that works with rear spare tire carrier/trays |
scavengers wrote: |
benandmj wrote: |
@benandmj what is the rack system you were using here? |
I’m 99% certain those are GW swingouts mounted on the GW bumpers.
As for the bike mounts, they look like a version of Yalkima Boa. The crappy trademark Yakima faded red button on the rear mount is a giveaway.
https://www.rackattack.com/bike-racks/roof-mount-bike-racks/yakima-boa/ _________________ - Jim
Abscate wrote: |
