Lincolnlife Samba Member
Joined: January 24, 2018 Posts: 26 Location: Winston salem
Posted: Tue Nov 13, 2018 3:13 pm Post subject: Fan bolt |
Im trying to take off my altenator because on of the wires in side has became disconnected. Was just going to pull it off solder them back. I cant for the life of me get the fan bolt inside the shroud out. It is so tight it broke the key off the pully on front. Is it special thread? I can get to it and can crank on it but its stuck. I took a pic. Any help id love.
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Nov 13, 2018 3:18 pm Post subject: Re: Fan bolt |
Jam a large screw driver into the blades while you have it on the ground and use it as leverage. It will take some effort as it’s supoosed to be torqued to 50lbs or so and has probably corroded. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
ghia4mea Samba Member
Joined: July 23, 2007 Posts: 478 Location: Largo Florida
Posted: Tue Nov 13, 2018 3:21 pm Post subject: Re: Fan bolt |
This is no help to you but my Ghia had the same problem. It took a huge breaker bar and a destroyed alternator before the bolt would come loose.
We first destroyed the key then the alt. My mechanic (a retired vw mechanic) had never seen one so bad. |
KTPhil Samba Member
Posted: Tue Nov 13, 2018 3:43 pm Post subject: Re: Fan bolt |
Is the engine out? If so, use an impact gun to loosen the nut. This will lessen the need to hold the fan/alt in place, damaging one or both of them.
Some good penetrant (liquid wrench, not WD-40) can help. |
Posted: Tue Nov 13, 2018 4:07 pm Post subject: Re: Fan bolt |
No its in the car. I need a good way to hold the front as well. Like i said the key sheard off so the pully just turns on the alternator just turns. I will try the impach. Thought about welding a nut on the alternator shaft but idk if that would fry it. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Nov 13, 2018 4:20 pm Post subject: Re: Fan bolt |
Lincolnlife wrote: |
Get another woodruff key, put the pulley back on, and use a screwdriver jammed in the slot against an alternator bolt like when you tighten a fan belt.
That big nut should - and I say "should" - be only torqued to 43 ft lbs. But many don't understand stuff like that !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Nov 13, 2018 4:27 pm Post subject: Re: Fan bolt |
I will get a key. When i did the jamed screw driver it started to bend the pully. This things tight. Lol |
Cusser Samba Member
Posted: Tue Nov 13, 2018 5:01 pm Post subject: Re: Fan bolt |
I understand. Some previous owner could've used red Loctite and a zillion foot pounds on it. Would be really sad if a real mechanic did something like that.
You might need to remove the fan shroud and the alternator/fan from that and secure in a bench vise, and sacrifice the bad alternator or the pulley anyway. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Nov 13, 2018 5:04 pm Post subject: Re: Fan bolt |
Ok. I saw 2 bolts on left and right of the shroud. Is there any on the back? Feel like there should be a few holding it on |
bugheadred Samba Member
Posted: Tue Nov 13, 2018 6:04 pm Post subject: Re: Fan bolt |
Sharp64 wrote: |
Jam a large screw driver into the blades while you have it on the ground and use it as leverage. It will take some effort as it’s supoosed to be torqued to 50lbs or so and has probably corroded. |
you will bend the fins DONT DO IT |
Posted: Tue Nov 13, 2018 6:17 pm Post subject: Re: Fan bolt |
[email protected] wrote: |
Sharp64 wrote: |
I’ve used this method several times and it works. But the unit has to be out of the car. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
anthracitedub Samba Member
Yeah, don’t ever jam a screw driver in anything...get a little bottle torch and heat the nut, it’ll come off... I just got done taking two of these off of very rusty, nasty looking 6v generators and I’m recovering from broken hand surgery...still got them off with a ratchet. |
Cusser Samba Member
Posted: Tue Nov 13, 2018 6:30 pm Post subject: Re: Fan bolt |
Disclaimer: I've only worked on VW engines with generators....
For fan shroud removal: Yes, two (originally) slot head 6.0mm x 1.0mm screws on each side (called cheese head screws). The alternator strap holds the alternator to the stand securely, that needs to be loosened and slid forward to clear the stand. If a doghouse cooler, the tins on the front (hidden side) must be removed (10mm wrench). And the accelerator cable needs to be removed from the metal tube through the fan shroud. Plus, if you have a thermostat attached, that must be removed from the thermostat rod. Plus all the wires, so label those (of course disconnect the battery negative cable first). I've typically also had to remove the carburetor. And if attempting this with engine still in the VW, mark the lid brackets and remove the engine lid.
I've found that using an impact wrench just makes it spin if the shaft isn't secured somehow. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Nov 13, 2018 6:36 pm Post subject: Re: Fan bolt |
Sharp64 wrote: |
Sharp64 wrote: |
I’ve used this method several times and it works. But the unit has to be out of the car. |
ok so you have done it before (is it the right way to do it NO ) why would you give advice to someone looking for help ? unless it is the way you should do it and maybe cause damage to the fan also . then he will need a fan and an alt. |
Posted: Tue Nov 13, 2018 6:48 pm Post subject: Re: Fan bolt |
Sharp64 wrote: |
Sharp64 wrote: |
The way I have done it I have yet to damage a fan. But as I said it has to be out of the car. Not everyone has a torch or impact wrench. You make do.
And if I have to make a choice between a $20 fan or a $350 generator....
What’s your method besides critiquing mine? Let’s not be negative. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Tue Nov 13, 2018 7:10 pm Post subject: Re: Fan bolt |
350.00 for a alt? where do you get them ? |
Posted: Tue Nov 13, 2018 7:36 pm Post subject: Re: Fan bolt |
90mm 12volt generators aren’t cheap. $250 plus another hundred for a rebuild. I also have a second that I bought already rebuilt for over $400. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Tue Nov 13, 2018 7:48 pm Post subject: Re: Fan bolt |
Sharp64 wrote: |
90mm 12volt generators aren’t cheap. $250 plus another hundred for a rebuild. I also have a second that I bought already rebuilt for over $400. |
wow he don't even have a gen. if you would read it is an alt and it don't matter sticking a screw driver in the fan wont work and it is just a stupid thing to do im done |
Posted: Tue Nov 13, 2018 8:07 pm Post subject: Re: Fan bolt |
Sharp64 wrote: |
They are both held on with a 30mm nut on the fan side aren’t they? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Tue Nov 13, 2018 9:47 pm Post subject: Re: Fan bolt |
Remove the alternator/fan assembly from the engine (just saying "out of the car" isn't really good enough. it needs to be removed from the fan shroud) and the fan can be held in such a way to allow the NUT (it ain't a bolt) to be removed.
The proper torque is 40 to 47 foot pounds - that's not a terrible lot. Now if someone used an impact gun to put the nut on then it might be a lot more than that. But that is overkill, and I take the time use a torque wrench and do it right.
Now, trying to get the nut loose when the alternator/generator is still installed on the engine? Uh, don't bother, it's not supposed to be attempted that way. _________________ Andy T.
