"Postal" HIGH TOPS in Canada?
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
dobryan
dobryan is offline
PostPosted: Thu Dec 27, 2018 3:07 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Ed, I cannot stand in an AW hightop and the sleeping area is too low for me to feel comfortable. But ymmv.
Dave O
The West Coast Westy
epowell
epowell is offline
PostPosted: Thu Dec 27, 2018 5:07 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Looks to me like the AW is about 6 inches lower than the JOKER. In my JOKER I can stand and have more than 6 inches head room. Dave, how tall are you?
Yeah, the AW seems pretty low and probably not so good for regular sleeping. . . that's what people say.
....unless the upper bunk bed could be made slightly lower. I know that my 'lower bunk' could be about 6 inches lower, and some vans even have shelves above the lower bunk... > so the might be designed to make the upper bunk lower > BUT actually the space is limited because of the windows.
www.edwardpowell.com
dobryan
dobryan is offline
PostPosted: Thu Dec 27, 2018 5:52 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
I am 6’ 4”
and my head bumps
on the AW when I stand inside. No good for me...
Dave O
ZsZ
ZsZ is offline
PostPosted: Fri Dec 28, 2018 6:17 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
keep in mind that in a converted van the bed sits about 10cms higher as the tintop roof is curved and the bed is above that, while in a Westfalia the whole roof panel is cut out
Zoltan
1.9 MTdi Multivan (ex Caravelle)
Van since 2006, engine since 2008
dobryan
dobryan is offline
PostPosted: Fri Dec 28, 2018 6:25 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
^^^ and that would make an AW even worse for sleeping head room.
Dave O
epowell
epowell is offline
PostPosted: Fri Dec 28, 2018 7:45 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Yes, but that is going on the assumption that the rear part of the tintop is not cut out. It's my understanding that removal of that rear section of tintop is optional, no? ...or with an AW hightop is it structurally necessary to leave that portion of the tintop intact?
mikemtnbike
mikemtnbike is offline
PostPosted: Fri Dec 28, 2018 7:53 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Ed- you can't cut out the rear part to my knowledge. The C pillar roof brace is structural. In a factory hightop like your Eurobus, it and the D pillar roof brace are replaced with a flat, lower bar. The hole you'll cut is confined between the B and C pillar roof braces.
1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie"
In an abundance of water, the fool is thirsty.
epowell
epowell is offline
PostPosted: Fri Dec 28, 2018 7:56 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
But this AW from a BayBus looks pretty spacious up top! Maybe AW made higher tops for BayBuses?
epowell
epowell is offline
PostPosted: Fri Dec 28, 2018 8:02 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
OK, ...but then what are these people doing?
dobryan
dobryan is offline
PostPosted: Fri Dec 28, 2018 8:32 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Looks like they are trying to add back the structural strength they removed.
Dave O
mikemtnbike
PostPosted: Fri Dec 28, 2018 8:38 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
TRYING being the operative word.
Ed- what I'm describing is the difference between the hole-only westfauxlia conversion I did and the whole roof graft method when moving a pop-top to a tintop- the pictures of people cutting the roof off at the pillars, or taking all the spot welds out, to move the Westy roof over. Looking at some of the threads about pop-top conversions will probably make it clearer
NAHT hightops like jim's do the b-c pillar hole only.
dbcdad
dbcdad is offline
PostPosted: Fri Dec 28, 2018 9:45 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
epowell wrote:
....or this one and convert - just buy the whole van.
https://www.kijiji.ca/v-classic-cars/nelson/1972-v...nFlag=true
http://fiberine.com/GVMR/Home.html
This is the co I bought from for one of my vans.
Have Fun, David C
ZsZ
ZsZ is offline
PostPosted: Fri Dec 28, 2018 9:46 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
in the original VW hightop design the crossmember is changed to an upside down U shaped structural frame around the shape of the roof.
And the longitudinal roof frame is a closed cavity not just an L shaped beam like on the tintops
cutting the crossmember without making new structural beam is not good.
In the german camper conversion book they advise using box steel frames to make bigger holes in the roof
Zoltan
epowell
epowell is offline
PostPosted: Fri Dec 28, 2018 11:56 am    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
OK, so this basically means that if I want to do a basic tintop conversion to hightop without fabbing up some major extra supports, then I should count on NOT cutting out the rear section of roof. ...then this means that if I want to sleep up there for sure an AW won't be tall enough.
But this begs another question: Since the AW is an aftermarket conversion, then all vans with an AW top also still have the original rear section of tintop? This means that when Dave tested sleeping in the AW it was not only too cramped because of the low height of the top but ALSO because of the curve of the original tintop? >>> so this might suggest that if one can figure out a way to cut out that entire rear roof section and SUPPORT IT, then add the AW, this AW would have an extra 6 inches of sleeping space then a standard AW setup?
mikemtnbike
PostPosted: Fri Dec 28, 2018 12:17 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
As the Atlantic could be delivered as a pretty sweet double walled, insulated hightop, I'd wonder if your 3rd photo above may be how the factory did extended bracing. If that's so, you could try to replicate that framework, modified to the AW...but man, that seems like an awful lot of effort/expense. I'd be looking at the NAHT and it's ample headroom waaaaay before that- even if, like me, you don't find the NAHT lines as visually appealing.
dobryan
dobryan is offline
PostPosted: Fri Dec 28, 2018 1:36 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
How do you an extra 6”? I think you only get about 2”.
Dave O
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Dec 28, 2018 2:25 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
I have both type vans here, factory Westfalia flat steel and factory arched steel with a small hole cut for the installed Westy poptop.
The difference is 3" higher metal for the peak of the arch.
I have cut the full size hole on other vans by cutting out most of the arch and bridging with a doubled 1" square tubing piece slid inside both of the end stubs of the arch. This is far from rocket science. The fixed plywood bed section bolts to the remaining lip of the sheet metal all around the perimeter of the new hole, mounted below the sheet metal to keep it lower and to give a better appearance to the "headliner". A piece of 1" angle steel bolted to the 1" tubes supports the front edge of the new fixed bed board.
Mark
epowell
epowell is offline
PostPosted: Fri Dec 28, 2018 6:59 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Mark
Thanks Mark
3 inches is a lot! ...I would love to see some pics of the process you just described.
joetiger Premium Member
joetiger is offline
PostPosted: Thu Jan 10, 2019 2:46 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Ed,
The Holy Grail is on Ebay.de right now for VERY cheap...SCA poptop Hightop:
https://www.ebay.de/itm/223309472561
Git it!
Joe T.
'86 NAHT Vanagon GL Syncro/ supercharged ABA 2.0
'85 928S
'19 Golf R
'02 Beetle GLS
epowell
epowell is offline
PostPosted: Thu Jan 10, 2019 4:29 pm    Post subject: Re: "Postal" HIGH TOPS in Canada? Reply with quote
Thanks so much! ...however this is in Germany > I need one in Canada Sad
Page 5 of 7
