1/4" axial play in crankshaft! Type 2 '65 1500
tsimek2
tsimek2 is offline
PostPosted: Thu Nov 15, 2018 3:44 am    Post subject: 1/4" axial play in crankshaft! Type 2 '65 1500 Reply with quote
I'm definitely a noob, when it comes to VW engines. I pick up a Dune Buggy to rebuild.
When I opened up the case the Crank Shaft was sheared.
The case has an "H" stamped on it, which tells me it's a Type 2 '65 Early Bus 1500. I get a crankshaft for that.
I also got new bearings.
When I put everything in the case, the bearings are solid and locked in, I get about 1/4" play in the axial direction of the crank shaft.
Nothing is on but the bearings and crankshaft.
This seems like a problem to me.
Any help would be great.
FreeBug
FreeBug is offline
PostPosted: Thu Nov 15, 2018 4:03 am    Post subject: Re: 1/4" axial play in crankshaft! Type 2 '65 1500 Reply with quote
Do you have the flywheel on?
tsimek2
tsimek2 is offline
PostPosted: Thu Nov 15, 2018 4:18 am    Post subject: Re: 1/4" axial play in crankshaft! Type 2 '65 1500 Reply with quote
I don't have the flywheel on. I still need to get one of those.
FreeBug
FreeBug is offline
PostPosted: Thu Nov 15, 2018 4:49 am    Post subject: Re: 1/4" axial play in crankshaft! Type 2 '65 1500 Reply with quote
The flywheel and 3 shims are what set the axial play. 0.07-0.13 mm.
tsimek2
tsimek2 is offline
PostPosted: Thu Nov 15, 2018 4:50 am    Post subject: Re: 1/4" axial play in crankshaft! Type 2 '65 1500 Reply with quote
EXCELLENT!!! Thank you So much!!!
