4 Position Headlight Switch?
thefladge
thefladge is offline
PostPosted: Thu Nov 15, 2018 9:50 am    Post subject: 4 Position Headlight Switch? Reply with quote
I'm wondering if anyone here is using a 4 position headlight switch typically sold for hot rods and kit cars.
It's a single pull out style switch that activates the high beams when pulled all the way out.
The switch would eliminate the need for the floor mounted high beam switch.
I'm looking for advice from someone using the switch.
Does it work well? Are there any problems?
Thanks.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
heywebonya
heywebonya is offline
PostPosted: Thu Nov 15, 2018 10:18 am    Post subject: Re: 4 Position Headlight Switch? Reply with quote
Why not install a floor switch? Cheap and easy - plus young people don't know what is is for.
If I knew what I was doing; I wouldn't be building a buggy!
thefladge
PostPosted: Thu Nov 15, 2018 10:26 am    Post subject: Re: 4 Position Headlight Switch? Reply with quote
The question is concerning a 4 position headlight switch.
Thank you.
TSFR
TSFR is offline
PostPosted: Thu Nov 15, 2018 11:59 am    Post subject: Re: 4 Position Headlight Switch? Reply with quote
I had one in my first buggy and it worked, but there was no flashing the highbeams. It was a good option for what it was and made wiring easy to where I didn't use relays. If you are not a high beam flasher type of person then its a solid solution. Also it seems to be a better switch than the cheap pull switches that are sold at the local parts stores.
Thanks,
Jeff
Manxter 2+2 #160
EVfun
EVfun is online now
PostPosted: Thu Nov 15, 2018 12:06 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
I'm using one in my beach buggy that I bought from Speedway Motors. It works fine but would be less fun if I was switching between low and high beams all the time. If I switched back and forth more I would be temped to wire low beams as all the way out (position 4) and high beams and position 3, making it a quick flick to switch to low beams.
The terminals on the switch are simple enough.
1. Power in
2. ON in positions 2, 3, and 4 (tail lights)
3. ON in position 2 (front parking lights)
4. ON in position 3 (low beam)
5. ON in position 4 (high beam)
Wildthings wrote:
thefladge
PostPosted: Thu Nov 15, 2018 1:29 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
Thanks.
If I go with this switch I might hook it up so the front running lights stay on with the headlights.
MrGoodtunes
MrGoodtunes is offline
PostPosted: Thu Nov 15, 2018 4:11 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
thefladge wrote:
... I might hook it up so the front running lights stay on with the headlights.
That was the way I went at first, but... on long drives at night, especially with brights, my headlight switch would get awfully HOT (stock 1967 bug switch). So I changed it to the more conventional, lower amperage hook up.
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Thu Nov 15, 2018 4:24 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
Headlights should be hooked up through a relay (one for low and another for high beam) - don't use the switched to directly turn them on and off as the switch won't last long.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
thefladge
PostPosted: Thu Nov 15, 2018 11:21 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
I think you're right. Adding relays is a good idea. There are no relays with the stock switches currently in the car.
slalombuggy
slalombuggy is offline
PostPosted: Fri Nov 16, 2018 9:08 am    Post subject: Re: 4 Position Headlight Switch? Reply with quote
When I build a car I use 2 relays for the lights.
One relay powers up all the park lights and a pair of fog lamps that are on all the time when the ignition is on.
A second relay powers a 30amp (@120V) DPDT toggle switch that I use to control the headlights that I mount so it switches vertically on the dash. High beam is up, low beam is down.
I also use a toggle for the signal lights, but that's another story.
brad
EVfun
EVfun is online now
PostPosted: Sat Nov 17, 2018 3:35 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
I've been using the 4 position switch from Speedway Motors without any relays for several years. The contacts, at least on positions 3 and 4, seem to be of sufficient size to handle standard H4 halogen headlamps just fine.
There is nothing special about a relay that makes it better than a switch. Either way works equally well if you have contacts sized for the current involved. Relays can be used.to reduce wiring length as wire has resistance, or they can allow you to use a small low power switch. Sometimes they are used to allow the use of an old switch with failing contacts.
Wildthings wrote:
thefladge
PostPosted: Sat Nov 17, 2018 9:48 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
Is this the one you use?
https://www.speedwaymotors.com/Speedway-Universal-Headlight-Switch-with-Hi-Low,41767.html
EVfun
EVfun is online now
PostPosted: Sun Nov 18, 2018 8:33 am    Post subject: Re: 4 Position Headlight Switch? Reply with quote
That is the one I used, I remember that ugly brown knob. Speedway offers a nice aluminum knob to replace it, that I also bought.
Wildthings wrote:
Makua Kane
Makua Kane is offline
PostPosted: Tue Nov 20, 2018 1:04 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
brad
I've been looking to do this exact thing with my buggy. Is there a wiring diagram that I can reference?
thefladge
PostPosted: Wed Nov 28, 2018 3:23 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
I ordered a 4 position headlight switch today. I will follow up with the results after I install it.
thefladge
PostPosted: Mon Dec 10, 2018 10:01 pm    Post subject: Re: 4 Position Headlight Switch? Reply with quote
Installed.
