EmpiGT Samba Member
Posted: Thu Nov 15, 2018 11:03 am Post subject: Anyone running a straight axle split case trans? |
For my build I was going to run a 1776 with a later set up. But just scored a full okrasa set up and was thinking about keeping the vintage vibe with a split case and lowered. But on long hauls I may put the 1776 in. Anyone think the non rgb split case can handle a bus and or a 1776? |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Sat Nov 17, 2018 2:44 pm Post subject: Re: Anyone running a straight axle split case trans? |
EmpiGT wrote: |
are we talking a later say 59-60 split case? i would be interested in knowing the answer to your question. I have seen barndoor trannies with 50hp 1600dps to motivate a BD camper, and i have seen that tranny replaced with a tunnel case.
if i had to do it i would not worry about a later split case, i always felt they were just about indestructable when used by adults _________________ regards
Uli
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
EmpiGT Samba Member
Posted: Wed Nov 21, 2018 9:41 am Post subject: Re: Anyone running a straight axle split case trans? |
Sorry for the late reply. I posted in the split bus forums as well. From replies over there it seems to work fine depending on driving style. So I'm going to do this in mine as well. One guy said use a later 58-59 split case for more strength in it. I didn't know there was a stronger split case? |
Posted: Thu Nov 22, 2018 5:56 am Post subject: Re: Anyone running a straight axle split case trans? |
There was a change on the main shaft. Minor but may help. You could look in Progressive Refinements and see when it actually occurred. I honestly don’t think it will make a difference. You are not drag racing with 100’s of hp. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
