water tight, dual 40mm air cleaner setup?
62kellison
62kellison is offline
PostPosted: Fri Nov 16, 2018 9:12 am    Post subject: water tight, dual 40mm air cleaner setup? Reply with quote
I have dual 40mm "webers".anyone have any ideas on a water tight carb filter/housing/snorkel. So that I am not sucking rain or tire puddle backsplash into my carbs?.i do NOT want to snorkl it into the buggys rear bench/seat area.do they make something or do I need to create something?.thanks Sean....Ps.I have a lot of room between top of dual carbs and buggy body I have a 3inch lift.something LIKE THIS?
62kellison
PostPosted: Fri Nov 16, 2018 9:13 am    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
I found that pic online don't know where I would find something like this for dual "webers 40mm"
cbeck
cbeck is offline
PostPosted: Fri Nov 16, 2018 12:16 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
Appletree [email protected]
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
W1K1
W1K1 is offline
PostPosted: Fri Nov 16, 2018 12:28 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
CB has the carb hats for turbo applications
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
W1K1
W1K1 is offline
PostPosted: Fri Nov 16, 2018 12:30 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
1973 super
weasel_ugs
weasel_ugs is offline
PostPosted: Sun Nov 18, 2018 10:33 am    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
W1K1 wrote:
Wrong link? Blueprinting an engine?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Nov 18, 2018 10:39 am    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
CSP makes a central filter.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
oprn
oprn is offline
PostPosted: Sun Nov 18, 2018 2:15 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
Did you check the price Glenn?
Letterman7
Letterman7 is offline
PostPosted: Sun Nov 18, 2018 2:29 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
Shocked yow.... that's quite the investment...
62kellison
PostPosted: Sun Nov 18, 2018 2:56 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
wow that's nice,afraid to look up the price.but that's what I need.thanks for ideas guys....Sean..
62kellison
PostPosted: Sun Nov 18, 2018 3:04 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
wow!!!! holy shit $1000 bucks for an air cleaner Shocked
oprn
oprn is offline
PostPosted: Mon Nov 19, 2018 5:50 am    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
Ya - more like $1500 Canadian dollars! Then what if it's too bulky to fit under my Buggy body?
62kellison
PostPosted: Mon Nov 19, 2018 8:25 am    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
I really like that CSP setup.BUT I think that's a little unreasonable. Idea IT does give me ideas for using turbo covers.Then plumb them into an airbox from a vehicle in the salvage yard or a reasonably priced airbox online...Sean..
W1K1
W1K1 is offline
PostPosted: Mon Nov 19, 2018 10:56 am    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
if you want to get creative, and like DIY projects, mine started with a chunk of pink styrofoam, a flat air filter for a buick 6 cylinder, and a plastic basket from the dollar store. Add a pile of hours pondering, figuring, sanding and fiberglassing.
1973 super
Letterman7
PostPosted: Mon Nov 19, 2018 12:58 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
^ Wow! Clean build!
62kellison
PostPosted: Mon Nov 19, 2018 2:39 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
W1K1 ,now that's nice.and that is something I can do.thanks for showing it!!...SEAN....
oprn
oprn is offline
PostPosted: Mon Nov 19, 2018 6:27 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
Nice work!
W1K1
W1K1 is offline
PostPosted: Fri Nov 23, 2018 2:43 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
the original i built was a little more crude, but used 2.5" oval exhaust tubing and the bottom of a T3 air cleaner. It didn't flow as free as I wanted. So i opted for the fiberglass route. The nice thing about the pink foam is it dissolves with acetone so you build a buck and wrap it with glass and melt the buck out.
1973 super
oprn
oprn is offline
PostPosted: Fri Nov 23, 2018 5:24 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
What kind of resin are you using? Epoxy or polyester? My experience with polyester is that it melts foam.
oprn
oprn is offline
PostPosted: Fri Nov 23, 2018 5:25 pm    Post subject: Re: water tight, dual 40mm air cleaner setup? Reply with quote
