Jmtr Samba Member
Posted: Fri Nov 16, 2018 7:34 pm Post subject: Type IV in 1970 Bus. |
I have been searching Google and The Samba for information on putting a 2056 Type IV from a 914 in a pre 1972 Bus but can't find anything helpful, so I thought I should ask the experts. I know the engine tin is different but not sure if the sheetmetal in the engine compartment pre Type IV era can be made to fit.
Thanks. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Nov 16, 2018 10:00 pm Post subject: Re: Type IV in 1970 Bus. |
Well, I’ve gone one direction but not the other.
Pause.... xvevin?
Just kidding but I’ve put an older engine in a newer bus but never a newer engine in an older bus. They should bolt up as far as engine mating with transmission. Don’t know how the rear hanger would work or the tin. They make conversion tin but I’ve never seen T4 in a T1 bus. I have seen them in a Baja bug but those leave off a lot of tin. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Jmtr Samba Member
Posted: Fri Nov 16, 2018 11:34 pm Post subject: Re: Type IV in 1970 Bus. |
That's mostly what I saw as well, T1's in T4's but not the other way around. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
SGKent Samba Member
Posted: Sat Nov 17, 2018 12:28 am Post subject: Re: Type IV in 1970 Bus. |
let us know how it goes once you price T4 parts. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Xevin Samba Member
Posted: Sat Nov 17, 2018 1:17 am Post subject: Re: Type IV in 1970 Bus. |
I dunno. Maybe seek out Joe Cali
https://vwparts.aircooled.net/Type-4-Upright-Conve...manual.htm _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Bagger04 Samba Member
Joined: August 03, 2015 Posts: 33 Location: Port Huron, Michigan
Posted: Sat Nov 17, 2018 7:25 am Post subject: Re: Type IV in 1970 Bus. |
Spike0180 bought a 70 with a 1700 type iv in it. Maybe he will chime in with some insite. He changed his back to type 1 |
Bleyseng Samba Member
Posted: Sat Nov 17, 2018 8:52 am Post subject: Re: Type IV in 1970 Bus. |
Get the DTM kit for the upright fan kit. You will need a 210mm flywheel as the 914 one won't work. You have to pull out the spacer in the crank and install the little bearing, the main cylinder tin will have to be cut to fit the engine compartment seal as you will need to keep the tin with the different sparkplug holes. Yes, the sparkplugs location are way different than a bus type 4. Keep the dizzy as it is the best for the engine. What carbs are you going with or are you keeping the Djet fuel injection? I am sure keeping the Djet would be the best. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Jmtr Samba Member
Posted: Sat Nov 17, 2018 11:19 am Post subject: Re: Type IV in 1970 Bus. |
I have considered the DTM kit but this engine is finished and didn't want to drill into the case for the alternator stand. If I use the Bus engine tin I would weld up the spark plug holes and drill new ones.
From searching images it looks like the engine compartment is much different from those that came with the type IV. Does the engine compartment sheetmetal that surrounds the engine tin unbolt? Some pictures I have seen look like it does. |
airschooled Air-Schooled
Posted: Sat Nov 17, 2018 2:25 pm Post subject: Re: Type IV in 1970 Bus. |
I see a few hurdles here too. I don't man to sound like a Debbie Downer!
Type 4's are wider and require cutting on 68-71 buses just to fit. Type 4's need a 5/8" longer input shaft in the transaxle. The engine hangers will have to be fabricated to use the early bay ears. (Plus side of that is that can have two sets of rubber engine mounts, and that would be ultra-smooth!) You'll have to cut the Type 1 air filter stand off, but please do it carefully because folks need them for restorations.
What do you mean about the spark plug holes? Type 4 in an early bay doesn't require any mods in that department. The engine itself is too wide, tin or not, so the engine compartment metal on the car has to be cut. I do not remember if the removable rear apron (!) on early bays needs to be cut.
Robbie
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Jmtr Samba Member
Posted: Sat Nov 17, 2018 3:02 pm Post subject: Re: Type IV in 1970 Bus. |
Thanks for the info Robbie, just what I was looking for. The reference to the spark plug holes was for the engine tin. I think different engine size Type IV's have the spark plug holes in a different spot than a 914 2.0
It sounds like I should just find a bus that uses a Type IV. |
Posted: Sat Nov 17, 2018 3:17 pm Post subject: Re: Type IV in 1970 Bus. |
The 914 heads have a different intake bolt pattern, but I don’t think they had different plug angles...
EDIT: They do! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Nov 17, 2018 3:47 pm Post subject: Re: Type IV in 1970 Bus. |
Jmtr wrote: |
It doesn't. Not only that- there's a different trans mount at the rear of the trans on a Type 4 that you MUST have.
If you're hell bent on doing this I'd get a rusty 1972- on donor bus and cut all the relevant sheet metal for the engine compartment, etc. out and weld it into your bus, along with the middle driveline mount.
I'd also upgrade the braking system and the rear suspension/ torsion bars while I was at it- front beam too- not to mention the trans.
There was a company years ago called FAT performance that sold a Type 1 conversion kit for a Type 4 engine. Even so, the T4 engine is still way heavier and I think would really tax the early original 1600 mounting points. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Jmtr Samba Member
Posted: Sat Nov 17, 2018 5:28 pm Post subject: Re: Type IV in 1970 Bus. |
Thanks for the info. Sounds like it's not worth the hassle. |
Zed999 Samba Member
Posted: Sun Nov 18, 2018 1:59 am Post subject: Re: Type IV in 1970 Bus. |
Jmtr wrote: |
That's just what I did. Unhappy with the T1 cooling I wanted to go T4. When I looked at the air vents, engine mounting and huge difference right around the perimeter of the tinware I sold my 68 and got a 74. The 68 was cute, but the later version is mechanically (running gear) quite a bit better...and the T4 engine slotted in very easily of course. |
soissisc Samba Member
Joined: April 04, 2007 Posts: 636 Location: Western Pennsylvania
Posted: Sun Nov 18, 2018 9:15 am Post subject: Re: Type IV in 1970 Bus. |
I have a type 4 in my 68. I did the Joe Cali upright conversion. I have ran it that way since 02 or 03. There was some Fab work involved but no cutting of body sheet metal or anything. It fit right in there. I ran a 3 rib trans meant for a T 4 ( from a 72 bus) so I did not have any problems with input shaft length or anything. The trans is showing signs of rebuild time in it's near future (whirring sound in first gear) so I am in process of going back to a stock T1 set up.
It was a fun project back then that gave our family a lot of fun and reliable trips. We are a family of 6 and we carried a lot of stuff on trips and even pulled a small trailer to haul all of the kids stuff. But everyone is getting older and in college / working, and more of them like to drive their own cars on vacation and bring friends etc so less load cruising in the bus so we are going back to stock type 1.
Let me know if you have any questions. I am eventually going to be selling my conversion stuff over the winter as I get everything back to stock. It is all home made per Joe Cali method, but I did work in a tool and die shop so it isn't too terrible for the most part haha.
I would recommend it from experience. _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
raygreenwood Samba Member
Posted: Sun Nov 18, 2018 10:01 am Post subject: Re: Type IV in 1970 Bus. |
asiab3 wrote: |
The 914 heads have a different intake bolt pattern, but I don’t think they had different plug angles... |
Only on the 914 "2.0" liter engine. The intake bolt pattern is different (three bolts on 914 2.0 and four on all others)...the 914 2.0 spark plug angle is very different and the sheet metal with the plug holes are therefore different.
The 914, 411, 412 and bus 1.7 and 1.8 engines and the 2.0 "bus" engines all have the same intake bolt pattern and spark plug angles.
Long time ago I put a 1972 411 engine in a 1971 bus. A lot of little details but its not that hard. I also put in a later trans so I did not have shaft to flywheel issues...but that,should not be an issue when you install the pilot bearing in the flywheel which is common on most conversions.
The tough part was cutting some sheet metal away....virtually none from the bus bit some of the original 411 sheet metal, bolting up early type 4 rear hanger bar end......and.....I wish,I had pictures of samples of this material.....but I used industrial canvas that had been roll coated with high temp silicone on both sides.
I have no idea,what it,was originally for.....i bought about 3 yards at 50" wide and installed it as make up material between sheet metal and body.....and it worked great!
Lots of ways to do this....some better than others. Ray |
Posted: Sun Nov 18, 2018 1:30 pm Post subject: Re: Type IV in 1970 Bus. |
Thanks for the info Ray, I didn't know the 914 had so many variances.
It's a shame that the two T4-in-early bay conversions I've seen had the engine compartment cut then, if it wasn't necessary. When modifying stuff, always go for the cheapest part first…
Starbucket Samba Member
Posted: Sun Nov 18, 2018 3:07 pm Post subject: Re: Type IV in 1970 Bus. |
raygreenwood wrote: |
asiab3 wrote: |
Where did you buy it? Was it pricy? |
Posted: Sun Nov 18, 2018 3:59 pm Post subject: Re: Type IV in 1970 Bus. |
Starbucket wrote: |
asiab3 wrote: |
I originally bought it.....man this had to be about 1986.....at Texas Rubber supply in Dallas Texas. That is one of those unbelievable rubber supply and hose, hydraulic hose, fuel hose, industrial hose, sheet rubber, die cut, punch cut....you name it shops. Been in business for about 70 years.
https://texasrubbersupply.com
I bought it on a trip to Dallas from OKC with buddy of mine. I was looking for sokething different....and saw that product in a dusty roll and they pulled some out. I think it was about $25 a yard.
About 10 years later....I was living in Dallas and went to TRS all the time for many items....personal and business....and they no longer had that product. I think what I bought,was a remnant from a special order.
But...it was not much different than this product....which is twice as expensive....but twice as good. This is silicone coated fiberglass cloth.
https://www.tarpsnow.com/index.php/32-oz-silicone-...DwQAvD_BwE
Its good to 500°F.....and i am thinking of using it for making a new type of cooling duct to engine shroud connector for 411/412 sedan. Think of more like a "gator"...than a molded boot.
When I installed it around the 411 engine.....I dont think it took more than a strip about a foot wide anywhere around the engine. I used 1/2" or 9/16" canvas snaps. So yes...I had to mainoy bend a little metal on the bus.... the only real mangling to the bus was drilling holes for the 30-40 snaps. I had piles of them at a job I worked.
The bus was straight...but was kind of a beater otherwise. I had been doing the tuning and engine work for the guy who owned it while I was in school. He ran it out of oil and it sat because he had no money. I had a 411 that I got T-boned in. It went to the salvage yard.....without its engine. I put the engine in the bus and drove it for about a year or so.
Ray |
