Posted: Sat Nov 17, 2018 1:54 pm Post subject: Rear torsion bar rust, how much is too much? |
In a recent post a member had a rusty rear torsion bar which he treated with a phosphoric acid product. My question: is a rusty bar suitable for reuse? or does the pitting from the rust render the bar unsuitable for reuse? When I replaced my rear torsion arm bushings a few years back I noticed a small area of paint failure and the accompanying rust on one of the bars and have wondered since if it might lead to a fatigue failure? |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Nov 17, 2018 2:41 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
I wouldn’t think surface rust would cause fatigue failure. If it’s gone deeper then you might have a problem. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
wcfvw69 Samba Purist
Posted: Sat Nov 17, 2018 4:18 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
This would be a great question for a metallurgist. _________________ Contact me at [email protected]
The Samba member since 2004.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Nov 17, 2018 4:54 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
A pit will eventually propagate a crack, how long that will take is a mystery, but when it happens it'll be sudden and possibly catastrophic.
You could grind and sand the pits so they are smooth depressions, remove the sharp corners that are the stress risers and the load is distributed evenly, no cracks (unless one has already started from years of action). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun Nov 18, 2018 1:30 am Post subject: Re: Rear torsion bar rust, how much is too much? |
Without seeing any pictures of the problem area, I would offer this with a grain of salt...
Prepare the pitted area for welding; lay down a bead or two of weld. Build this area back up with steel.
I would say the same wire feed setup one would use for sheet metal work would be appropriate. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sun Nov 18, 2018 10:59 am Post subject: Re: Rear torsion bar rust, how much is too much? |
I'm no metalurgist, but I would be way more wary of a torsion bar that had welding done to it than I would one that had a little surface rust or some gentle grinding (as described above) to get rid of the rust.
I just know that the heat does some funky stuff (that I don't fully understand how it works) to the atomic structure of the metal, and being a type of spring, those things were forged (?) in a special way. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Nov 18, 2018 11:22 am Post subject: Re: Rear torsion bar rust, how much is too much? |
vwwestyman wrote: |
I just know that the heat does some funky stuff (that I don't fully understand how it works) to the atomic structure of the metal, and being a type of spring, those things were forged (?) in a special way. |
Pretty much guaranteed that welding on the bar would cause it to break in short order. |
Just us buses Samba Member
Joined: April 27, 2004 Posts: 195 Location: Where the nuthatch winters
Posted: Sun Nov 18, 2018 11:38 am Post subject: Re: Rear torsion bar rust, how much is too much? |
I know this ain't your first rodeo but my split Bentley says to make sure there are no signs off rust; replace if necessary. Bay Bentley just says to paint any scratches/chips to protect against corrosion. _________________ It doesn't matter where you start, it all comes together; it all falls apart. |
Posted: Sun Nov 18, 2018 11:39 am Post subject: Re: Rear torsion bar rust, how much is too much? |
Yeah, welding (or heat of any kind) is a giant no no.
Think of it like an aircraft propeller, they flex constantly and a scratch or gouge will result in blade loss if left alone. The rule for aviation is dress an area 10X the depth of the divot so it tapers gradually to the lowest point.
For example: http://www.avcanada.ca/forums2/viewtopic.php?f=27&t=101883
You can skip the part about restoring aerodynamic shape, but the rest still applies to any forged metal part under stress and flex. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Nov 18, 2018 12:10 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
I’m sorry! I was thinking of the torsion trailing arm. You guys are referring to the actual spring steel torsion rods?
If so, then absolutely no welding on spring steel at this level. |
SGKent Samba Member
Posted: Sun Nov 18, 2018 1:31 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
I would guess that 99% of the torsion bars have some rust on them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
MorkC68 Samba Member
Joined: December 23, 2015 Posts: 610 Location: Nottingham, England
Posted: Sun Nov 18, 2018 2:32 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
TomWesty wrote: |
I wouldn’t think surface rust would cause fatigue failure. If it’s gone deeper then you might have a problem. |
In my work life, I test metallic materials for the fatigue and tensile properties, anything from a small test coupon to tests on structures such as landing gear components.
Surface rust shouldn't have any effect on the bar but, as suggested, pitting will be a potential source for fatigue failure.
best suggestion would be to rub the rust off and give it a good coat of paint _________________ Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
My blog: https://twolatebays.wordpress.com/ |
Starbucket Samba Member
Posted: Sun Nov 18, 2018 2:58 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
MorkC68 wrote: |
TomWesty wrote: |
X2 I would remove the rust with a rag soaked in White Vinegar over night (and some plastic wrap to keep the vinegar there) or paint it with rust inverter and when it turns black paint it with a rust preventive paint. I wouldn't remove any good metal as that will make that area thinner (like a pull bar) and be the fracture area. |
Posted: Sun Nov 18, 2018 4:16 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
I think I’m confused about which parts are being discussed. I thought originally it was the torsion tube then I thought it was the trailing arm; which was why I made my comment. Then I was thinking we were talking about the stack of bars that make up the torsion assembly.
Somebody help me out please and explain exactly which part are we talking about. Is it the part that is internal and is normally saturated in grease, or is this part of an assembly that is external and usually has some sort of body coating and paint? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22640 Location: NYC/Upstate/ROW
Posted: Sun Nov 18, 2018 4:22 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
It’s a Bay rear torsion bar which is a solid rod with two splined ends, no stack of leaves like the front _________________ .ssS! |
SGKent Samba Member
Posted: Sun Nov 18, 2018 4:24 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
my take is this:
Posted: Sun Nov 18, 2018 4:30 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
Thanks. That’s an area I’ve never ventured.
If the carbon or other non-ferrous make up is higher than what I’d call mild or structural steel (very loose idea here) than I’d not weld on anything like that unless it follows an approved process with normalizing.
I thought for a bit we were talking about external parts that see welding as part of their assembly process. Clearly, we are not. Thank you for the clarification. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Nov 18, 2018 6:43 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
Mine looked like this...
I removed the rust with a wire wheel then painted it with Tremclad paint. That was over ten years ago and many off-road camping trips. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Sun Nov 18, 2018 7:57 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
Well there you go, real life beta testing!
But is there a small crack starting that might let go one day?, who knows?, and how long until it does?
Other than going full NDT on one of yours with all the tools available to see if there's anything starting we'll likely never know. VW said to keep them painted and avoid nicks, how many thousands of hours in a test rig did it take for them to get one to actually snap? Front leaves break regularly, but I've never seen a rear bar broken myself that I can recall.
Either way I'll still follow the recommended protocol, non rusty bars are easy to find if one is too messed up to trust. If I decide to run one that's not up to par and it defys the odds and actually breaks it'll be a major pain in the a** that I could have avoided by just installing a clean one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Nov 18, 2018 9:56 pm Post subject: Re: Rear torsion bar rust, how much is too much? |
busdaddy wrote: |
Either way I'll still follow the recommended protocol, non rusty bars are easy to find if one is too messed up to trust. If I decide to run one that's not up to par and it defys the odds and actually breaks it'll be a major pain in the a** that I could have avoided by just installing a clean one. |
If I had rust-pitted rear torsion bars, I would probably smooth the exterior surface down with my patented insane overuse of a Dremel cutting wheel followed by a desperate effort to sand it smooth smooth smooth, followed by several coats of plastic black paint (suitable for plastic) so that the bar can flex without fracturing or peeling the paint off as would happen with a typical spray can paint. But I have never had a rust-pitted torsion bar . . .
Colin _________________ www.itinerant-air-cooled.com |
