pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Sat Nov 17, 2018 2:27 pm Post subject: Junk Piles |
How do you keep your junk pile?
Score me this steel frame from a friend's new house. Figured it would be a great base for what I've been wanting to do for the longest time... a better and neater storage place for my junk pile which was sitting in, well, a pile, next to the Garaj Mahal and covered up with the cheap bamboo style cover. Here's how it worked out.
Still have to put some shelves in it and finish clearing the pile in the back forty. _________________ Some people are so busy being clever they don't have time enough to be wise. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Nov 17, 2018 3:09 pm Post subject: Re: Junk Piles |
That looks like what most folks around here build for trash & recycle bins.
Not Bear proof, but it would keep the Racoons & Skunks out....
My "Good" Junk gets stored inside:
_________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon
anthracitedub Samba Member
Posted: Sat Nov 17, 2018 3:32 pm Post subject: Re: Junk Piles |
I’m at the age where I try not to own any junk or take on any new junk... it’s all about self control 😁 |
pyrOman Fire Master
Posted: Sat Nov 17, 2018 4:01 pm Post subject: Re: Junk Piles |
Here's what it looked like way back when I first build the deck.
While the "cover" looks good in that picture, this was quite a few years ago and it just didn't look that happy any more.
FWIW, I also have been thinning out the pile as of late. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Nov 17, 2018 8:33 pm Post subject: Re: Junk Piles |
Depending on the 'quality' of your neighborhood, the new container may or may not be the 'best' solution. The bamboo curtain says "I'm covering up worthless junk and garbage that I'm embarrassed about the neighbors seeing" ....the locked, metal and wood enclosure says "I'm protecting some valuable stuff that I don't want to have damaged by the weather, or possibly stolen." Nice work, though!! _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
pyrOman Fire Master
Posted: Sat Nov 17, 2018 9:27 pm Post subject: Re: Junk Piles |
Digger89L wrote: |
Depending on the 'quality' of your neighborhood, the new container may or may not be the 'best' solution. The bamboo curtain says "I'm covering up worthless junk and garbage that I'm embarrassed about the neighbors seeing" ....the locked, metal and wood enclosure says "I'm protecting some valuable stuff that I don't want to have damaged by the weather, or possibly stolen." Nice work, though!! |
You can’t see it even with google earth since it all is in my back yard. Hell, the Garaj Mahal is behind the house!
I spend most of my time in the garage and the back yard. It has to look good for me, not to mention access to my pile which was a pain having to remove the “curtain” to then dig through the pile. It’ll be better organized now. _________________ Some people are so busy being clever they don't have time enough to be wise. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12709 Location: Western Canada
Posted: Sun Nov 18, 2018 6:05 am Post subject: Re: Junk Piles |
Nice Job! Good choice on raising it a bit above ground level as I see you did with the garage and deck too. Far too many such projects are built on grade around here and flood every spring.
I badly need to thin out and re-organize my junk pile too! |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sun Nov 18, 2018 7:28 am Post subject: Re: Junk Piles |
If it is organized inside a big cabinet, is it still a "junk pile?" Still, I like it, and need to do something similar. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
pyrOman Fire Master
Posted: Sun Nov 18, 2018 8:06 am Post subject: Re: Junk Piles |
Q-Dog wrote: |
If it is organized inside a big cabinet, is it still a "junk pile?" Still, I like it, and need to do something similar. |
Well, an organized pile is better than just a pile. And it’s also mostly junk still. Of all the motors I have in there, probably only 2 can be rebuilt. Most have case issues like over machined, pulled threads, and such. I keep them assembled until I need something off of them. Maybe some day I’ll take them apart and store the good parts then get rid of the true junk... maybe some day. _________________ Some people are so busy being clever they don't have time enough to be wise. |
pyrOman Fire Master
Posted: Sun Nov 18, 2018 8:10 am Post subject: Re: Junk Piles |
oprn wrote: |
Nice Job! Good choice on raising it a bit above ground level as I see you did with the garage and deck too. Far too many such projects are built on grade around here and flood every spring. |
Two things, the area is under the little awning of the garage so the dirt there has always stayed dry, and I kept most the pile on top of pallets. _________________ Some people are so busy being clever they don't have time enough to be wise. |
oprn Samba Member
Posted: Sat Nov 24, 2018 6:15 am Post subject: Re: Junk Piles |
pyrOman wrote: |
oprn wrote: |
Two things, the area is under the little awning of the garage so the dirt there has always stayed dry, and I kept most the pile on top of pallets. |
Wouldn't work here, most of our rain arrives sideways! |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sat Nov 24, 2018 10:06 am Post subject: Re: Junk Piles |
How long until you out grow that box? |
pyrOman Fire Master
Posted: Sat Nov 24, 2018 4:33 pm Post subject: Re: Junk Piles |
oprn wrote: |
pyrOman wrote: |
oprn wrote: |
Dwayne1m wrote: |
Again, I'm thinning out as of late! Right now getting things just a bit more organized in my mess.
More room for "wall art".
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Nov 26, 2018 10:13 am Post subject: Re: Junk Piles |
I like your school desk- right there. When I do stuff like that my wife usually asks something like, "Why does this have to be here?" I (closely) reply, "Cause that's it's place- it belongs there." _________________
EverettB wrote: |
FU#5 |
c21darrel Samba Member
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Tue Nov 27, 2018 10:25 am Post subject: Re: Junk Piles |
Wow super nice and tidy pyrOman but I'm 2x on what anthracitedub said. Although I need to learn to just say no to good deal junk and free junk.
anthracitedub wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
