BIGSERG Samba Member
Posted: Sun Nov 18, 2018 8:26 pm Post subject: brake booster help 1974 vw bus westi |
i need help identifying all the vacuum lines on my brake booster. i have a 1974 and one of the vacuum lines is cut off i am assuming its for the valve pressure check not sure. its on the front side of the bus the line thats cut off. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Nov 18, 2018 9:58 pm Post subject: Re: brake booster help 1974 vw bus westi |
BIGSERG wrote: |
"All the vacuum lines" are just two.
Rear nipple is for vacuum line to engine
Front nipple is the atmosphere line that leads to the driver's side b-pillar.
Colin Get Thee a Bentley Manual _________________ www.itinerant-air-cooled.com |
SGKent Samba Member
Posted: Sun Nov 18, 2018 10:43 pm Post subject: Re: brake booster help 1974 vw bus westi |
Amskeptic wrote: |
BIGSERG wrote: |
Colin Get Thee a Bentley Manual |
Actually one does not even need the Bentley manual at all to work on this area. A person can just bang their forehead into the nose of their bus ten to twelve times at the beltline, and everything they want to know about how to fix their bus will appear in front of their eyes... (as they pass out in pain for those who are stupid enough to try it - had to put that disclaimer in.) _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Nov 18, 2018 11:26 pm Post subject: Re: brake booster help 1974 vw bus westi |
thanks guys !!!! how about this little disk that spins underneath the engine seems like some kinda cable goes through it ot sure if its for the heater or not |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Mon Nov 19, 2018 4:39 am Post subject: Re: brake booster help 1974 vw bus westi |
That's part of the thermostat system.
Get A Bentley Manual |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Nov 19, 2018 10:02 am Post subject: Re: brake booster help 1974 vw bus westi |
tristessa wrote: |
If you remove it, oil will leak out of the hole.
(That's not in the Bentley…) _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
