Jack-Fatboy Samba Member
Joined: September 28, 2007 Posts: 353 Location: POLAND
Posted: Mon Nov 19, 2018 9:25 am Post subject: Subhatch prop rod - brand new |
Hello There,
This is just the prototype of brand new subhatch prop rod. Please take a look on pics and ... say what you think?! Thanks a lot.
I used almost the right 13mm x 1,5mm aluminium tube.
The next two earlier types will be ready soon. I just need the rectangular plates to finish them. The different wires eyelets are ready.
If there is someone who wants the new prop rod please email me.
Cheers,
Jacek |
Dewayne Samba Member
Joined: October 05, 2003 Posts: 332 Location: Oklahoma
Posted: Mon Nov 19, 2018 9:59 am Post subject: Re: Subhatch prop rod - brand new |
Looks great! Glad to see this as I need one! _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
Wolfsburg Classics Banned
Joined: October 17, 2003 Posts: 326 Location: Christchurch,New Zealand.
Posted: Mon Nov 19, 2018 4:33 pm Post subject: Re: Subhatch prop rod - brand new |
Jacek.
Looking good,there's a few people looking for these.
Are you doing the other version that has the rectangle sheet mounting plate? |
aerosilver Samba Member
Posted: Mon Nov 19, 2018 11:07 pm Post subject: Re: Subhatch prop rod - brand new |
Yes, I need one for a '61. |
Posted: Mon Nov 19, 2018 11:39 pm Post subject: Re: Subhatch prop rod - brand new |
Wolfsburg Classics wrote: |
Jacek.
Thanks Tony and you Guys for good words
Sure I want to do all version with rectangular plate with sharp and rounded edges.
Can you help me guys with investigation over the systems of the putting the rod on the hatch. Can you also tell me the year and model eventually?!
I know that there were the leather strap and the clip system but maybe there were some more?! All the way isn't difficult to do and maybe I can help with it to.
I also looking for the support pin?!
I think some people want to have all parts so ... please let me know if you have something. Maybe some good drawings helps or the sample.
Cheers,
Jacek |
Posted: Wed Nov 21, 2018 7:01 am Post subject: Re: Subhatch prop rod - brand new |
Hello All,
This is what I found - the clip to close the prop rod on the hatch. It looks the same like original one used in SO34.
There are 3 pieces and the cap isn't need. The man end is screwed to the rod and the woman to the board on hatch.
Cheers,
Jacek |
Posted: Wed Nov 21, 2018 7:40 am Post subject: Re: Subhatch prop rod - brand new |
There are the pics found in TS gallery.
This one shows the clip system where you can button up the rod to the hatch -
This is the secend one -
I need the information about he strap used to hang the prop rod. Is there anybody who can help? What was it? The plastic or leather strap?! Maybe something different?
Thanks in advance for help.
Cheers,
Jacek |
Posted: Wed Nov 21, 2018 10:20 am Post subject: Re: Subhatch prop rod - brand new |
Jacek,
I wish I could help you, but I'm missing all those parts on my SO23. I will be picking up an SO34 this weekend and will take ics of what is on it, if that helps.. _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
'64 SO34
'60 SO23 |
Posted: Wed Nov 21, 2018 10:28 am Post subject: Re: Subhatch prop rod - brand new |
Dewayne,
Thanks for your help. Let's try with it. I think I have something but I still looking for the information.
Cheers,
Jacek |
Posted: Thu Nov 22, 2018 2:16 pm Post subject: Re: Subhatch prop rod - brand new |
OK now everything is clear for me. I can't put the pics here right now but I will try to do it soon. I think I will do it when the new prop rods are ready. I think it will be next week.
Thanks a lot.
Jacek |
Posted: Fri Nov 23, 2018 5:09 pm Post subject: Re: Subhatch prop rod - brand new |
Guys I need your help.
1. I have an original prop rod and it is 42,5 cm long tube.
The holes are 9,5mm and they are located:
from the bottom of the tube - 2,5cm - 11,5cm - 12,3cm - 12,3cm - 3,9 cm eyelet
2. Tube is 42,6cm long.
I have found also few different prop rod dimensions like that:
from the bottom of the tube - 1cm - 12,7cm - 12,7cm - 12,7cm - 3,5cm
3. and ... 42,9cm long
from the bottom of the tube - 2,5cm - 12,3cm - 12,3cm - 12,3cm - 3,5cm
I want to drill the holes in tubes to make the prop rods now. What do you think? Is there any dependence between the year and holes location?!
Any idea?!
I think that I will do the last one holes dimension. It looks universal.
Please let me know what you are thinking or maybe you can put here the dimension of your original prop rods. Thanks in advance.
Cheers,
Jacek |
Posted: Wed Nov 28, 2018 1:33 am Post subject: Re: Subhatch prop rod - brand new |
Hello
I've just recived the metal plates needed to finish an early prop rods All works fine and I can back to the work on the prop rods. Please take a look on pics.
I will also paint the ends with eyelets using the paint from really good and original looking pattern.
I think you will see the rods really soon becuase I have all I need now.
Cheers,
Jacek |
Posted: Wed Nov 28, 2018 2:17 am Post subject: Re: Subhatch prop rod - brand new |
Question -
Who knows the size of the original screws to connect the rod with hatch?! Or maybe someone of you guys can measure it?!
Thanks in advance for your help.
Jacek |
Posted: Wed Nov 28, 2018 2:58 am Post subject: Re: Subhatch prop rod - brand new |
Jacek.
I am pretty sure they are 3mm screws and are the same as used to hold the middle bungee clamps.
Tony. |
Clara Samba Member
Posted: Wed Nov 28, 2018 10:08 am Post subject: Re: Subhatch prop rod - brand new |
Nice on the prop rods! Sometimes the og one is broken.
Jack-Fatboy wrote: |
Cheers,
Jacek |
Greg has repro westy leather straps sets for sale:
SO-23 set: https://www.thesamba.com/vw/classifieds/detail.php?id=2088392
pre-SO-23 set: https://www.thesamba.com/vw/classifieds/detail.php?id=2222558
Since the leather straps would be the same age, replacing one strap still leaves you with the other straps broken or of extreme age, dry and cracked. Sometimes a couple straps are still hanging on. With a bit of use, they also break. So when people have asked for a partial set, I've recommended they buy the whole set. The prop rod leather strap in the 56 westy was functional when we got the bus, but later it broke.
This is an original leather curtain strap in my 61 westy, but I doubt it will last with much use:
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Nov 28, 2018 10:32 am Post subject: Re: Subhatch prop rod - brand new |
You only need one strap for the prop rods. My 62 had a leather one that was broke so I made another one.
I'll add that I wish my 62 had come with the straps rather than the bungee cords to hold the curtains. Anyone who has a westy and pop outs knows that the bungees don't keep the curtains in the bus very well.
Those rods look great. Mine looks to have been a two piece rod that im guessing was done by a previous owner. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Wed Nov 28, 2018 10:51 am Post subject: Re: Subhatch prop rod - brand new |
Hello ALL
I have one more question - can someone check the wire diameter on metal plate?! I just need to be 200% sure if I made the good one.
I have two answers and they are the same but I wish to ask one more owner of original prop rod !!! Thanks in advance for your help.
Thanks for a good comment about my prop rods . It is nice. Greg's straps look really good Clara I like them. I can think to make some deal with Greg to have them in stock. I will contact with him later.
Sean thanks a lot for good words to. You should think to change your prop rod in the future Now you can think about it.
One more pic:
Cheers,
Jacek |
vtomike Samba Member
Joined: March 09, 2004 Posts: 147 Location: The armpit of so. cal
Posted: Wed Nov 28, 2018 1:08 pm Post subject: Re: Subhatch prop rod - brand new |
I will take a look at mine and get measurements. |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Thu Nov 29, 2018 9:43 am Post subject: Re: Subhatch prop rod - brand new |
hello and great work! please put me down for a prop-rod. 1961.
thank you!
email [email protected] _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Posted: Fri Nov 30, 2018 6:06 pm Post subject: Re: Subhatch prop rod - brand new |
Hi There
I need to Make some detailing and painting. The subhatch prop rods almost done
Cheers
Jacek |
