zgmg54321 Samba Member
Joined: August 24, 2018 Posts: 34 Location: Massachusetts
Posted: Tue Nov 20, 2018 11:12 pm Post subject: rebuild kit |
i have never built a vw motor before I have a 1600 dp type 1 right now what are your thoughts on this kit (part quality wise and price point) seemed reasonable to me but what the heck do I know its my first build... https://chircoestore.com/engine-rebuild-kit-1641cc.html
or does someone else sell a better kit I couldn't find anything with quiet as much in it
thanks in advance, zach |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Wed Nov 21, 2018 2:40 am Post subject: Re: rebuild kit |
Well it's not as simple as it sounds if your doing a bottom end rebuild as well. Motor needs to be torn down to a bare case and the mains checked or align bored just to get measured for your main bearing size before you can even order a kit. Same goes for the crankshaft. The could both already be 0.010 or more as it sits. You also are leaving an opportunity for "free" power like upgrading the cam shaft and bumping the compression. Even if your just wanting to rebuild a "stock" motor your going to need some special tools to go along with whatever kit you choose. If it was me I would just buy a piston and cylinder kit, tear it down, have the case and crank checked so you can order bearings, have the rods rebuilt/ checked and figure out a cam. New cam also means new lifters, once ran that lifter is a match for that cam lobe, same thing with rod caps. Are you just wanting to do it yourself? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Nov 21, 2018 3:08 am Post subject: Re: rebuild kit |
That's a way more stupider way to order parts if I ever was one.
I recommend you read through some of the the builds in the build stickies above to educate yourself on the procedure before you get out your Visa card. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Wed Nov 21, 2018 8:28 am Post subject: Re: rebuild kit |
Yes pull it apart before ordering parts.
Dont waste your time with a 1641 either. There is no point. Your buying heads, so if you want a bump in cc's without needing to bore the case then order heads opened to 90.5 and use 88mm kit with 90.5 top and stock slip in bottom for 1679. Now you have thick wall cylinders, not 1641 superthinwalls lol. |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Wed Nov 21, 2018 8:58 am Post subject: Re: rebuild kit |
Same rust bucket engine core & plan from this post?
https://www.thesamba.com/vw/forum/viewtopic.php?t=709477&highlight=
Same result:
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Nov 21, 2018 9:11 am Post subject: Re: rebuild kit |
Let's keep this in the original topic. _________________ Glenn
Member #1009
#BlueSquare |
