AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Wed Nov 21, 2018 10:09 am Post subject: Vanagon with an automatic transmission balks moving when cold? |
On the forum the question comes up from time to time why the Vanagon with an automatic transmission will not move when the gear-lever is in D or R..cold. It may take what seems like a minute and then the transmission shifts fine. Once the Vanagon is parked for a while the problem returns..why?
The answer could be a number of things..first off..your transmission could have worn seals or clutches..could be low ATF..could be normal too.
I went back through the old achieves from my training days with Porsche and thought I would share some information from 1982. The 010/089/090 transmission was still a relatively new item for VW/Porsche/Audi cars and the same basic transmission is/was used in many different cars.
One problem they had, early on, was the transmission balking once starting out cold, when the car had been parked for a while.
VW and Audi are silent on the solution. Porsche was better and described the problem and solution in a 1982 technical supplement for the 924 Turbo.
The solution was in installation of a "seal" to keep the torque converter from draining out when parked. The seal is used in Vanagons too. The seal is in the part catalogs. Probably NLA. Don't plan on replacing it.
I have built a few of these transmissions and never found the "seal" inside any turbine shaft. I suspect over time and use the seal gets loose and blows harmlessly into the torque converter. Lost forever until the torque converter is rebuilt.
If your automatic transmission Vanagon is balking moving in D or R cold..after being parked for a few days..it could be the torque converter draining down.
Put the gear-lever in N or P then wait a few seconds..Porsche says 10 to 20 seconds...which seems like a long time if you are sitting around..wait or blip the throttle a few times..fasten you seat belt..adjust your mirrors..adjust your radio..whatever..and then try D or R and see if the Vanagon moves out as it should.
Hope this is helpful.
Posted: Wed Nov 21, 2018 10:44 am Post subject: Re: Vanagon with an automatic transmission balks moving when cold? |
Vanagon boxes had a flat spring valve located underneath the inner pinion seal that kept the TC from draining down. Unfortunately the spring is easily damaged when a pry bar is inserted into the seal to pries the seal out. The damaged spring is not easily replaceable as it is held in place by an inaccessible rivet.
The spring on my '91 was so damaged by a previous owner (the damaged spring also pressed against the seal and eventually damaged it). I just put up with the transmission taking up to thirty seconds to engage if the car is not driven daily. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Wed Nov 21, 2018 11:27 am Post subject: Re: Vanagon with an automatic transmission balks moving when cold? |
Always a pleasure reading your informative posts. Thanks. My auto has been well treated and is low miles, yet exhibits this trait. Next cold start I willdo the pause and see what happens to add to the knowledge. In summer I hardly experience it but we are in the 30s now and it usually does it all winter.
Thank you! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
jlrftype7 Samba Member
Posted: Wed Nov 21, 2018 1:12 pm Post subject: Re: Vanagon with an automatic transmission balks moving when cold? |
For what it's worth, ZF HP transmissions are known for this issue as well Most people are living with it, or they take so long to get going with the vehicle that the TC refills and they're unaware it's happening in the first place....
So far, I haven't experienced any TC drain back on my '84 and it sits for days at a time since I'm still working on it and only moving it once a week at best when I pull it in to do the next never ending job...Guess that's one thing that works on the Van as designed.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
