Broseph Stalin Samba Member
Posted: Wed Nov 21, 2018 4:33 pm Post subject: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
The reason I ask is I have a stock 225/60/16 spare and 225/70/16's on each corner. Those are apx 1" taller than stock.
I've heard that having mismatched tires can ruin a differential, something I did not know. So bad idea to mismatch, or workable with only 1" difference? _________________ '68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Wed Nov 21, 2018 5:12 pm Post subject: Re: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
I would replace one as soon as possible. Besides any transaxle stress, emergency handling could be an issue.
Edit - if it's only the spare, you never have those on long enough to be a problem, IMHO _________________ Rich |
Abscate Samba Member
Posted: Wed Nov 21, 2018 5:23 pm Post subject: Re: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
You can run that until the cows come home. _________________ .ssS! |
Posted: Wed Nov 21, 2018 6:36 pm Post subject: Re: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
Thanks for the replies. Yeah, it would only be the spare, and I could put one of the rear tires on the front.
Actually I shouldn't make a big deal out of putting a matching 225/7016 tire on the spare wheel. Probably the smart thing to do. _________________ '68 Bus in West Germany, 1977-1979
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Wed Nov 21, 2018 8:01 pm Post subject: Re: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
Since the differential is not a locking or limited slip unit, it will be fine. This could cause some confusion/weirdness with the ABS system though.
There’s nothing like the ABS grabbing the brake on one side when you least expect it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Nov 25, 2018 7:26 pm Post subject: Re: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
TDCTDI wrote: |
There’s nothing like the ABS grabbing the brake on one side when you least expect it. |
Yeah I can see ABS being a problem, wheelspeed sensors getting confused. Makes sense to put a matched spare on, it isn't some big expensive deal. _________________ '68 Bus in West Germany, 1977-1979
Posted: Tue Nov 27, 2018 4:36 pm Post subject: Re: Mismatched Tire Sizes on Drive Axle? Problem or Not? |
2003 EVC, looked at the spare tire carrier, there isn't much room for a larger diameter tire. Stock 225/60/16 is 26.63" diameter, 225/70/16 is 28.4" diameter. https://www.tacomaworld.com/tirecalc?tires=225-60r16-225-70r16
Eyeballing the clearance available with the stock spare in the carrier there's maybe 1" more space available. _________________ '68 Bus in West Germany, 1977-1979
