nilza Samba Member
Joined: May 21, 2007 Posts: 342 Location: brisbane australia
Posted: Sat Nov 24, 2018 11:44 am Post subject: Gearbox parts condition? (now a rebuild thread) |
*EDITED** I noticed this kept getting bigger so it was time for a rename, history and introduction.
My name is Nils, I live in Australia and own one of very few westys in the country (due to either trakka having the contract to convert here, or possibly because there are so few RHD westys)
I use my bus alot. It is a RHD converted 1989 Syncro westfalia multivan that my better half only refers to as Roy. I don't like to cook inside so he has a weekender/multivan interior, 3 knobs and a DJ motor.
I have had the van in it's current state for about 3 years and have fixed and traveled so much. The Gearbox always jumped out of first if you back off hard, but recently developed a whine and a tendency to jump out of 4th. So it was time for a teardown.
Gearbox builders that want to take on a syncro are very slim on the ground here and any kind of guarantee is out of the question. My background is in aeronautical maintenance, so thought I would give it a shot.
Using the vast experience group on the samba I would really appreciate feed back and guidance with the parts within, as the Bentley doesn't exactly provide negligible damage limits for these parts. **
Hi guys delving into my first syncro gearbox fix.
Not sure whether I will be just fixing the major defects or doing a full rebuild, guess that is dependent on how much is wrong with it.
Anyways looking for a second option on ring and pinion wear.
Pictured is the only bit of damage present on the pair. My guess is a piece of the shift fork liniar bearing went though there.
The R&P look to be the factory due to the lack of markings on the outside of the ring and has 340000km to date.
Soooo, one mark equals replacement?
_________________ still floating around the web somewhere
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Sat Nov 24, 2018 12:02 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
Looks like spalling to me, which means replacing is necessary. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sat Nov 24, 2018 12:38 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
Yes, you should absolutely replace this R&P .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
nilza Samba Member
Posted: Sat Nov 24, 2018 1:39 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
Thanks for the responses fellows, I guess I knew that was going to be the answer. Having only one mark was killing me.
Gears, looks like I will be sending you a message in the next few days in regards to a 4.86 (and probably some other parts too by the time this thing is apart) _________________ still floating around the web somewhere |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Sat Nov 24, 2018 2:13 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
Gears- i'm not doubting you, just trying to learn... why would one mark on the pinion condemn this set? how many more miles do you estimate this set, as is, could go? i'm wanting to understand how one spalling mark on the pinion with no marks on the ring gear condemns the set because i expect to run into this on my second or third rebuild i attempt. i'll assume mixing a new pinion with a used ring gear is totally out. _________________ -dan
www.thefixitworkshop.com |
gears Samba Member
Posted: Sat Nov 24, 2018 4:24 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
If I were on a S. America safari and saw this via boroscope, I'd likely try to make it home .. but that R&P certainly can't be reused in any serious "rebuild". The case hardening is suspect, and the other pinion teeth can be expected to soon look the same.
A new pinion paired to a used ring gear might be "doable", but makes no sense. No one sells separate pinions .. they all come with a paired ring gear. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Zeitgeist 13 Samba Member
Posted: Sat Nov 24, 2018 5:54 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
Nothing a little JB Weld can't fix. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Sat Nov 24, 2018 9:21 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
nilza wrote: |
Having only one mark was killing me. |
[IMHO]you should rebuild for 100,000 miles[/IMHO]
What if that started to grow, shedding super-hard steel bits into your lubricant, denting up the precious surfaces of your new pinion bearing, your beleaguered mainshaft bearing, polluting your lubricant, growing big hairdos on your drain magnet in short intervals. You will not sleep well. _________________
....KTMs, GasGas, SPOT mtb |
?Waldo? Samba Member
Posted: Sat Nov 24, 2018 9:42 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
I believe that the one gouged tooth will hit every 7th tooth on the ring gear and will place undo wear on each of those teeth... but the tooth count on the ring is not divisible by 7 so it will hit different teeth the next time around. The teeth on the ring gear that were hit last rev by the gouged tooth on the pinion will all hit the same new tooth on the pinion this time around and transfer some of the wear to the second tooth... etc... and on and on as the wear cascades around both gears. One of two events will likely then occur. Either the teeth will all wear to a new nice stable wear pattern, (ha ha), or both gears will be progressively (exponentially) reduced to rubble. |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Sun Nov 25, 2018 1:51 am Post subject: Re: Gearbox parts condition? Love some second opinions |
First you should check whats the reason for the pitting. Pnionbearing clearance, wrong adjusted pinion, overpovered by engine or g-gear use ? |
nilza Samba Member
Posted: Sun Nov 25, 2018 2:42 am Post subject: Re: Gearbox parts condition? Love some second opinions |
Thanks for the input guys, definitely know where you are coming from. The snowball effect such damage could create, just had to ask the question as I am novice at this job and would hate for someone to point out "that would have been fine" after I replaced it.
Which pitting are we talking about Waldi? _________________ still floating around the web somewhere |
Waldi Samba Member
Posted: Sun Nov 25, 2018 3:28 am Post subject: Re: Gearbox parts condition? Love some second opinions |
we are calling damage like yours pitting. This kind of damage happens for a reason i asked above.. Mosly worn out bearing, but also possible the other 2. |
Posted: Sun Nov 25, 2018 10:15 am Post subject: Re: Gearbox parts condition? Love some second opinions |
so what is the red gear oil brand we see in the photo? Redline? since some of that Redline isn't rated for hypoid gears, could this have been a contributing factor? is that the type of damage that may occur using a non-hypoid gear oil? _________________ -dan
gears Samba Member
Posted: Sun Nov 25, 2018 10:17 am Post subject: Re: Gearbox parts condition? Love some second opinions |
nilza wrote: |
The R&P ... has 340000km to date. |
Look no further for a reason this R&P is worn out. Even without a glaring pit, the R&P has reached the end of its service life and couldn't be reinstalled with expectation of living another 150,000+ kilometers. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Waldi Samba Member
Posted: Sun Nov 25, 2018 10:21 am Post subject: Re: Gearbox parts condition? Love some second opinions |
no,to Dan.
And no to Paul. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Nov 25, 2018 2:42 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
DanHoug wrote: |
so what is the red gear oil brand we see in the photo? Redline? since some of that Redline isn't rated for hypoid gears, could this have been a contributing factor? is that the type of damage that may occur using a non-hypoid gear oil? |
Swepco 210 is red - and recommended for higher torque engine applications. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Sodo Samba Member
Posted: Sun Nov 25, 2018 7:20 pm Post subject: Re: Gearbox parts condition? Love some second opinions |
Paul is thinking 340,000 miles. ????
Many use “400,000 miles” so if it had 340,000 mile (plus damage....) its toast.
But it has 210,000 plus damage and is toast anyway.
It takes more than miles to age an R&P but miles is a component.
1) A van has only 90 HP, always has clean transaxle lubricant, drives slower. And the owner rebuilds the trans before it makes noise, before it pollutes the lubricant, destroying valuable shafts, valuable R&p etc.
2) another van has 180HP, drives fast, camper with heavy loads and never checks condition of the lubricant. By the time he notices the noise it’s been running the last 15,000 miles with a huge afro on the magnet, circulating the worst grinding compound you can imagine.
#1 is “one person”, somewhere. Nobody knows this person.
Most vans are #2.
I did #2 not so long ago. _________________
nilza Samba Member
Posted: Mon Nov 26, 2018 3:08 am Post subject: Re: Gearbox parts condition? Love some second opinions |
Wow, alot of questions to answer.
The red oil is indeed swepco 210
340000 Km not miles, sorry about the confusion I'm in Australia.
The visual mark pictured my guess is from the broken piece of linear bearing from the shift forks that I am yet to locate.
The gearbox was pulled down due to popping out of first and a increasing bearing noise on my last trip. I nursed it home 500miles (ish) with the noise. I considered the pinion bearing to be the cause, maybe explains the less than ideal contact too? _________________ still floating around the web somewhere |
Waldi Samba Member
Posted: Mon Nov 26, 2018 3:23 am Post subject: Re: Gearbox parts condition? Love some second opinions |
nilza wrote: |
. I considered the pinion bearing to be the cause, maybe explains the less than ideal contact too? |
yes |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Nov 27, 2018 9:54 am Post subject: Re: Gearbox parts condition? Love some second opinions |
Hello, Paul "Gears" and Waldi, have a lot of experience rebuilding these transaxles. I have read a lot of their posts. Experience is something "learned". You can read and watch all the videos you want, but there is a "feel" you just can't get without getting your hands dirty.
I have had professional builders build my vanagon 4 speed and my front differential on my syncro project, but decided rather than send out my syncro transaxle, I would tackle it myself. I have quite a bit of experience building other types of transaxles and racing transmissions. I have also setup some conventional differentials. I am also a retired factory trained VW technician. Syncro transaxles are new to me.
My advice would be to go about rebuilding this one with the ring and pinion. Not for the years of trouble free life, but to gain some experience. I purchased a few of the available tools, but have had to make numerous other tools that are NLA. They are usually easily fabricated, but I have access to welders, lathes, mills etc. Along with a lot of different diameter tubing for press sleeves.
You will have a lot of hurdles to overcome and why not learn on this one? You will learn what works and does not work, build your arsenal of special tools and get some of the "experience" you seek.
I have already worked out how to add a main bearing retainer plate, how to machine the case for the aftermarket splash plates, and I have made a few mistakes along the way that I caught, but won't make again.
I purchased parts from Paul, "Gears" and from Weddle. Paul was very helpful and we are lucky to have experienced rebuilders willing to share their experience with us. It is my intention to regear this one after I get the TDI engine up and running. Good luck on the rebuild and gaining some experience. _________________ ☮️ |
