pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Nov 29, 2018 3:06 pm Post subject: Rear Defroster Glass |
How do you test it?
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Nov 29, 2018 3:14 pm Post subject: Re: Rear Defroster Glass |
Connect electrical leads to a DC power source and spray the glass with a fine mist of water. If the lines dry of water first, then it works. _________________ In Stereo, Where Available! |
c21darrel Samba Member
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Nov 29, 2018 5:56 pm Post subject: Re: Rear Defroster Glass |
they usually work unless the wire is interrupted somewhere. That can be "fixed" too. _________________ regards
Uli
busdaddy Samba Member
Posted: Thu Nov 29, 2018 6:51 pm Post subject: Re: Rear Defroster Glass |
Really?, maybe in a desert climate, around here the conductive stuff has been corroded off from too many years of damp climate, they aren't like modern ones.
A Hanes or Chiltons manual for almost any vehicle from the 70's or 80's will have a section describing how to test and troubleshoot a defroster grid, sadly most VW heated windows from that era are so far gone it's not worth the time to attempt repairs.
Luckily a new one isn't much money at all: http://www.busdepot.com/j13431 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Clara Samba Member
Posted: Thu Nov 29, 2018 7:21 pm Post subject: Re: Rear Defroster Glass |
busdaddy wrote: |
Luckily a new one isn't much money at all: http://www.busdepot.com/j13431 |
for that price i would also get a new one. then again if i already had one that looks good i would give it a shot. _________________ regards
Uli
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Nov 29, 2018 7:30 pm Post subject: Re: Rear Defroster Glass |
pyrOman wrote: |
How do you test it? |
12 volts negative to one side positive to other side. |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Fri Nov 30, 2018 3:51 am Post subject: Re: Rear Defroster Glass |
Wow only $100. for a new one is pretty cool.
busdaddy wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Fri Nov 30, 2018 7:31 am Post subject: Re: Rear Defroster Glass |
It can be tested with either an Ohmmeter or a simple low impedance test light. Each line can be tested separately by connecting power to one side and the test light to ground, then gently and carefully pushing the tip of the test light onto each line. The same process with the ohmmeter without the use of power, just testing for continuity. Which actually works better as the resistance of each line can be measured and possibly detect a fault before it fails.
The repair kits are pretty cheap and easy to use, just tape it off and paint it on.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Fri Nov 30, 2018 7:55 am Post subject: Re: Rear Defroster Glass |
flemcadiddlehopper wrote: |
Each line can be tested separately by connecting power to one side and the test light to ground, then gently and carefully pushing the tip of the test light onto each line. The same process with the ohmmeter without the use of power, just testing for continuity. Which actually works better as the resistance of each line can be measured and possibly detect a fault before it fails. |
I don't agree, this goes against the basics of electrical theory. You'll be measuring the resistance of the entire grid, not one line (unless many/every line is broken).
The best way to test any electrical heating device is using amperage, but the "hook it up and spray water" procedure is quick, dirty, and works. I remember being taught in class to fog the glass by breathing heavy on it while connected. Same idea. _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Nov 30, 2018 10:21 am Post subject: Re: Rear Defroster Glass |
Ohms can be read very sensitively using Gordo's method- because they will read simply a stark difference on the lines that are broken in the absence of power. Ohm comparisons are the simplest way of dealing with conductivity testing on multiple, similar circuits. The guys who save money at swap meets are the guys with an ohmmeter in their pocket. _________________
EverettB wrote: |
FU#5 |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Fri Nov 30, 2018 3:14 pm Post subject: Re: Rear Defroster Glass |
I had a glass like that until recently. The heat never worked. I have only met about 2 people who have a functioning Bus rear defogger. (Unless they got the new glass..) _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Sat Dec 01, 2018 10:05 pm Post subject: Re: Rear Defroster Glass |
Bruce Amacker wrote: |
I think you misunderstood the process. Each line is being tested in this method.
The water method does show that a line does not work, but it does not show where the break in the line is.
With my method, if you have a bad line you simply work the neg. test lead towards the positive end until power (or continuity) is restored. You just found where you need to repair the grid.
There are many ways to test a grid. This is what to do if you want to fix it.
