valvecovergasket Samba Member
Posted: Thu Nov 29, 2018 4:48 pm Post subject: a slightly different heater topic - slooooow warmup |
ive searched all the threads i can find, and most deal a bit more specifically with the gassers.
i know the diesel stuff is a little less common, and ive had these NA early diesels in mk1s and know the heat takes some time to come on... but real quick here is my setup -
'83 westy 1.9l NA swapped diesel, originally the van was a 1.6l diesel.
cooling hose layout is the original 1.6l stuff, with the original 1.6l expansion tank, new pressure cap, overflow tank. system holds pressure (verified with one of those air-lift type coolant bleeders).
the engine failed an oil cooler according the PO and his stack of receipts, and the shiny new oil cooler on the engine.
there was still a little slime left in the coolant and as the van is new to us, i thought it worthwhile to drop the coolant and flush/clean. that was a success, and its all clean now!
it took some time to bleed but using the air-lift/vacuum/suction method worked great and i verified the system doesnt have any leaks. comes up to pressure, and sucks the coolant back out of the overflow on cool down.
the heater has always been really lazy, and the van very slow to warm up, even before my draining/filling. i originally thought what the heck ill throw a new tstat in while i had it drained, thinking maybe that was past its prime... no change.
the van also doesnt have a rear heater, just the front heater core in the dash. im thinking something related to this coolant flow may be the issue... ? missing a restriction somewhere?
with ambient temps during my commute getting into the low 40s i would like some heat, mostly for defrost
i have a vdo coolant temp gauge from the PO that ive been using to monitor the temps, a bit more accurately than the dash gauge.
if i leave the heater valve wide open/full heat request, its basically impossible to get the water temp up to 180 when going 50mph. itll warm up, albeit very slowly, moving in stop/go traffic.
if i leave the heater off, things warm up a bit quicker, though still not all that quickly comparing to my old diesel mk1s.
do i need to block the fresh air inlet to the heater box with these ambient temps?
did the diesel vans have worse heat?
did this thing come with a rear heater - that the PO maybe deleted incorrectly causing some funky radiator bypass condition?
thanks! |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Thu Nov 29, 2018 5:06 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
the small VW diesels suffer heat issues. there is so little waste heat that a heater core acting as a 'radiator' can cool the engine down so your temp gauge falls. some of the TDi models had an electric element inline with the heater core to add extra BTUs to the passenger compartment.
i ran a 1.6 diesel on veg oil all year round in essentially arctic temps. it'd take me a good 20 miles to get the cab warm of a tiny Jetta. a van? uff ta. _________________ -dan
www.thefixitworkshop.com |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32635 Location: Reading Pennsylvania
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Thu Nov 29, 2018 5:39 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
I would get a new 87c thermostat and put it in.
The diesel fired aux heaters were only common in markets where they were needed. Northern states and Canada mostly.
The 82 and 83 diesels didn't get the rear underseat heaters. Instead they had a plastic center floor duct that fed from the dash heater to the rear compartment area.
Mark |
Posted: Thu Nov 29, 2018 6:09 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
thanks guys, sounds like im not totally offbase ..
for reference, it has a brand new tstat in it - i figured id replace that while i had it all apart anyway.
if i leave the heater valve closed/heater off the whole drive, warmup time is decent-ish in this weather, and once at temp it tends to do a fine job staying there.... unless the heater is turned on going down a hill then it over cools again haha
i guess the relatively large heater core on these, being fed ram air at the front of the van, is just too much cooling with these ambient temps. sort of makes sense.
i guess i need to put one of the vanistan fresh air blockoffs on my christmas list! haha
as for aux heaters, it has the DA6 diesel eberspacher that appears to be factory/dealer installed/original.
it has a lot of cut wires and capped off connections around it but the fan does work when i twist the aux heat knob at the dash hah
i think thatll all be for sale eventually for someone else to use as parts. |
Posted: Thu Nov 29, 2018 6:24 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
My point was to make sure it is the correct 87c thermostat and not one of the lower ones, like 80 or 70. It needs to have no bleed hole as well.
Mark |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Thu Nov 29, 2018 8:16 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
I have exactly the same problem with a few nuances. I have 87 with an ALH tdi motor swap. I have closed the front vent as part of my small car ac install. I also have the oem rear heater.
I’m buying a cheap Chinese diesel heater as discussed in the other heater thread.
Here is the thread.
_________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Fri Nov 30, 2018 10:21 am Post subject: Re: a slightly different heater topic - slooooow warmup |
rmcd wrote: |
i saw that heater thread, definitely tempting when it comes time to update that part of the van. especially for the money!
when you blocked off your vents did you notice a significant difference in warmup times, especially with the heat running from a start?
id imagine the turbo engine would tend to put a little more waste heat out anyway than my NA setup.
crazyvwvanman wrote: |
gotcha! ill have to double check the p/n but i believe it was.
definitely didnt have a bleed hole though.
driving in this morning i left the heat fully off until i saw the temp come up to around 150-160 and it tended to stay there even with heat on during my 50-55mph steady state drive, until i got into stop and go traffic. then it came up a bit and eventually settled back into the 150-170 range depending on hills and speed for the rest of the drive in.
i think if i add a coolant line or block heater for the overnight sitting and that front vent block off ill probably be in better shape.
i also saw in some of the hvac threads that folks were wrapping their heater coolant lines with insulation which probably wouldnt hurt to at least keep the heat from escaping before it even gets to the core. |
?Waldo? Samba Member
Posted: Fri Nov 30, 2018 10:43 am Post subject: Re: a slightly different heater topic - slooooow warmup |
The ALH engine (TDI) dumps about half the waste heat into the coolant compared to your 1.9 IDI engine.
Preventing outside air from running through the heater core should help warmup times but it really isn't as simple as blocking the inlet. There is no recirculate feature to the stock vanagon heater system and the heater air has to come from somewhere.
If your thermostat is working properly then blocking the air to the radiator has absolutely zero effect on warmup times. It also has zero effect on engine temperature unless the thermostat gets to the fully open position (rarely happens in colder weather) in which case it can cause overheating.
It sounds like you have a non-functional or incorrect thermostat. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Nov 30, 2018 10:49 am Post subject: Re: a slightly different heater topic - slooooow warmup |
you might want to get the kit from Vanistan's IntrepidOverland.
https://intrepidoverland.com/shop/cabin-air-control/
Blocks off the cold air coming in the front. _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Nov 30, 2018 11:19 am Post subject: Re: a slightly different heater topic - slooooow warmup |
Assuming it was used on a Diesel then removing the baffle plate from the heater box should increase the air flow through the core and thus bring more heat into the cab. You could also add an pump to the heater circuit to increase the coolant flow through the heater. As mentioned get a higher temperature thermostat without a weep hole and check the temperature of your block during warm up with an IR gun.
Do check the temperature of the inlet hose to the radiator during warm up as well to verify it is remaining cold. If it warms as the engine warms your heat is being wasted. Do you have the pan under the engine compartment to keep cold air from blowing across the engine. |
edit - i think my first post was maybe a bit less than clear on the behavior with the heater off. but im generally happy with the warmup times in that case.
?Waldo? wrote: |
as i said i think it warms up decently without the heater turned on. so the normal radiator/thermostat loop seems fine
i think specifically the slow warmup is when the heater is on and im moving, blasting the heatercore with cold air.
when i say block off, i mean only the freshair inlet to the hvac, no the radiator itself |
Posted: Fri Nov 30, 2018 11:56 am Post subject: Re: a slightly different heater topic - slooooow warmup |
I've owned, operated, maintained many of the diesels in Vanagons the various varieties of Mk1-Mk4 IDI and TDI engines.
Your 1.9 non-turbo IDI engine should come up to normal operating temp very quickly unless it is down into the lower teens in °F and should blast burning hot heat from the heater. The IDI waste heat is significant and has no trouble keeping up with full-blast heat unless it is really cold out.
Blocking off the heater input will block the only inlet for air to the heater.
BTW, I find the lack of capitalization a bit irritating to read and inconsiderate so at this point I will opt out of reading your posts. Good luck with your issue. |
Posted: Fri Nov 30, 2018 12:06 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
Wildthings wrote: |
no pan under the compartment, its all just open. i wasnt aware that was even an option!
ill add dropping the tstat to my todo list to triple check the opening temp.
?Waldo? wrote: |
understood
i need to do some more poking around with the IR gun and see whats going wrong then.
from the looks of that vanistan setup it adds a recirc port which as you noted is needed to move some air through there, so perhaps just throwing cardboard in front of the inlet as a test wouldnt be the smartest idea hah
?Waldo? wrote: |
interesting take... certainly no offense meant by it, but whatever works. appreciate the help. |
Posted: Fri Nov 30, 2018 6:20 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
having another look at the van, and the bentley hose layout for the diesel and i think ive spotted my issue.
a bit hard to describe in words but long story short i think theres a tstat bypass with the way the hoses are laid out around the oil cooler.
the 1.9l has the fwd style j hose (between the head outlet port and waterpump) with the t in the middle that normally goes to the oil cooler. PO has this hooked up.
the radiator to tstat hose is the van one, with the t that goes off to the oil cooler. the large head -> radiator hose has its second t blocked off.
anyway, this looks like a big tstat bypass to me as the water pump will suction through the oil cooler and bypass the tstat for however much flow can go through that thing.
im unsure of exactly how the heater core on/off plays into how this all flows but ill fix this bypass as a first step. |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Sat Dec 01, 2018 7:34 pm Post subject: Re: a slightly different heater topic - slooooow warmup |
valvecovergasket wrote: |
id imagine the turbo engine would tend to put a little more waste heat out anyway than my NA setup. |
Negative, more likely a turbo will run with a leaner mixture so you will get less waste heat. When I put the TD in mine I noticed it took significantly longer to warm up. But… I live at high altitude, so the NA engine was overfueling. It turns out too rich of a mixture generates excess heat by burning fuel in the absence of oxygen. Instead of power you get heat and soot. You may notice the effect climbing a mountain pass, where the heat will shoot up unexpectedly fast compared to equivalent sea level climbs. Any engine that gives you an optimal fuel/air ratio is going to run cool. The TDi is notorious for not blowing heat in winter.
There’s a cooling system rerouting mod out there that can improve your cooling and heating. It uses the TDi hose routing and is pretty easy to implement. I did it and it helps in all weather situations.
Aso, I put tubular foam insulation around my heater hoses, helps tremendously. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Sun Dec 02, 2018 9:39 am Post subject: Re: a slightly different heater topic - slooooow warmup |
Gotcha - that makes sense
I'll have a look around for the reroute. Definitely wrapping the hoses will be on the to do list when we do the engine swap next year
I swapped the hoses around on the oil cooler last night so I'm not bypassing the tstat anymore and that made a big difference in the speed of the warmup while stationary.
Perhaps Ive stumbled on to the reroute, as my routing now matches the front wheel drive cars, just minus the metal distribution pipe.
I'll have a chance to take it for a spin tomorrow and see how it does with the heat on from a cold start while moving. |
