Vanderhiem Samba Member
Posted: Thu Nov 29, 2018 7:21 pm Post subject: brake reservoir replacement |
I recently had an issue with a cracked reservoir near one of the spouts going into the master cylinder. My question is can I replace the reservoir and grommets with the master cylinder installed in the bus or do I have to remove the master cylinder. I also wanted to know if I should put the grommets in the master cylinder first then insert the reservoir or do I put the grommets onto the reservoir then insert the reservoir into the master cylinder? Any help is appreciated. Thank you. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Nov 29, 2018 7:36 pm Post subject: Re: brake reservoir replacement |
I think it can be done with the MC installed, you'll need 1"+ between the top of the reservoir and the floor. Put the grommets in the MC first and then pop the reservoir into them.
How confident are you that no bits have broken off and are now down in the MC? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 284 Location: East Tennessee
Posted: Fri Nov 30, 2018 7:30 pm Post subject: Re: brake reservoir replacement |
Make sure your master cylinder isn't rusty where those grommets go in it. Mine was rusty and the rust had embedded itself in the grommets, so I couldn't reuse them. If you don't remove the cylinder, at least get a really good view of the grommet seating area to make sure they're rust free.
Install the grommets first, then the reservoir, lubing the little nipples with some brake fluid. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Nov 30, 2018 10:02 pm Post subject: Re: brake reservoir replacement |
Odd that your lower reservoir broke like that. Was it original or aftermarket? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sat Dec 01, 2018 11:35 am Post subject: Re: brake reservoir replacement |
It was an aftermarket (Airtec). I believe I may have caused the leak. When I pushed the reservoir into the master it caused pressure on the spouts which bent the bottom of the reservoir. It appears the leak was a seam where the spouts are molded to the reservoir. |
