How to build a narrowed adjustable Bus beam (tutorial)
Long-roofs
Long-roofs is offline
PostPosted: Tue Sep 12, 2006 10:17 pm    Post subject: Reply with quote
Smaller slide hammer with 2 or 3 prong ends. Just be careful, don't be a meat-head....
One way or another, lifetime of chasing the dragon
Do not let neanderthals dictate your personal happiness
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Wed Sep 13, 2006 2:21 am    Post subject: Reply with quote
I heavy peice of pipe, a length of threaded rod and some "Washers" made to fit the beam ID with the side shaved off so that they will slide to the inside of the bearing. Then slide the pipe just like a slide hammer and wala.
Why buy what you can build.
kei
kei is offline
PostPosted: Fri Dec 15, 2006 6:54 am    Post subject: Reply with quote
Hi, this is a very nice thread. I'm planning to narrow the front beam on my 1960 bus, but I have a couple questions.
At what point do you need a narrowed beam? Anytime the bus is lowered? Or is this more for custom wheels?
And what types of wheels is everyone using on their bus? Looks like most custom wheels like empi and such are 15 x 5.5.
And for the new side flanges, do you use the old ones for a pattern?
jeremyrockjock
PostPosted: Fri Dec 15, 2006 4:48 pm    Post subject: Reply with quote
I do things different from how I used to. I free up the center torsion retainer by total removing it and hammering the dimples back out. That way I don't have to remove the steering knuckle. I just cut the tube half way through and the retainer falls out. I leave enough metal to tuck back under the adjuster when I weld them on.
I cut the outer material off and weld 3/8" plate as the new side flange plates. Doing it this way the geometry of the beam is not changed.
Also I use the 1/2-20tpi set screw that comes with the adjusters. I drill the center torsion retainer 180 degrees from the original 14mm hole and thread it for 1/2-20.
I also use the original roller bearings instead of bushings. I have the machine the bearing fit though which is not easy. I have used a rotary file to cut the bearing fits. It take a while to get them to fit.
Other than that, I build beams the same way.
jerupke
jerupke is offline
PostPosted: Sun Dec 17, 2006 4:19 am    Post subject: geat topic Reply with quote
almost got mine finished.... great tutorial Jeremy!!!!
If it Jams, Force it.... if it breaks... it needed replacement anyway
Culito
11010101
Culito is offline
PostPosted: Tue Dec 26, 2006 4:49 pm    Post subject: Reply with quote
So how much would you charge just to build me a beam if I send the old one to ya?
jerupke
jerupke is offline
PostPosted: Wed Jan 03, 2007 2:02 pm    Post subject: send it..... to me????? Reply with quote
Send it.... to me.......???? I live in Europe?!?!
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Wed Jan 03, 2007 3:50 pm    Post subject: Re: send it..... to me????? Reply with quote
I think the question was for the teacher, not the student. Wink
Culito
11010101
Culito is offline
PostPosted: Wed Jan 03, 2007 4:53 pm    Post subject: Reply with quote
For the teacher, yes.
But I think since my truck is kind of a rare model, I'm going to buy new stuff and save the old in case someone (maybe me) wants to restore it at a later time.
jerupke
jerupke is offline
PostPosted: Mon Jan 08, 2007 4:23 pm    Post subject: Re: send it..... to me????? Reply with quote
ohhhh.. (thank God....) Rolling Eyes Rolling Eyes Rolling Eyes
kevinh94
kevinh94 is offline
PostPosted: Thu Jul 30, 2009 11:44 pm    Post subject: Reply with quote
Hey guys why couldn't you leave your control arm on the torsions bars and slid it back through your newly narrowed adjustable beam and cut just the one side 4 inches in?
it would save any guess work all the bars are together you measure in 5 inches and wrap them together. Then make one clean cut of 4 inches make your indention for the grub screw and call it a day?
I never understood the reason of measuring both sides, though I haven't tried lowering any beam myself.
Thanks
I really like this thread heck all the lowering threads for that matter.
Kevin
Low and Slow is the only way to go!!!
Geoslavetoo
Geoslavetoo is offline
PostPosted: Sat Aug 01, 2009 8:03 am    Post subject: Reply with quote
Kevin
Grub screw for the adjuster in the middle....think it all the way through Question Wink
kevinh94
kevinh94 is offline
PostPosted: Sat Aug 01, 2009 11:42 am    Post subject: Reply with quote
Kevin
Gotcha.
Na I usually don't. I guess I like to do things the hard way. Laughing
Thats how I roll. I always to it the hard way.
I may have found a good deal. But I am still talking to a guy about it. Its a 65 but like I said nothing is set in stone so its not mine yet. I need to learn on these things though.
On the cuts I saw a Saws-all in one of the pics. Is that how you all do it? I would have thought cutting straight would be CRITICAL with these beams. So buying or renting a Chop saw would be necessary.
I know when I have used a Saws-all I usually go crooked. I guess with practice that could be changed but a chop saw would take the guess work out of it all.
I have never done it but I think thats the route I would go.
Am I wrong. You guys that have done it know more than I so am I?
Kevin
Goshen
Goshen is offline
PostPosted: Sun Aug 05, 2012 11:24 pm    Post subject: Reply with quote
What happens to the dimples in the middle of the beam ?
jeremyrockjock
PostPosted: Fri Aug 10, 2012 5:44 am    Post subject: Reply with quote
You have to hammer them outward to allow the leave retainer to rotate.
Goshen
Goshen is offline
PostPosted: Fri Aug 10, 2012 10:25 am    Post subject: Reply with quote
I believe that there are three dimples on the center of the beam... I am trying to visualize how I would hammer them outward.. how would i access them to hammer them outward ?
Is there a cutout that I have to make ?
tanhis
tanhis is offline
PostPosted: Fri Aug 10, 2012 2:45 pm    Post subject: Reply with quote
Drill them out.
To hammer them out needs so much force or heat that you have a good chance to bend the beam in the process.
-58 Typ2 ambulance
-65 Typ 34
-73 411 variant all metal custom
-67 Typ2 kombi for parts
-07 TFSI passat variant
jeffreyned
jeffreyned is offline
PostPosted: Sat Jan 05, 2013 10:46 pm    Post subject: Reply with quote
Has anyone calculated how much drop you get for a specified amount of turn of the adjusters? I ask because I'm considering a cut and turn of my beam instead of using the adjusters. As its a one shot deal I'd like to find some actual data from those who have done it before. I realize its probably not a constant figure as the amount of drop must be affected by wear on the leaves, but a ball park figure would be nice. I'm hoping to drop 3-4 inches by cutting and turning and then re-index the rear to match.
Thanks!
'69 Bay Window Deluxe
'67 Single Cab Dual Chester
Busbodger
Busbodger is offline
PostPosted: Sun Jan 06, 2013 11:23 am    Post subject: Please put adjusters in Reply with quote
...now I don't know you are anything but for the sake of the next owner - put adjusters in. They might not want it 3-4" lowered all the time. Should help your resale value too in case you ever want to sell it.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jan 06, 2013 11:40 am    Post subject: Reply with quote
Thanks!
pretty easy to build a model to calculate
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
Page 3 of 5
