jmarshall024 Samba Member
Joined: April 16, 2008 Posts: 127 Location: Hopedale, MA
Posted: Sun Dec 02, 2018 7:09 pm Post subject: 77 Fuel injection trouble shooting |
Hi all- I know there are a ton of threads on FI issues. I read through a bunch of them, but could use a little simple step by step help.
I'm working on a friend's 77 bus with FI. When he bought it the previous owner told him it ran but very poorly and then died. Looking at the old fuel filter my guess is they ran this thing until it just clogged up and died.
So far I've done the following:
1. Drained the tank and washed some fresh fuel through it. I still think it will need a tank out cleaning.
2. Replaced the fuel filter.
3. Changed the fuel pump. I determined the previous pump was bad by putting the key to on and hitting the lever in the air flow meter. I can hear the new pump working/circulating fuel now.
I noticed no change after doing the above. The engine just cranks with no sign of starting.
I tried putting some fuel down the S boot today. No change.
Until today I thought this had to be a fuel delivery issue (given condition of the old filter, fuel pump and drained gas), but putting fuel in the S boot did nothing.
Now I'm thinking it could be lack of spark. I did confirm power at the coil and cleaned the grounds under the plenum. The vacuum lines aren't in great shape but I went around and made sure all the connections are a secure as possible.
I think a lot of work will be needed on the vacuum system and fuel injection components before this can be driven regularly, but I'd like to at least get it to fire before just having my friend buy parts on a hunch.
Any thoughts/ideas to at least get some signs of life? |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Sun Dec 02, 2018 7:41 pm Post subject: Re: 77 Fuel injection trouble shooting |
Did you test for spark at the plugs? Running points or pertronix? What's the timing tentatively set at for now? _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Dec 02, 2018 7:48 pm Post subject: Re: 77 Fuel injection trouble shooting |
Have you seen this manual yet?...
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Sun Dec 02, 2018 8:43 pm Post subject: Re: 77 Fuel injection trouble shooting |
Test for spark by setting the distributor end of the coil wire 1/4" from a good ground, if you have spark there then remove each plug wire in turn and use a spare plug to check for spark.
Your points could well be corroded up or just not opening. |
Posted: Mon Dec 03, 2018 6:24 am Post subject: Re: 77 Fuel injection trouble shooting |
thanks guys. I only get over to the bus on weekends so I'll attack spark next weekend.
I have been using the AFC manual here and there. The bus is running points.
The points, cap and rotor all looked ok, but agree on testing for spark the way described and probably replacing the points just in case.
I didn't get even a pop putting gas down the S boot so definitely think spark next. I'll report back in a week or so. thanks |
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Mon Dec 03, 2018 6:55 am Post subject: Re: 77 Fuel injection trouble shooting |
You can buy a spark plug tester from Harbor Freight.
I have four of these testers. They really put on some light display.
Posted: Mon Dec 03, 2018 9:40 am Post subject: Re: 77 Fuel injection trouble shooting |
jmarshall024 wrote: |
If you have your spark plug wires installed 180° out the engine will of course not run but may not even spit or backfire. Visually look at the resistance strip on your rotor, does it look burnt? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Dec 03, 2018 12:14 pm Post subject: Re: 77 Fuel injection trouble shooting |
Sorting out the ignition system is step 1 before you start dicking around with the FI.
Also this system hates vacuum leaks. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Randy in Maine Samba Member
Posted: Mon Dec 03, 2018 12:43 pm Post subject: Re: 77 Fuel injection trouble shooting |
If I might offer just a bit of a suggestion....
While it is nice that you are trying to get it to start in its present condition, that is likely not sustainable long term. Drawing fuel directly from a gas can will sometimes allow you to get adequate fuel pressure in the system even with a rusty fuel tank. A dwell meter and timing light will confirm that you have decent spark.
I would just plan on removing the engine/transmission as a unit and getting it on an engine stand. Once that happens you will be able to remove the injectors for servicing, the fuel tank for proper cleaning, the fuel lines for replacing, and will be able to clean up the tinwork to whatever your budget allows.
Make sure you own a dwell meter, a volt ohm meter, and a fuel pressure gauge.
If you need to borrow some stuff (like an engine stand) or something like that, let us know. There are lot of us bus guys in the area and we may have some of that stuff to let you borrow. Sometimes we even help out when we can. |
SGKent Samba Member
Posted: Mon Dec 03, 2018 1:01 pm Post subject: Re: 77 Fuel injection trouble shooting |
Randy in Maine wrote: |
you mean you can't just buy a car that has been sitting, add fuel and turn the key like they do on TV? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Dec 03, 2018 1:09 pm Post subject: Re: 77 Fuel injection trouble shooting |
Only if you have never sinned or had impure thoughts does that work.
In short it has never worked for me.
I am about 2 hours north of the original poster by the way. |
SGKent Samba Member
Posted: Mon Dec 03, 2018 1:26 pm Post subject: Re: 77 Fuel injection trouble shooting |
Only if you have never sinned or had impure thoughts does that work. |
well that explains why mine didn't start right up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Dec 03, 2018 1:33 pm Post subject: Re: 77 Fuel injection trouble shooting |
sjbartnik wrote: |
Also this system hates vacuum leaks. |
This!
Stop focusing on fuel at this point. Use Wildthings suggestion and then update this thread. |
SGKent Samba Member
Posted: Mon Dec 03, 2018 1:42 pm Post subject: Re: 77 Fuel injection trouble shooting |
Wasted youth wrote: |
sjbartnik wrote: |
This!
I have never understood why people have such trouble with ignitions. One has to have a WORKING timing light if they are going to work on a car of this era. If the battery has voltage in it enough to turn the motor, the timing light can tell you in 10 seconds if the plugs are firing, and if the timing is in the ballpark. Light flashes then the ignition is working. Light not flashing the ignition is not. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Dec 03, 2018 2:19 pm Post subject: Re: 77 Fuel injection trouble shooting |
SGKent wrote: |
sjbartnik wrote: |
This!
I have never understood why people have such trouble with ignitions. One has to have a WORKING timing light if they are going to work on a car of this era. If the battery has voltage in it enough to turn the motor, the timing light can tell you in 10 seconds if the plugs are firing, and if the timing is in the ballpark. Light flashes then the ignition is working. Light not flashing the ignition is not. |
You can buy a pretty nice timing light at a yard sale or flea market today for $5-10 that would have made a professional mechanic drool 30 years back. |
Posted: Mon Dec 03, 2018 2:28 pm Post subject: Re: 77 Fuel injection trouble shooting |
Thanks for the continued replies. I have tools and equipment needed to test the ignition system. Just didn’t have them with me yesterday. ( I was secretly hoping to get some response from the gas in the s boot).
As suggested I do think pulling the engine and tank will be necessary. Even if I got it running I wouldn’t trust driving it and I’m sure bad injectors and vacuum leaks will keep it from running well.
But while I have everything intact I can’t help trying some basic stuff. At least that way I won’t reinstall a cleaned up junk part. |
Posted: Mon Dec 03, 2018 2:55 pm Post subject: Re: 77 Fuel injection trouble shooting |
Nothing terribly wrong with this line of thinking, and it's great that you understand the value in pulling the power-plant and attending to all the deferred maintenance, mouse stuffings, questionable P.O. hacks and mends and give yourself a refreshed fuel tank, filler neck and vapor hoses.
And yeah... it's supremely motivating to bring a long-dormant engine back to life, just for a moment... just to know the damn thing isn't seized. |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Dec 03, 2018 3:38 pm Post subject: Re: 77 Fuel injection trouble shooting |
pulling the motor and tin may give you the win in the mouse nest thread as well |
Posted: Mon Dec 03, 2018 3:39 pm Post subject: Re: 77 Fuel injection trouble shooting |
