74 standard Samba Member
Posted: Mon Dec 03, 2018 8:32 am Post subject: Question on my oil pressure relief valve |
When I removed my plungers from my old case, they were both like the one on the right. Straight sided. But the pictures I have show the pressure relief plunger like the one on the left. 1974 stock build. As41 Case original and new. Do I have a problem?
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9954 Location: Huntington Beach, CA
Posted: Mon Dec 03, 2018 9:41 am Post subject: Re: Question on my oil pressure relief valve |
Nope. Use the old stuff, if it is not broken or heavily scored. The new ones suck! The package I purchased looked exactly like what you show. It took my low oil pressure and reduced it by another 5psi. I then recleaned some old stock pistons and springs I had in an old dusty bin and stuck those in. WAY BETTER. I still ended up with an issue, but in regards to what you wrote, the remainder of that story does not apply.
VW did install that bypass piston in some of their cases. Which ones is nothing I have knowledge of. But I have dropped that cut one out of the rear relief cavity many times, but the front cavity always had a solid piston in it.
Hoping I helped out! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Zundfolge1432 Samba Member
Posted: Mon Dec 03, 2018 10:10 am Post subject: Re: Question on my oil pressure relief valve |
1500 S engine type 3 used the grooved plunger. The booster kits are for people that think they need massive oil pressure, I’ve seen pressure spikes which pegged a gauge and burst oil coolers and blown seals. It’s also a bandaid fix for worn out engine with low pressure. All the ones I see go straight in the trash along with the bogus looking springs. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon Dec 03, 2018 10:58 am Post subject: Re: Question on my oil pressure relief valve |
VW_Jimbo wrote: |
Hoping I helped out! |
Thanks Jimbo! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Mon Dec 03, 2018 6:09 pm Post subject: Re: Question on my oil pressure relief valve |
VW initially used a grooved plunger in some Type 3 vehicles, but eventually they started putting it in all of
their single-relief case engines, as indicated by the part no. for the plunger (311-115-411) in the various
engines. VW never put a grooved plunger in a dual-relief Type I engine. Also, the grooved plunger (with a
slanted bottom edge) that almost always comes in the kits is NOT the same one VW used in Type I single-
relief engines, which had straight sides.
Using a grooved plunger in a dual-relief case is pointless, because the grooved plungers were designed
to work with an upper dump port in the case, which does not exist in dual-relief cases. Also, because the
grooved plungers are considerably longer than the plain ones, the effect is pretty much the same as
just using a much stronger spring, which is also pointless, because the stock plunger with the stock spring
will not even begin to move until there is PLENTY of oil pressure. _________________ '67 bug: seized by the authorities
morrist2 Samba Member
Joined: May 11, 2013 Posts: 2 Location: United States
Posted: Sun Jun 13, 2021 4:26 pm Post subject: Re: Question on my oil pressure relief valve |
Hi, i'm having a bit of a different issue. I just replaced my case and on start up, #1 piston rod bearing seized due to no oil. The front oil piston was stuck in the new empi aluminum case...would this cause the issue? I also had a brand new CB Performance crank, could there have been a blockage inside the crank? Any and all help would be greatly appreciated!!
Tim |
Posted: Sun Jun 13, 2021 4:34 pm Post subject: Re: Question on my oil pressure relief valve |
morrist2 wrote: |
Tim |
Could be a chunk of aluminum shaving got into the the piston and galled up. Best way to find out is pull it apart and diagnose. _________________ In Stereo, Where Available! |
Posted: Sun Jun 13, 2021 5:20 pm Post subject: Re: Question on my oil pressure relief valve |
Neither relief piston being stuck in the up (closed) position would cause oil starvation. Perhaps
excessive oil pressure in the case of the front piston.
New crank oil passages should be cleaned before install, no telling what sort of factory debris might
be lurking in there. _________________ '67 bug: seized by the authorities
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Sun Jun 13, 2021 6:58 pm Post subject: Re: Question on my oil pressure relief valve |
Eric&Barb wrote: |
morrist2 wrote: |
Tim |
Could be a chunk of aluminum shaving got into the the piston and galled up. Best way to find out is pull it apart and diagnose. |
On the diagram I have it shows the main bearings being fed first and then oil to rod bearing, so if this is true you’d expect the main to have been starved as well. But I agree, all the components should have been cleaned out first. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
