airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Dec 05, 2018 1:55 pm Post subject: Bus won't shift? Let's play Shifter Bingo! |
A few people have asked me about shifter issues this week… Here are the majority of shifter issues for you to contemplate:
And here are descriptions of each issue:
Missing or worn bushings: Each bus needs one plastic shift bushing in the front, and two in the central shift tube. (Some have three.) It might be possible to shift without the front bushings, but shifting will be loud and inconsistent. Check this first.
Aftermarket parts not compatible with originals: Some aftermarket shifters do not play nice with other stock parts due to height differences, angle issues, and lack of tape measures at the shift rod factory. Some shifters need stock reverse lockout plates, and some do not.
Clutch release issue: Always try all shifter tests with the engine running and with the engine shut off. If your clutch pedal doesn't fully release the clutch disc, the car will shift fine with the engine off but not with the engine running.
Cabin floor damaged: Over-tightening of the shifter housing bolts and front-end collisions can warp the cabin floor into shift issues. This won't cause any issue by itself, but can make existing issues worse.
Loose or missing grub screws: Unless your bus is held together entirely by rust, a missing grub screw will not allow the shifter to communicate with the transaxle shift mechanism. This can show up as hard 2-3/3-2 shifting, and general inconsistency in shifter action.
No grease on bushings: This usually results in loud and firm but still predictable shifting. Metal things need grease to move, like, duh? Rear bushings can squeak and sound like Bowser.
Shift rod(s) bent: So you just removed your front beam but it's hanging up on something… Oops… Front/back action may be unusable now, and side to side shifter action may be odd too.
Anti-rotation pin missing: This causes the shifter to rotate freely in its housing, but it may theoretically possible to shift, though I doubt it.
Grub screw landing(s) dirty: The shifter grub screws have tapered heads and required a matching taper to grab when tightened. If you get dirt in the landing, or use the wrong bolt, the proper grub screw can not fully tighten. This results in clumsy shifting at best, and a general distaste for going into any gears.
Reverse lockout plate missing or installed wrong: The lockout tabs go up, and the Ramp goes on the Right. See how fun letters are? The "collar" on the shifter handle has to be at the exact height of the lockout plate when the plate is installed into the housing when held upside in your hands. Sometimes the lockout plate will be at the wrong level when aftermarket shifters or plates are mixed with originals.
Nosecone bracket broken/studs stripped: All shifter movement is braced by a thin metal bracket in the transaxle nosecone. Gentle shifting prevents this, but sometimes the bracket or studs can't handle any more force and break. Repair requires removing the engine and transaxle. Remove the 091 springs and circlips while you're in there.
Coupler cage loose: The metal rear shift coupler cage should be a tight fit around the rubber bushings. Slop here results in sloppy shifter feel.
Free space: we've all used this one.
Broken/worn early guide pin or late bushing housing: The front shift bushings on early bays need a straight pin in the front bushing. Bent pins can allow the shifter to pop out of the pipe bowl, and missing pins result in no shifting at all. Late bays have a round hold in a thin sheet of metal that holds the bushing. If the hole is wallowed out enough from neglect, a new bushing will not stay installed. Late model bug bushings seem to work really well in late bays where the quality of available bushings is suspect.
Motor mounts loose/worn/missing: The transaxle has to remain stationary while shifting, like duh?
Bad pilot bearing: The pilot bearing allows the clutch to spin independently from the engine. A bad bearing usually acts fine when the engine is cold and mimics a sticking clutch disc once the engine warms up. Sometimes they make noise. Always they require engine removal to repair.
Reverse lockout plate broken: Reverse lockout plates crack and result in a wandering shifter feel. Originals can be welded, since the cost will out-perform an aftermarket plate. Make sure it matches the shifter housing. ("Wings and cutouts" or "No wings or cutouts.")
Reverse lockout plate misadjusted: Often resulting in a "chirp" of gear grinding when downshifting to second gear, the plate is designed to guide you into second and prevent reverse engagement without a full "push down" of the shifter. The "chirp" is your reverse gear grinding into silver slurry.
EMPI shifter: This was almost a free space, but if you're going to spring-load a shifter, make it the 1-2 gate instead of the 3-4 gate. Those who drive on any public roads need the 3-2 downshift guided if anything at all. Remove the coil spring in the base of your EMPI shifter to retain its excellent Nylon pivot bushings while making it easier to select gears. Adjust by selecting second gear and shoving the whole shifter and housing to the left before finally tightening the shifter bolts.
Coupler collar spinning: Some aftermarket shift couplers aren't fully coupled internally. (Interestingly, NOS VW couplers are crimped 360°, where even the good aftermarket couplers are only crimped once for a few degrees somewhere along the edge.)
Bent shift coupler: Someone removed your engine/transaxle without proper supports and coupler disconnects, so you get to buy a new coupler. And instal it. And adjust the reverse lockout plate. And enjoy paying attention.
Nose cone ball worn/missing: There is a metal ball in the nosecone that is responsible for taking your PERFECT H-pattern (right??) shifting and translate those motions into gear engagements. VW went plastic (cheap!) in 1976 and the metal balls will wear out too if you neglect oil changes and/or shift like a gorilla. Repair requires removal of engine and transmission. Please ensure your old ball is fully removed first, RIGHT KENTps?
Coupler cage bolts missing: The seemingly-cheap-but-actually-brilliant method of using a lag bolt and sleeve to clamp the rubber bushings into the rear shift coupler can work loose. I make sure to check the tightness on these after the first few hundred miles of shifting. Some use blue thread locker.
Shifter housing bolts loose: This one should be self-explanatory, but those buses are still out there! Mine was one.
Slot/pin interface in pipe bowl worn: The fit of the shift ball pin into the shift rod pipe bowl determines lateral slop in the shifter. New parts are not available, but rotating the pin often results in the "fresh" metal taking up some slack until you find someone to weld the bowl and grind a fresh slot into it.
I wish everyone many many miles of fantastic shifting,
www.airschooled.com
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Dec 05, 2018 7:53 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
I played "Find That Gear!" in Chloe for almost two years. The fore/aft movement was pretty long, and finding the right location for first and second gears were a hit-and-miss thing. I received numerous impatient honks at stop lights while playing this game.
But after replacing all three bushings (and adding the fourth one recommended in the service bulletin), and replacing the plastic nose cone ball with a metal one, shifting is PERFECT! This is the first VW I've driven that had a tight shift pattern and actually matches the decal on the ash tray.
If I had done this work on the '71 tin top Westy I had in the '80's, I may still have it today. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Tue Dec 11, 2018 8:39 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Anybody have a BINGO on their car?
Did I miss any?
www.airschooled.com |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Dec 11, 2018 9:33 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
looks like the bingo hall is empty. everyone's at the buffet _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Dec 12, 2018 2:38 am Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Automatic transmission symptoms will need a different bingo card.
Before I drove my 77 bus with manual transmission, I had replaced all the bushings I could find that were available. To this day, I do not know if the previous owner even suffered anything on the bingo card, because I never even drove it until I replaced all those parts. Doing that allowed me to have a shifter that I can shift all four years with my index finger and thumb... it was beautiful! |
SGKent Samba Member
Posted: Wed Dec 12, 2018 9:33 am Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Wasted youth wrote: |
Steve - I like shifting years too. Would you like some of mine? - they are free if you want them. I am having trouble getting rid of them, and they are accumulating too fast. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Dec 12, 2018 12:24 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
If you eat the right mushrooms, you can shift years perfectly. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed Dec 12, 2018 12:42 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Nice work Robbie! Very useful for diagnosing _________________ Stuart Zickefoose
206-841-7324
[email protected] |
timvw7476 Samba Member
Posted: Wed Dec 12, 2018 2:59 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
The Bingo Card is almost perfect.
With the exception of Free Space, I would devote Free Space
to the problematic engagement of First & Reverse Gears when it's time to
adjust the clutch cable travel back to factory spec. Always an issue. |
SGKent Samba Member
Posted: Wed Dec 12, 2018 3:15 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
I must be eating the wrong ones - all I see are pretty colors - or colours if one is eating them from the UK. Hey does that mean I time-space warped? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Dec 12, 2018 8:12 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
timvw7476 wrote: |
Thanks for the kind words
I will group the clutch cable slack in with top center “clutch release issue.”
The differential diagnosis would be that the car shifts perfectly with the engine off, and has issues shifting once the engine is spinning the clutch disc without letting go when told. At this point, you’d need a different bingo card with:
- check clutch pedal for not too-much free play.
- check Bowden tube for sag and integrity. (Also check the weld where he Bowden tube mounts to the chassis.)
- check for clutch arm parts compatibility. (There are different length arms for both ends of the cable, and stack up errors can prevent the clutch from releasing.) This is rare, but easy to check with help from Samba threads.
- check engine and transaxle mounts for tightness, condition, and straightness.
- remove engine and replace pressure plate if the springs aren’t symmetrical, or pilot bearing if shifting is fine when cold but gets worse as the engine warms up. Pilot bearings usually leave marks on the input shaft. Cross hatch sand those down. Sometimes a collapsed pressure plate isn’t visible, but is the last part you can throw at it. It should be dynamically balanced before installation, and it should fit the flywheel with NO movement up or down. Sachs of Brazil is notorious for this, and the vibration will tear your bearings part.
Posted: Wed Dec 12, 2018 8:13 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Theoretically you could shift a bus with no bushings at all. Theoretically.
Posted: Thu Dec 13, 2018 9:53 am Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Years ago (1998) I had a 1971 bus that was a huge pain in the ass to find the gears when shifting. I had no knowledge of repairing that, and paid a shop $50 to replace the bushing under the shift lever and reset the plate. Probably took them all of 20 minutes |
airkooledchris Samba Member
Posted: Thu Apr 18, 2019 12:33 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Quote: |
Bad pilot bearing: The pilot bearing allows the clutch to spin independently from the engine. A bad bearing usually acts fine when the engine is cold and mimics a sticking clutch disc once the engine warms up. Sometimes they make noise. Always they require engine removal to repair. |
Im pretty sure this is where im at currently. Late last year I readjusted the clutch with every turn I could muster on the adjustment, which did restore my ability to shift into 1/2 again, but it's back where I was before:
I can shift fine when it's cold. Not *great*, like I have to really SHOVE the shifter towards the front of the bus to get it into 1st, but once im in first im pretty much good to go through the rest of the gears.
Now - once it's hot, it's almost impossible to get into first. If I can, I can fairly easily find second and then third and fourth are never a problem. I haven't done the clutch in a long time, so ill probably just tackle that at the same time when I go to change the pilot bearing. |
SGKent Samba Member
Posted: Thu Apr 18, 2019 1:00 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
It usually grinds if the bearing is bad. Try shifting with the engine off.
Also - the bearing can do the opposite too - act sticky or squeal when cold, and shift when hot. I've seen them both ways. The bad news is it is wearing the pilot shaft if bad so it is something you want to get to as soon as possible. Loose engine to trans bolts can do the same. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
If it goes into gear fine with the engine off, (clutch can help sometimes) it’s very likely a clutch release issue. The pilot bearing can grab the input shaft if it’s not in good shape and lubricated. I’ve also seen pressure plates go bad for no reason and give the same symptoms. If the pilot bearing is well-greased and rolls smoothly, stare down the pressure plate parallel to the flywheel. Some diaphragm fingers sitting lower than others can indicate failure, though I see it more on older style pressure plates.
The temperature change is good to note, since cold transaxle oil is thick and helps slow down the gear sets enough to mesh even if the clutch system isn’t releasing fully.
Good luck,
Posted: Thu Apr 18, 2019 1:16 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
It never 'grinds' going into gear, if that changes the possible cause of the shifting issues.
I just can't push it into first without quite a bit of force, when it will finally clunk into place when I find the magic spot.
Whatever it is, it's getting a lot worse and fast. I don't plan on driving it at this point, other than from the street to the driveway when im ready to pull the whole lot. i'll throw some UV dye into the oil while it's idling in the driveway before I pull it, so I can get it into the garage and identify any current sources of leaks that I should tackle while it's out. |
Posted: Thu Apr 18, 2019 1:26 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
Sounds like your transaxle synchronizers are putting up with the clutch release issue...... for now.... _________________ Learn how your vintage VW works. And why it doesn't!
SGKent Samba Member
Posted: Thu Apr 18, 2019 1:35 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
see if it does it when the engine is off. Go up and down thru the gears. Then put it in neutral and start the engine then turn it off and try it again. See what happens. If it is something in the trans I would think it would be hard again but if it is the pilot bearing it would work fine both times. When my 1st gear syncho wore I had to put it in 2nd from neutral then first. 1st is a big gear and it takes more to stop it from spinning.
Another way is put the engine in first with the clutch pushed in and let off the brake. Does the engine try to push the bus forward or the bearing squeal? That would mean either a bad pilot bearing is bad or the clutch disc is dragging. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Apr 18, 2019 4:15 pm Post subject: Re: Bus won't shift? Let's play Shifter Bingo! |
SGKent wrote: |
Another way is put the engine in first with the clutch pushed in and let off the brake. Does the engine try to push the bus forward or the bearing squeal? That would mean either a bad pilot bearing is bad or the clutch disc is dragging. |
Still sitting since yesterday, engine off - I was able to get through all of the gears fairly well. Started it up in neutral, then pushed in the clutch and went through all of the gears. I could do it, but juuuust barely, with 1st and 2nd again nearly impossible.
Turn engine off and right away I can get through all of the gears again.
Im going to assume bearing, but it's been so long since it's had a fresh clutch that im just going to do it as well. I guess the main thing I need to sort by then is just how I plan to get the pilot bearing out.
Thanks for the tips guys. |
