Xevin Samba Member
Posted: Wed Dec 05, 2018 7:10 pm Post subject: Identifying after market cam gear |
Long shot here. Curious about what after market company made this gear. I couldn’t find anything searching the internet.
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Wed Dec 05, 2018 7:33 pm Post subject: Re: Identifying after market cam gear |
There you go. Mofoco!
https://www.mofoco.com/item/VW_TYPE_1_BUG_GHIA_ENGINE_FLAT_CAMSHAFT_CAM_GEAR_KIT/2240/c145
Call Roy and inquire. _________________ I have learned over the years.
Buy Once, Cry Once!
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Wed Dec 05, 2018 7:34 pm Post subject: Re: Identifying after market cam gear |
Thompson/Ramo-Wooldridge.
Remember them?
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Dec 05, 2018 7:38 pm Post subject: Re: Identifying after market cam gear |
Google came up with Mofoco.
Same part number. _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Dec 05, 2018 8:15 pm Post subject: Re: Identifying after market cam gear |
Let's allow Roy to weigh-in here & advise us if MOFOCO's operations include gear hobbing. _________________
modok wrote: |
Xevin Samba Member
Posted: Wed Dec 05, 2018 8:58 pm Post subject: Re: Identifying after market cam gear |
There has got to be some kind of connection - right? _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Dec 05, 2018 9:38 pm Post subject: Re: Identifying after market cam gear |
VW_Jimbo wrote: |
There has got to be some kind of connection - right? |
Nope! _________________ I have learned over the years.
Buy Once, Cry Once!
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Thu Dec 06, 2018 8:11 am Post subject: Re: Identifying after market cam gear |
The issue here is fit, right?
Too tight or too loose or not round, correct?
Again,
Mother VW is our savior.
Not only do they make them in different sizes to fit correctly,
They also make them round..
When you dig thru junk boxes or piles at swaps,
You usually find factory gears riveted to old cams.
We used to throw them on the ground so they fit in the scrap bin easier.
Cast cams just snap so easily...
Those factory gears were everywhere back in the day.
You drill out the rivets to remove the cam from the gear,
Then use a mill or drill press to ‘spot face’ a place for bolts to go.
(Like was done to the gear in your pic above)
Any chance the cam/gear that came from your motor is still around somewhere?
Maybe go dig in the scrap pile?
Tear down one of those old cores behind the shop?
Sucks all these things we -always- just threw away are scarce now..
Gee, wonder why?!? _________________ Bus Motor Build
What’s That Noise?!? |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Thu Dec 06, 2018 8:59 am Post subject: Re: Identifying after market cam gear |
That isn't one of mine BUT may have been made by the same company that makes mine(IN THE USA!!!)
My gears are -2
BTW....the real fun part of putting a new cam gear on an OE German cam is using the combo drill-tap for the holes by hand and doing it perfectly straight. I've done thousands over the years as we used to make all the performance grind cams for JC Whitney..... _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Xevin Samba Member
Posted: Thu Dec 06, 2018 1:23 pm Post subject: Re: Identifying after market cam gear |
Yep Clatter, I know about the OEM Cam gear to after market cam swap procedure. I have a +1 OEM gear lined up if needed. But it’s attached to a NOS
VW Cam. Seemed like a waist of Cam if this +2 is what’s needed. This bolt on +2 is easy to use for testing. If +1 is needed I will pick up the NOS cam and do the mod. Won’t know until we crack the engine back open.
What I ultimately wanted to know is. Is this a quality aftermarket gear to use should +2 gear achieve the proper backlash
The gear feels and looks really nice compared to other aftermarket gears. A real nice chunk of metal and it measured out nicely. It was only $25. The fact that it’s very rare to find a + aftermarket gear tells me it’s probably not shiny-chiny, maybe Taiwanese or domestic. I might be wrong on this but my opinion is 80s Taiwan parts had better quality control then today’s Chinese stuff.
I wonder if the stamp 8-71 on the gear actually indicates it was made in August of 1971? _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Fri Dec 07, 2018 8:45 am Post subject: Re: Identifying after market cam gear |
An NOS stock cam?!?
PERFECT for a set of pea-shooters!
The thing will purr like a sewing machine... _________________ Bus Motor Build
Posted: Fri Dec 07, 2018 8:48 am Post subject: Re: Identifying after market cam gear |
FFFWWWEEEEMMMMM!!!!
Posted: Fri Dec 07, 2018 8:54 am Post subject: Re: Identifying after market cam gear |
Seriously, man,
If Xatie wants to go stomping around town,
Setting off car alarms,
And breaking hearts at every stop light,
I can build you a copy of my heater beater 1776.
Already have a case, 69 counterweight, unitechs, heater boxes, lessee..
What else we got here??
If you want something with heaters,
And some stomp to it’s tromp..
There’s another floor-sweeping around here somewhere.
Build the sweetest stocker for your sweetie you can right now,
Because pretty much everything should be different on That Other Motor..
Know what I mean, Vern..? _________________ Bus Motor Build
Posted: Fri Dec 07, 2018 9:07 am Post subject: Re: Identifying after market cam gear |
Send me that set of Auto Linea heads your builder didn’t like?
I’ll fix ‘me and give them a porting..
Got a couple sets of heavy singles here,
Or a slightly-worn set of Berg duals to use.
Plus a set of swivel feet and a little-bit-worn E110..
You have a header,
(And hopefully a glass-pack (!))
So far all we need is a set of cylinders and carbs..
I have some nice old-school Cima 90.5s,
But they are getting worn.
Will have to measure, but, maybe a ridge-ream and re-ring will do ‘em..
If you’re gonna be beating on it,
There’s no real need to be all anal and perfectionist about it..
All of this stuff was given to me so why not pass it along?
They have those $90 copy-of-a-copy China IDFs for sale.
If we had time to analyze them on the run stand,
Send back for replacements as needed if needed,
If we got them to work they would probably stay that way, right? _________________ Bus Motor Build
Xevin Samba Member
Posted: Fri Dec 07, 2018 10:20 am Post subject: Re: Identifying after market cam gear |
You the best Clatter. Thanks brother. The after market gear was just to have on hand for diagnostic purposes. Easy to bolt on to the Engle cam. We also have a stash of OEM cams/gears to use in an assorted range and a Brazilian +1 cam gear ready to bolt on. So we did some test last night. It appears the problem is on the crank gear. Found a tooth just a bit off. So went through his box of crank gears to find a suitable replacement. So hoping it’s not a line bore issue. The way the engine went together didn’t feel like it in my buddies experience. If it is. We have several cases in the bull pin if needed. Machining won’t cost anything.
Anybody have experience with SWAG crank gears?
We not using it. My buddy was just curious, if they were any good.
Clatter wrote: |
SGKent wrote: |
Posted: Fri Dec 07, 2018 11:10 am Post subject: Re: Identifying after market cam gear |
Xevin wrote: |
I always wanted to build an entire motor where all the parts said Made in WEST Germany.... _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
Posted: Fri Dec 07, 2018 12:28 pm Post subject: Re: Identifying after market cam gear |
There has been an issue with woodruff keys being big..
Does the tight spot correspond with the location of the keyway?
Easy enough fix if so;
Just sand the thing down on the old surface plate.. _________________ Bus Motor Build
Xevin Samba Member
Posted: Fri Dec 07, 2018 12:53 pm Post subject: Re: Identifying after market cam gear |
Thanks Clatter. I’ll run that by him. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Fri Dec 07, 2018 1:47 pm Post subject: Re: Identifying after market cam gear |
That gear, heated, should just drop in place. I guess everyone knows that though. _________________ Volkswagen!
(Compression 8.7:1) |
