Corinne&jake Samba Member
Posted: Thu Dec 06, 2018 6:46 pm Post subject: Floor pan installation |
Started fitting in our new floor pans but before we start welding the manufacture recommended sanding off the protective layer that it was shipped with, has anybody done this? It seems especially difficult around the seat braces. Is there another way to remove it or can it stay on and be painted over?
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Thu Dec 06, 2018 6:49 pm Post subject: Re: Floor pan installation |
This should be in one of the vehicle forums....
This is the Performance Engine Section.
Anyway, I'm sure they mean to remove the coating just where you will be welding. Leave all the rest. _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Dec 06, 2018 6:52 pm Post subject: Re: Floor pan installation |
Performance floorpan!!! _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Fri Dec 07, 2018 12:08 am Post subject: Re: Floor pan installation |
Steel wire brush on the angle grinder to quicly remove paint, yes, only where you are welding, the rest can serve as an undercoat. Fully sanding down the floor pan is quite a job! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Dec 07, 2018 8:54 am Post subject: Re: Floor pan installation |
Only where you will weld.... It's something taught in welding class/science... Always make area to weld as clean as possible, means bright steel.... Also where you will attach ground clamp...
FullFender Samba Member
Posted: Fri Dec 07, 2018 9:31 am Post subject: Re: Floor pan installation |
did you use a wire wheel? |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1170 Location: San Angelo, Texas
Posted: Fri Dec 07, 2018 3:42 pm Post subject: Re: Floor pan installation |
Use a flap disc on an angle grinder. It will take off the paint and leave the metal. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
nsracing Samba Member
Posted: Sat Dec 08, 2018 1:00 am Post subject: Re: Floor pan installation |
Cleaning the parts to be welded is part of the process of ..welding.
Is this first time welding? Floorpans have to be fitted to the body, obviously before any welding. All the holes should line up.
Also, are you doing an off the pan job? or a slip in job? |
Posted: Sat Dec 08, 2018 4:25 pm Post subject: Re: Floor pan installation |
Obviously a wire welder is a must have, preferably with c25 _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
