moxbox Samba Member
Joined: April 14, 2014 Posts: 24 Location: United States
Posted: Sat Jul 23, 2022 3:51 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
Quote: |
ALSO....the same gun case will fit (2ce...TWO of them) in your upper luggage rack! Flambeau Express Gun Case 6448SC |
Nice fit to the luggage rack! Almost looks like it was designed to go there
So what will fit in the cases? Oil quarts? Coolant top up? Jack? |
57daddy0d Samba Member
Posted: Sat Jul 23, 2022 1:21 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
pnwkayaker wrote: |
Thanks for the explanation, do you have any pics to go along with it? I'm having a bit of a hard time understanding your setup.
Also, do you have a link to the gun case? I've never heard that 2 of them could fit in the upper luggage rack (that's interesting).
57daddy0d wrote: |
This from (my) FB post:
A standard hard plastic rifle case will fit perfectly under there.
I bolted a gate hinge on one end of a 12" x 42" piece of plywood with angled aluminum edging on the long sides of the plywood to prevent bowing.
The gate hinge is bolted to the RF jack point frame member. The other end of the plywood swings down under the van so that you can slide the (in my case - very full and heavy) gun case onto it. I drilled a small hole through the floor under the bench seat to come out under the van about 5" in front of the RR jack point frame member. Through the top of the hole I slid a 6" Lag bolt to rest securely on the rear bench floor. On the rear end of the plywood I drilled a hole to meet the threaded stud of the lag bolt (underneath). Swing the whole affair up from the bottom (using a scissor jack if your gun case is REALLY full and heavy like mine) and bolt it to the lag-bolt using a big washer. Use a 2nd bolt to lock it in place or better yet drill a hole in the lower end of the lag stud (below the end bolt) and fit a cotter pin.
ALSO....the same gun case will fit (2ce...TWO of them) in your upper luggage rack! |
I edited my prev. post to include those details, thanks! |
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Sat Jul 23, 2022 10:02 am Post subject: Re: Under floor storage box - what are the latest ideas? |
the joker Samba Member
Posted: Sat Jul 23, 2022 9:48 am Post subject: Re: Under floor storage box - what are the latest ideas? |
I once saw surplus ammo tubes fairly long with water tight caps , they would fit under near the slider I'm still looking for them (flea mrkt item) |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Fri Jul 22, 2022 1:11 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
Aww I love this thread. This is so on my next project list. |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 920 Location: Sammamish, WA
Posted: Fri Jul 22, 2022 8:01 am Post subject: Re: Under floor storage box - what are the latest ideas? |
57daddy0d wrote: |
_________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Thu Jul 21, 2022 8:52 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
A standard 48" hard plastic rifle case will fit perfectly under there.
I bolted a gate hinge on one end of a 12" x 48" piece of plywood with angled aluminum edging on the long sides of the plywood to prevent bowing.
(Sale item at princess auto in canada for 20bucks CDN)
T
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
?Waldo? Samba Member
Posted: Sat Dec 08, 2018 10:44 am Post subject: Re: Under floor storage box - what are the latest ideas? |
Every sock vanagon wheel I have seen has allowed significant airflow through it to match the large holes in the clamshell. It seems likely that the airflow through the wheel and clamshell is the stock path for a lot of the air passing through the radiator. I believe the later stock turbo-diesel vanagons in other markets had an enlarged air tunnel in order to further increase the airflow through the (oversized) radiator. It seems unlikely to me that VW would have made a significant body modification if the airflow through the tunnel/clamshell was excessive. Blocking off the airflow through the clamshell might not be an issue but it would be wise to proceed with caution. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Dec 08, 2018 10:32 am Post subject: Re: Under floor storage box - what are the latest ideas? |
dobryan wrote: |
That will have no impact on cooling. There is plenty of room
for the radiator air. |
No Impact on the cooling, but long term heat being blown off the radiator onto the storage container. It's not an immediate effect, but I've seen more then one dried out spare tire where the sidewalls are cracked over time.
How is the heat resistance of blue plastic container material?
It is something else to consider as your going down the interstate in August. _________________ This free advice is worth exactly what you paid for it.
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Sat Dec 08, 2018 6:27 am Post subject: Re: Under floor storage box - what are the latest ideas? |
GypsyDriver wrote: |
I've seen someone make a similarly-functioning long drop down box in this same space for chock blocks, jack, etc. Doesn't look all that hard to fabricate. |
yeah, like the seemingly simpler fab on the under tray and its good for batteries that are not frequently accessed.
i really like the simpler look down in a box idea that that the floor cut out allows for _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
GypsyDriver Samba Member
Joined: November 06, 2012 Posts: 190 Location: Columbus, GA
Posted: Sat Dec 08, 2018 12:19 am Post subject: Re: Under floor storage box - what are the latest ideas? |
I haven't had any issues. I doubt there's any measurable difference in airflow between solid storage and the stock spare tire. In my case (pun intended), there's plenty of room on all sides of the box for air flow. there's about 3 or 4 inches of inches above the box for the radiator / heater hoses and transmission shifter rod that live in the top of that space. There's about an inch on each side between the box and the frame and about 8 inches behind the box that is now open air where the old spare tire used to be.
PeaceVans in Seattle makes or used to make these battery trays for the space under the sliding door:
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4096 Location: East Kootenay, British Columbia
Posted: Fri Dec 07, 2018 8:05 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
IMHO it's a valid question, VW raised the shifter floor on the diesel models to increase airflow through the radiator. Seems that if you block too much of the airflow with boxes, etc, it may affect the cooling in certain hot conditions. _________________ Currently:
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Fri Dec 07, 2018 3:09 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
Ryan Alfonso wrote: |
Wouldn't spare tire storage boxes/bins/drums limit the airflow? The radiator is right there... Looks to me like hot air is supposed to flow through the radiator and down through the spare and out the tray. [here come the "hot air" jokes... ] |
I have had the space stuffed with drybags. Did not notice an iota of difference in running temperature. |
Ryan Alfonso Samba Member
Joined: March 23, 2007 Posts: 101 Location: Half Moon Bay, CA
Posted: Fri Dec 07, 2018 2:33 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
Posted: Fri Dec 07, 2018 12:14 pm Post subject: Re: Under floor storage box - what are the latest ideas? |
vanis13 wrote: |
true on stick models...Automatics don;t have that issue I understand |
My Westy’s an automatic; it doesn’t have the box over the shifter linkage sticking down in that space.
Here’s another picture. The case fits perfectly between the frame rails. The photo perspective makes it look lower than it I really is. The spacer for the clamshell hook extension is 1.5 inches lower than the stock clamshell.
