gumbya55 Samba Member
Posted: Fri Dec 07, 2018 7:53 am Post subject: NON VW aftermarket wheel thread |
With all the options available for bolt patterns and offsets, wondering why more guys are not running more oversized aftermarket wheels? Let's see those who have custom wheels and list your offsets/specs and pics!
*not my car |
chickengeorge Samba Member
Joined: August 18, 2004 Posts: 5634 Location: Spokompton Warshington
Posted: Fri Dec 07, 2018 9:20 am Post subject: Re: NON VW aftermarket wheel thread |
17x7 with 4.5" backspace up front and 18x7 with 4.5" backspace out back.
Ford Bolt pattern. Front narrowed 6". Rear narrowed 1-9/16" each side with custom made trail arms, short side automatic Type III axles and some custom rotor machine work requiring new caliper mounts.
b-man Samba Member
Posted: Fri Jan 18, 2019 10:05 pm Post subject: Re: NON VW aftermarket wheel thread |
Since 1989 my '66 single cab pickup has been running 16X8.5" 1984 Corvette wheels and 205/55-16 tires. The front rotors and rear drums were drilled for the Chevy 5 on 4.75" (5 on 120.65mm) bolt pattern.
I used Bus Boys exchange spindles (welded on caliper brackets) and modified spring plates/special length axles/trailing arm mounts to convert to 1971 bus front discs (originally 5 on 112mm) and '70 Type III IRS rear suspension and drums (originally 4 on 130mm). Front beam has been cut and turned for a 3.5" drop, still stock width. The 'vette wheels bolted right up with no wheel spacers after the machine work was done, not sure on the wheel back spacing but it's for sure over 6".
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
Posted: Mon Jan 21, 2019 1:33 pm Post subject: Re: NON VW aftermarket wheel thread |
^^ Love it! ^^ |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Mon Feb 18, 2019 9:22 pm Post subject: Re: NON VW aftermarket wheel thread |
Weld wheel dragstar chevy 5 on 4.75 15x4 in front and 15x7 with 3.5 offset in rear no offset in front 5 inch narrow beam. Rear is irs with 1” narrow arms. Wheels are Powerder coated liquid smoke
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1300 Location: North Carolina
Posted: Sat Feb 23, 2019 3:49 pm Post subject: Re: NON VW aftermarket wheel thread |
Porsche Boxster 18”x 7.5” and 18”x9”. With 205/40 and 245/35 tires. |
vwo60 Samba Member
Joined: April 06, 2007 Posts: 116 Location: pomona australia
Posted: Fri May 03, 2019 10:54 pm Post subject: Re: NON VW aftermarket wheel thread |
These are the wheels I had made in the UK to fit my 1960 karmann Ghia, they are three piece Image Wheels, 6" x 17" with an ET of 55 and fitted with 185/50/17 and on the rear are 7" x 17" with a ET of 23 fitted with 205/50/17, they fit perfectly with no rubbing and look great with the added benefit of very light weight. front has a standard width beam running 6 spot calipers and vented rotors along with dropped spindles, the rear has a IRS conversion with CB rear disc's. |
