VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Dec 08, 2018 9:56 am Post subject: Throwing my belt at 7050rpms. Why? |
Hey all! I have been having a blast in the Bug, now that the tranny holds itself together! Thanks Scott at MCM! Super fun to drive! However,.......
My engine keeps throwing the generator belt, if the RPMs get above 7000. Why? What am I not seeing or accounting for?
Back story, as most have seen my threads. I spent a few extra bucks for nicer stuff (twice), then getting it all dynamically balanced (twice), so that I could spin it up 8500. My calculated redline, based off of some material facts and off of some feed back from a few friends that have built engines that spun that fast. I did everything I was supposed to do, but every time the engine hits 7050, the belt get shredded and flies off. Check out the pictures. Not a horrible issue to have, except for the two times the engine has gotten past this magical number, 7050. Then the charging light goes on and I turn the key off! Coasting to the closest parking spot.
Let me know what you all think and any options that are out there. Thanks!
Since I did not have a spare on the second time it happened, I had to turn the belt inside out and run it the two miles back to the house. It worked!
I am guessing that spot that is missing is the one down on the crank, but really have no way to prove it. Why would a belt disintegrate like this? The tension is spot on. Never experienced anything like it before! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Sat Dec 08, 2018 10:02 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
Belt not designed to take the forces made by those rpms? Smaller crank pulley to slow down belt speed?
Or maybe tension the belt even tighter so it doesn't stretch as much at the high rpms. That puts more load on the gen bearings though. |
Xevin Samba Member
Posted: Sat Dec 08, 2018 10:37 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
Maybe go beltless and ad this to your pulley
https://www.oreillyauto.com/flux-capacitor _________________ Keep on Busin'
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
oprn Samba Member
Joined: November 13, 2016 Posts: 12737 Location: Western Canada
Posted: Sat Dec 08, 2018 10:38 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
"7050 rpm" is the key to the problem. Nothing on that engine was designed by VW to take that kind of speed.
I have a similar problem with the implement tires I have on the front of my sand rail. They shake so bad at 70 mph that the front end disappears in a blur and I can see day light under the front wheels. These things happen when we do stupid things to parts that are not designed for what we are subjecting them to! |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Dec 08, 2018 10:45 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
I once had the same problem (at about the same rpm)- if you really want the thing to spin that fast on a regular basis you need a power pulley. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Sat Dec 08, 2018 10:50 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
Simply put you have reached the limit of the fan. The fan can not push any more air above that speed and turns into a brake. The crankshaft continues to go faster but the fan can not. I have experienced the same issues on the drag strip. With a stock sized pulley I can not turn above 6800 RPM as I have always thrown the belt. I turn 7200 RPM with a power size pulley and no problems throwing the belt. Your only solution is not rev that fast with the stock size pulley.
DO NOT UNDER ANY CIRCUMSTANCES INSTALL A SERPINTINE BELT SYSTEM. It will not fix the problem, it will only make it worse. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Dec 08, 2018 11:08 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
Hi, please gdt that fuel filter out of the engine compartment, close to the spark machine, without clamps, ESPECIALLY as you're throwing belts around.
Happened to me once, full size pulley at around 7000-7500 rpm, and it blew the "1300" emblem off the lid. That's enough momentum to pull off a fuel hose. Best place for a filter is just under the tank. Check, you might already have an old one there, too.
Maybe try running a thinner belt, sits down further in the groove, and maybe try running the belt a bit slacker, letting it slip more. Just ideas. |
Posted: Sat Dec 08, 2018 11:23 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
vwracerdave wrote: |
DO NOT UNDER ANY CIRCUMSTANCES INSTALL A SERPINTINE BELT SYSTEM. It will not fix the problem, it will only make it worse. |
Thanks Dave! I had a feeling it was a braking issue of the pulleies, but it was just not working out in my head. You can see that the belt has been completely ripped apart where it was in direct contact with the crank pulley. That missing section is the same exact size! I knew the belt stopped and then the friction of the crank pulley killed it, it then grabbed on hit the generator pulley and launched!
Guess I have to turn the orange needle down to 6500.
Just asking. The serpentine belt will meet the same fate, since it is the cooling fan that actually stops the generator - correct? Never interacted with this belt system and have no knowledge of it, besides the ads and what is in some of the threads.
Damn it! It really feels good around 6800 - sooooo smooth! Scary smooth! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Dec 08, 2018 11:26 am Post subject: Re: Throwing my belt at 7050rpms. Why? |
FreeBug wrote: |
Thank you for your expected response. Carry on, please. Work on VW for 40 years (10 professionally) and then tell me about the filter. Thanks again! _________________ Jimbo
TDCTDI wrote: |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Sat Dec 08, 2018 12:15 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
VW_Jimbo wrote: |
FreeBug wrote: |
Thank you for your expected response. Carry on, please. Work on VW for 40 years (10 professionally) and then tell me about the filter. Thanks again! |
_________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
DeathBySnuSnu Samba Member
Posted: Sat Dec 08, 2018 12:25 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
You are hitting the max hp you can transfer by a single belt. Fan would keep on going IF you could get the hp to it. BUT putting a serp belt or a configuration of belt that can move the hp.....the fan will explode. Hence the welded fans.....
I do not know how many rpm or for how long a stock or welded fan will take.
It is slipping and overheating the belt. Then the belt comes apart.
http://www.offroadvw.net/tech/wes/fan.html _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Posted: Sat Dec 08, 2018 1:18 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
VW_Jimbo wrote: |
FreeBug wrote: |
Dude, it's your car...see if i care if it goes up in flames, just trying to help. You're going to tell me in 40 years, you've never seen this happen? |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Sat Dec 08, 2018 1:22 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
VW_Jimbo wrote: |
FreeBug wrote: |
SPARK MACHINE HAHAHA I haven't had a good laugh in a long time lol. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sat Dec 08, 2018 1:42 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
What kind of belt is that?
Try a gates or dayco raw edge belt,and set it up snug....not too tight.
Nothing wrong with the stock pulleys, but to run over 6500 rpm often it would be smart to run a smaller cooling fan OR a power pulley, so the belt does not overheat so bad. Think about it, on ANY car, the alternator isn't rated to go over 10K rpm, but do the math and at redline it would......so it must be the belt slips. |
ralf Samba Member
Posted: Sat Dec 08, 2018 3:30 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
modok wrote: |
this is true... on a platform we work on...
8,800-9,200rpm seems to be okay and 9,500 was cutting it close
(oem pulley and oem belt)
when we reached 9,700rpm = after the 2nd or 3rd run on the dyno.. the belt is gone \ flips.. so we used to carry 2 spare bnew belts.. then we got tired of it./.. LOL
now run an underdrive pulley.. and 9,700-10,000rpm is fine
so in our bugs.. this must be the 6,800-7,200rpm region.. interesting though hope the OP finds a good solution... a smaller pulley would help yeah _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Dec 08, 2018 5:07 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
VW_Jimbo wrote: |
My engine keeps throwing the generator belt, if the RPMs get above 7000. |
I must be a wimp, because in 4 decades of driving beetles, I've never exceeded 5000 rpm !!! Even with my 1835cc engine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
oprn Samba Member
Posted: Sat Dec 08, 2018 5:50 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
Cusser wrote: |
VW_Jimbo wrote: |
I must be a wimp, because in 4 decades of driving beetles, I've never exceeded 5000 rpm !!! Even with my 1835cc engine. |
Wrong!
My guess is that you are just a regular guy with a regular income who needs to make what you own last. Don't be ashamed of being conservative and taking pride in the longevity of your cars! You are in good company.
I do have an appreciation though for people that have very deep pockets that can walk the edge and show us what the limits are as I don't have the funds to do that. |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Sat Dec 08, 2018 6:24 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
What are the specs on the engine? CCs, heads, carbs? _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Zundfolge1432 Samba Member
Posted: Sat Dec 08, 2018 7:00 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
Cusser wrote: |
VW_Jimbo wrote: |
Not so much different strokes for different folks, I too like the basic design and actually drove stock oval window beetles during the early 80s when they were cheap. Look where we are in the performance forum, these guys like a little something extra some of em like to go very fast. More power to them (pun intended) 😀 |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sat Dec 08, 2018 7:11 pm Post subject: Re: Throwing my belt at 7050rpms. Why? |
Jim, Is this your engine with the Engle 110 cam? |
