Booky Samba Member
Posted: Sat Dec 08, 2018 6:31 pm Post subject: 90.5 vs 92 |
Why does it seem that from what I have seen and read that 90.5mm puts out more horse power than the 92mm does on average builds? |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sat Dec 08, 2018 6:45 pm Post subject: Re: 90.5 vs 92 |
Whats one of your examples that you seen? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sat Dec 08, 2018 8:14 pm Post subject: Re: 90.5 vs 92 |
Not true at all with the 92 thick walls. A larger piston always has the potential to make more power.
Now the reality is the 90.5's are thicker cylinder walls than the old school thin 92's so the cylinders don't hold their shape and you have more blow-by robbing power. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sat Dec 08, 2018 8:18 pm Post subject: Re: 90.5 vs 92 |
It's kind of outdated now because mostly everyone using 92s are using the thicker barrels now. 92s will make more horsepower or torque now if they use the thick wall cylinders.
The older ones were so thin (about .118" thick), that they'd go really out of round when they got up to operating temp. The rings can only conform so much to a warped bore, so they'd see higher blow-by. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Booky Samba Member
Posted: Sat Dec 08, 2018 8:19 pm Post subject: Re: 90.5 vs 92 |
Take CB Performance website I believe it says it 1776 vs 1835 is like 10 horsepower more for 1776. |
Booky Samba Member
Posted: Sat Dec 08, 2018 8:32 pm Post subject: Re: 90.5 vs 92 |
Plus I miss read CBs website. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Sun Dec 09, 2018 9:45 am Post subject: Re: 90.5 vs 92 |
vwracerdave wrote: |
Now the reality is the 90.5's are thicker cylinder walls than the old school thin 92's so the cylinders don't hold their shape and you have more blow-by robbing power. |
My thin-wall 92s have been inside my engine since 1986, in the Arizona heat.
How will I know when this shape distorts and I have blow-by robbing power ???
Don't worry about the blue paint on my tins in the photo, I'll paint those the next time the engine is out. But that hasn't been out in well over a decade.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
jpaull Samba Member
Posted: Sun Dec 09, 2018 10:00 am Post subject: Re: 90.5 vs 92 |
Cusser wrote: |
You gotta make some horsepower before you can make some heat to distort those thinwalls. Your single carb 1835 might not be at that point yet😊😊😊😊 |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Sun Dec 09, 2018 11:03 am Post subject: Re: 90.5 vs 92 |
Booky wrote: |
Are you referring to Builder's choices Kits? I didn't find any 92mm, here's the list:
Part #----Engine Size------------TargetHP--Desired Result
1179-----1904cc [90.5 x 74]-----90-------Gas Saver [Great Fuel Economy]
1180-----1776cc [90.5 x 69]-----105
1181-----1915cc [94 x 69]-------120
1182-----2005cc [90.5 x 78]-----140
1183-----2110cc [90.5 x 82]-----150
1184-----2165cc [94 x 78]-------160
1185-----2276cc [94 x 82]-------180
1186-----2332cc [94 x 84]-------200
1187-----2387cc [94 x 86]-------220------Big Power Signature Kit [MAX HP!]
Edit: But they have a video of an 1835 with 48 IDAs that made 165HP@6800 rpm...
Posted: Sun Dec 09, 2018 11:08 am Post subject: Re: 90.5 vs 92 |
jpaull wrote: |
[You gotta make some horsepower before you can make some heat to distort those thinwalls. |
That is so wrong. Any engine that is not tuned correctly will overheat. HP has nothing to do with the cylinders warping. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Dec 09, 2018 11:18 am Post subject: Re: 90.5 vs 92 |
He was joking Dave |
jpaull Samba Member
Posted: Sun Dec 09, 2018 11:24 am Post subject: Re: 90.5 vs 92 |
jpaull wrote: |
That is so wrong. Any engine that is not tuned correctly will overheat. HP has nothing to do with the cylinders warping. |
Of course! Thinwalls will warp easier if anything goes wrong, but Cussers post is asking why his are working so well, so my response is giving a possible answer😊 |
