Joined: June 24, 2015 Posts: 715 Location: Rialto. CA
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Thu Dec 12, 2019 8:54 pm Post subject: Re: 36hp Cam Bearings / Service Available Soon..... |
Yeah. I seen that listing. That is another method of installing cam bearing inserts. This way is permanent and should last the life of the block. _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
TomSimon Samba Member
Posted: Wed Dec 18, 2019 5:27 am Post subject: Re: 36hp Cam Bearings / Service Available Soon..... |
That's quite a game changer, and a great way to salvage an otherwise worn out 36hp VW or Porsche case.
If you don't already have your own cam tunnel boring bar, and need one custom made, I suggest you talk to Rocky Jennings in Washington, he's a real cleaver machinist who already makes and sells his own line of case boring bars.
What's next? Oversize oil pump gears and machining service to save 356 3pc case front covers? _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
jz56oval Samba Member
Joined: September 03, 2007 Posts: 375 Location: bay area
Posted: Sun Jan 31, 2021 11:44 am Post subject: Re: 36hp Cam Bearings / Service Available Soon..... |
Any further updates on this set up? |
Posted: Sun Jan 31, 2021 11:53 am Post subject: Re: 36hp Cam Bearings / Service Available Soon..... |
jz56oval wrote: |
Actually....just yesterday I was going through my Porsche Pre-A 2pc. engine blocks and noticed that I have 3 that need some type of cam bore work. I already made 1 type of boring bar. I need to have it surface ground. I need to make the tooling to secure the bushings in place so when the boring bar is run through the cam bores, they are concentric to each other. A lot of work and I wish I had more time to dedicate to this project. _________________
VW www.Okrasa.com
Posted: Sun Jan 31, 2021 11:59 am Post subject: Re: 36hp Cam Bearings / Service Available Soon..... |
Mr. Okrasa wrote: |
jz56oval wrote: |
Actually....just yesterday I was going through my Porsche Pre-A 2pc. engine blocks and noticed that I have 3 that need some type of cam bore work. I already made 1 type of boring bar. I need to have it surface ground. I need to make the tooling to secure the bushings in place so when the boring bar is run through the cam bores, they are concentric to each other. A lot of work and I wish I had more time to dedicate to this project. |
Awesome. Thanks for update. |
