Deebs Samba Member
Joined: June 23, 2018 Posts: 248 Location: Chattanooga, TN
Posted: Mon Dec 10, 2018 12:15 pm Post subject: Thermostat not opening in cold weather or paranoia? |
I've been keeping my eye on this since I installed the thermostat and flaps recently. Since it was my first time installing, I researched on here and found this procedure for installing the thermostat:
1) Screw in thermostat to the link rod (I screwed in gently all the way up until I felt resistance). I also checked to make sure the link moved freely up and down without much resistance.
2) Installed the bracket loosely, and placed the thermostat inside the bracket.
3) Where the bracket sat in relation to the position of the fully screwed in thermostat, I then tightened the bracket. At this point, the bracket is fully mounted and the thermostat is screwed in, sitting high up off the bottom of the bracket.
4) Pulled the thermostat/rod down into its seat in the bottom of the bracket and fastened it down with the bolt.
Today I went for a roughly 5-10 mile, 20 minute drive. The temperature outside is 43* (feels like 39*). I took photos of before and after because I wanted to visually see if the thermostat was functioning properly, or if I installed it wrong.
Needless to say, both before and after look the same.
Before:
After 20 minute drive:
Does this seem normal for this temperature? I may try again with a longer drive (I never really got over 40 mph this time).
It's a bone stock 1600DP and was just tuned up including valves, timing plugs etc...
So, am I overthinking this? |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Dec 10, 2018 12:20 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Not a good enough test. Go get an industrial heat gun, like for taking paint off of walls. Then remove the thermostat and bracket from the car, but leave the thermostat in the bracket, because if they grow larger than the bracket allowance, they go bad!
With it out of the car, blow that hot air over it, for a little bit, maybe 4 or 5 minutes. You will see it expand fully. If it does not expand, go for another 5 minutes. If it still does nothing, you do need a new thermostat.
Also, with the thermostat removed, be sure you can push the flap rod up easily. Sometimes these get installed incorrectly and bind up in the head or on the flaps. Seen that a few times! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Deebs Samba Member
Posted: Mon Dec 10, 2018 12:29 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
VW_Jimbo wrote: |
Also, with the thermostat removed, be sure you can push the flap rod up easily. Sometimes these get installed incorrectly and bind up in the head or on the flaps. Seen that a few times! |
I actually just went out and tried this under the car with a hair dryer (long nose of the hair dryer gave me a better angle than my heat gun). It definitely opens!
That said, it almost looks as if things may not be properly aligned. I may loosen the bracket and change it's angle a little, because the thermostat doesn't look like it is sitting completely "inline" if that makes sense. |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Mon Dec 10, 2018 12:33 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Where the rod goes thru the head make sure that it travels smoothly... you should be able to pull on it and move it freely up and down with just slight resistance from the spring. _________________ 66- Ghia
76-Beetle |
kpf Samba Member
Joined: March 01, 2017 Posts: 852 Location: California, US
Posted: Mon Dec 10, 2018 1:16 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Definitely make sure that the rod or other parts of the mechanism are not binding, and that it is all free to move.
I don't have any cold-weather experience (southern California), but my thermostat will start opening just by idling in the driveway. If I remember correctly, the choke opens up and shortly after that I'm able to see the that the thermostat has started expanding.
I've also noticed that if I look at the thermostat after returning from a short drive of only a few miles around town, the thermostat looks fully expanded (or very close to it).
Regards,
Kris _________________ 1971 Super Beetle |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Deebs Samba Member
Posted: Mon Dec 10, 2018 1:28 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
AWESOME. Thank you!
And thanks to everyone else too for their help. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Dec 10, 2018 6:12 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
If the thermostat is expanding all the way so that the top of the thermostat is in contact with the bottom of the upper part of the bracket, then you should b in good shape.
But to check ... when cold, remove the bottom thermostat bolt and let the thermostat pop up. Then pull the thermostat down and release it. It should pop up all the way easily. If not, it’s ganging up. I’d also tell you to test if the thermostat opens, but you know it does already.
I adjust the thermostat and bracket simultaneously. I remove the thermostat bottom bolt, then loosen the thermostat bracket nut. At this point, I push up on the thermostat all the way until it stops. This procedure simultaneously pushes the bracket up where it should be. Then, I tighten the bracket bolt, pull the thermostat down into its slot, and install the thermostat bolt.
You can check to see that your flap linkage is moving by having an assistant look in front of the fan shroud while you push and pull on the loose thermostat. Naturally, you do this before adjusting it.
If you’re not getting some really hot air blowing from the heads, your thermostat will not open until you get to 65 degrees Centigrade. Check on a chart to compare to Fahrenheit. I think you’ll find that’s pretty hot.
Edit: Actually, I just checked and 149 F, is equivalent to 65 C.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Mon Dec 10, 2018 6:28 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
_________________ Glenn
Member #1009
#BlueSquare |
Deebs Samba Member
Posted: Mon Dec 10, 2018 6:54 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Tim Donahoe wrote: |
Tim |
Thanks Tim, and Glenn for the video. My link is most likely ganging up, because one side of the bellows seems to expand further than the other, and not to the top of the bracket. I'm going to loosen everything tomorrow and readjust it. I'll update when it's fixed. |
wcfvw69 Samba Purist
Posted: Mon Dec 10, 2018 8:29 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
I read somewhere that in really cold places like 20° of lower, the thermostat will not open all the way if at all. It helps the engine try to reach temperature in those cold temps. _________________ Contact me at [email protected]
The Samba member since 2004.
TX-73 Samba Member
Posted: Mon Dec 10, 2018 8:37 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Besides verifying that the flaps move freely, be really sure the vertical connecting rod has clearance as it routes thru the cylinder head. Just a slight tweak and it will bind. I had one that was a bit off, no matter how I tried to make it right it just wouldn't clear as it moved thru its operating range. Got another oem rod thru classifieds and it was perfect. _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
Posted: Mon Dec 10, 2018 10:09 pm Post subject: Re: Thermostat not opening in cold weather or paranoia? |
wcfvw69 wrote: |
I read somewhere that in really cold places like 20° of lower, the thermostat will not open all the way if at all. It helps the engine try to reach temperature in those cold temps. |
this
When it's cold like below 32 the t-stat will only expand if the air from the heads has warmed up enough this is why it is important to make sure that the sled tins and all the lower tinwork are in place as it actually holds the heated air where you want it... I mean that it does exhaust out the bottom but it's held in around the t-stat long enough to have effect. _________________ 66- Ghia
76-Beetle |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Tue Dec 11, 2018 4:22 am Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Are new thermostats available? |
vamram Samba Member
Posted: Tue Dec 11, 2018 4:48 am Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Awesomepowdercoat.com fabricates and sells them. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 791 Location: dallas, tx
Posted: Tue Dec 11, 2018 6:09 am Post subject: Re: Thermostat not opening in cold weather or paranoia? |
vamram wrote: |
Awesomepowdercoat.com fabricates and sells them. |
Got mine thru them... $130 if I remember correctly _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
74 Thing Samba Member
Posted: Tue Dec 11, 2018 7:06 am Post subject: Re: Thermostat not opening in cold weather or paranoia? |
Make sure your fail safe open spring is attached behind the shroud. |
garyloos Samba Member
Joined: August 13, 2015 Posts: 93 Location: Wet Lafayette, Ohio 43845
gt1953 Samba Member
Posted: Tue Dec 11, 2018 7:46 am Post subject: Re: Thermostat not opening in cold weather or paranoia? |
The thermostats show up from time to time hear in classifieds and are snapped up. I check mine from time to time in the winter and summer, jast have to make sure all if operating correctly. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Deebs Samba Member
Posted: Tue Dec 11, 2018 8:11 am Post subject: Re: Thermostat not opening in cold weather or paranoia? |
I bought my whole setup from Awesome Powdercoat. The quality is great. The spring is definitely installed behind the shroud as well. |
