disc brakes for a king pin set up?
redfinger61
redfinger61 is offline
PostPosted: Tue May 04, 2004 2:40 pm    Post subject: disc brakes for a king pin set up? Reply with quote
Has anyone out there ever done this before? How hard/expensive is it, should I just pull out the link pin beam, and put a new one in from say, a later model Ghia? Any addvice would be great.....
Ashton
Learn to listen, Listen to learn...
Ragman
The Sambinator
Ragman is offline
PostPosted: Wed May 05, 2004 1:02 pm    Post subject: Reply with quote
It is not necessary to change the beam at all. There are various kits to upgrade to discs. You'll need to replace the spindles, but keep the King/link pin beam. I have CB Performance Wide 5 disc brake set up, and it is very nice. Another option is a 4 bolt pattern kit (vw or porsche pattern).
Dave
Samba Elder
Dave is offline
PostPosted: Fri May 07, 2004 6:59 am    Post subject: Reply with quote
CB, CSP, and SoCal Imports, Inc. all offer wide-5 front disc brake kits. Some increses the wheel track a little bit ( about 1/2 inch per side) so depending on your choice of tires, that might be a concern) some are "zero-offset", and all of them are bolt-on; if you can get to your backing plate, and remove them, and can bleed your brakes, you can do the swap at home. Something you may want to consider is purchasing an item called a "porportioning valve" that lets you set how much brake line pressure goes to which end of the car. With skinny 135 or 145 tires, it's pretty easy to lock up the front wheels with discs in front.
2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter"
